Fortress 1700 ta/2.5 y.old /3 whls driving for 10_15 min.power shots down .the battery indicator will flash. Removing the ignitoion key,reset and drive a little more it will
SOURCE: I have 2005 pathfinder my
I EXPERIENCE THIS PROBLEM BEFORE , THE ENGINE MISFIRES BEFORE IT DIES, FEELS LIKE ITS RUNNING ON 3 CYLINDERS AND THEN IT DIES AND IF YUO WANT TO START THE ENGINE RIGHT AWAY IT JUST CRANKS, FOR THIS PROBLEM I FOUND LOW VOLTAGE READING COMMING OUT OF IPDM RELAY TO ECM ASSY , AND I FIX THIS PROBLE BY REPLACING THI IPDM.
SOURCE: 1996 Volvo 850 wagon sputtered @ intersection smell of antifreeze
I would check that the auxilliary drive belt that runs the alternator and probably the water pump hasn't just broken, causing the engine to overheat and the battery to run flat. Just a suggestion, hope it helps.
SOURCE: laptop battery charge indicator flashing amber and green
If the battery is hot from being used in your computer or being in a hot environment, the battery may not charge when you connect the computer to an electrical outlet.The battery is too hot to start charging if the light flashes alternately orange and green. Disconnect the computer from the electrical outlet and allow the computer and the battery to cool to room temperature. Then connect the computer to an electrical outlet to continue charging the battery.
Regards..
SOURCE: peugeot 406 estate 2l hdi, anti polution light on
it would never be 1000 euros!!!!!!!!!!!! it will be part of the exhaust system it cuts out because its causing pollution
