Question about Samsung B2230HD LCD TV
SAMSUNG B2230HD HAS NO DISPLAY - Samsung B2230HD LCD TV
Problem connecting dvd recorder.
All tape recorders made since the late-1990s are equipped with protection interlocks to prevent you from copying copyright material to tape. They work in different ways but, generally, they will thwart any attempt to copy a DVD to tape.
May 21, 2015 | Samsung B2230HD 22 inch Widescreen LCD...
Driver for Linux
Normally Linux doesn't need drivers because are already present on kernel. I doubt you will find one from a Samsung product.
What's exactly your problem with this monitor?
Sep 04, 2012 | Samsung SyncMaster B2230HD - LCD monitor -...
Cant get b512 universal remote control to work tv
not all remotes will program for all sets.
Jun 07, 2012 | Samsung B2230HD LCD TV
I cant connect my BD512 universal remote contol to work on my samsung B2230HD tv
It likely does not have the code built into it that is needed.
Jun 07, 2012 | Televison & Video
B2230HD TV STAND REMOVAL
First of all, thank you very much for choosing FIXYA today for your online technical support needs.
See page 2-3 of the User's Manual for detailed instructions on how to remove the base stand on that monitor. But basically you just lay the monitor face down on a soft cloth so as not to damage the screen, and then just pull the base firmly straight out (downwards).
Here is a direct link to the ONLINE USER'S MANUAL for that model:
http://downloadcenter.samsung.com/content/UM/201008/20100820090207453/BN59-01091B-01Eng.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted section of text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Feb 18, 2012 | Samsung B2230HD LCD TV
I can't hear anything when I plug in the headphones in the headphone output in the back, I can only hear something when I turn the volume up to 100, but still, what I can hear is very low... Please...
Check the impedance of your headphone, which should match with the specified impedance in the user manual. The impedance of your headphone is very high.
sonsunny
Jun 16, 2011 | Samsung B2230HD LCD TV
It seems to forget its freeview channels and starts to run through every channel, interupting tv service provide by scart connection to talktalk box. First sympton is the sound volume icon appears on...
Tries tv and the box unplug,replug it back like about an hour later.For the tv to do a resetting itself back to the factory setting.The box to upgraded it softwares.Tv should be working again.If still have the same problems.Take ur tv backcover aparts and disconnection of the tv side manual control board PCB wire connection plug in that have like Power,Channel - +,Volme - + and Menu so on buttons switches.Turn the tv on and see if tv funtions correctly If yes than the tv manual cotrol buttons PCB board have to be change.If the manual contol board is diconnected from the tv Tuner signal board and have the same problems.Than ur tv have a bigger problems,the tv Tuner signal board is the causes and the problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish manual control PCB board or the tv Tuner signal boards for the replacement.
Apr 07, 2011 | Samsung B2230HD LCD TV
Samsung B2230HD LCD TV Logo
20 people viewed this question
Jerry Greenberg
Jerry Greenberg
