Question about Garden
22" eagar-1 snow thrower manual
Missing switch and primer for Craftsman 22" eager-1 snow thrower. I need a manual for it any help will be appreciated.
    Top Expert:
  • 2,044 Answers
Http://www.searspartsdirect.com/
Put in your Model Number and your Parts Breakdown will show you all of the parts.... This was the Easiest One of the day.
Posted on Feb 12, 2014
rwvanlue
  • 486 Answers
SOURCE: craftsman snow thrower. headlight stopped working.
The voltage from the alternator is AC, and will increase/decrease with the engine speed, so when checking, run the engine at full throttle. 1/2 of the alternator is not used, the other 1/2 is used to power the light. Also, inspect the light harness plug-in just above or below the starter. Check for being disconnected, burnt, or wiring pinched around the starter mounting area. Lastly, check the bulb with a 12 volt battery, connecting one bulb spade to the + connection of the battery, and the other spade to the - connection.
Posted on Nov 22, 2009
jyackle5
  • 8197 Answers
SOURCE: I just bought a used
I was unable to find an owner's manual for download or for purchase. The 842.240561 manual is no longer available. When a manual is not found for download or purchase the other option you have is to please call the Manage My Home Member Services Team at 1-800-803-6775, between 8 a.m. and 8 p.m. Central Time. They will be more than happy to help you track down the manual.
Posted on Jan 06, 2010
  • 16 Answers
SOURCE: CRAFTSMAN SNOW THROWER DRIVE WHEELS WILL NOT MOVE
well if it is a walk behind style it could be the drive is out of adjustment, also craftsman were famous for the cable mounts bending and that will throw them out of adjustment. follow the traction drive linkage down to the base of the blowe and there should be an adjustment, or it will be under the belt gaurd or even on the handle on some.
Posted on Feb 04, 2010
huffman49
  • 235 Answers
SOURCE: Snow thrower is self propelled. was working fine then stalled
check the bearings in the auger sounds like the froze up and now they need to be replaced (the smoking you saw was from the belts slipping on the pullies)..good luck
Posted on Apr 14, 2010
  • 4345 Answers
SOURCE: I inherited my Father's Craftsman
Look for an oil fill location, like on all small motors. My guess would be it has oil reservoir crankcase.
Posted on Oct 07, 2010
I need a service manual for snow thrower model# 247.888160
manual can be had at link below, if carb. is leaking fuel chances are it has dirt in it and requires rebuilding which I will post a second link to.
press the helpful button
Craftsman 247 888160 Owner Manual
How to Fix Snow Blower Carburetor
Oct 15, 2015 | Craftsman Sears Snow Thrower Manual Model...
Manual for sears snow thrower 536.886621
They are basic what do you need to Find in the Manual?
Feb 12, 2014 | Craftsman Sears Snow Thrower Manual Model...
How do you replace a leaking primer?
You must go through Sears to get the parts you need.
Feb 08, 2014 | Craftsman Sears Snow Thrower Manual Model...
How to take a carburetor off an MTD Snow Thrower
Get user manuals for craftsman snowblowers to train yourself in clearing the pathways that are fully covered with snow.
Dec 15, 2013 | Mtd Yard-Man 26" 208cc Two Stage Gas...
Where is the throttle on a craftsman 536.881800 snow thrower?
Manual is available at http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Snow-removal-equipment-Parts/user-manuals/manual-downloads/Model-536881800/0247/1507200?modelNumber=536881800&diagramPageId=&documentId=
Dec 14, 2013 | Craftsman Sears Snow Thrower Manual Model...
Engine on 30"Craftsman 2009 snow thrower won't prime. Primer button and connecting tube look good. Primer button won't send gas to the carb.
the priming bubble can look totally perfect, but all it takes is a pin hole and right around the retaining ring is hard to spot a crack and you should also check fuel lines in tank
Jan 07, 2013 | managemylife.com
I have a craftsman eager 1 4.5 hp 22
clean the jets in the carb
Jun 03, 2012 | Garden
Garden Logo
82 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
