Question about Cuisinart Coffee Makers & Espresso Machines
Grinder on quisinart cereal # 90219C not grinding beans
Serial # 90219C
  • 8 Answers
SOURCE: Coffee beans will not grind
If the grinder is blocked try changing the grinder setting up to the coarsest setting (I think it is numbered 16 on this model) and then vacuum or fill with beans and push them through. Be sure that any damp coffee has gone as you don't want the grinder blades to be left wet.
Never freeze or refrigerate your coffee beans as the condensation from doing this can also block your grinder. Also never use coffees that have been flavoured during the roasting process as they are often too sticky or oily and will block your grinder. These coffees should be ground using a grinder that can be easily pulled apart for cleaning...which is not the case in the Saeco automatic machines.
After you have finished clearing your grinder you will want to turn it back down to a finer setting ( a setting of 6 or 7 works well on this model) however you should only turn the grinder setting finer while the machine is actaully grinding. Otherwise you may find the coffee beans jam between the blades.
If you are unable to clear the blockage it might need to go to a technician.
Posted on Dec 09, 2007
SOURCE: grinder does not work!
http://www.cerinicoffee.com/custompages/Tech/Grinder_Adjustments_for_Italia.pdf
Posted on Apr 12, 2009
  • 352 Answers
SOURCE: Beans are too oily
This fixes almost all the "beans will not feed or beans will not grind" problems caused by coffee bean dust packed in the burrs. Oily beans cause this problem more fequently.
a. Pour all the beans out the top.
b. Open the settings up all the way and see what else can be poured out. Use your shop vacuum to **** grounds out the spout and backward out the bean bin.
c. Pour in some instant rice and start grinding. Reduce the grind to a small setting like six and then open the settings all the way again. (The grinder will not start at a low setting with the rice in it. If you let it stop, open the settings to about 16 before trying to restart.)
d. Pour out the rice and vacuum out the ground rice.
e. Adjust the grinder to your favorite setting and try a coffee grind. Grind until most of the rice dust is expelled (any remaining trace of rice dust will not affect the flavor of the coffee).
Posted on Dec 01, 2009
  • 1089 Answers
SOURCE: the coffee grinder on my Magic Comfort Plus is not
Hi Sounds like you have a blockage in you grind passage. Try removing the brew group. Then inside on the roof of the machine where the brew unit was setting there is a drop chute where the coffee is dropped into the brew unit. From the left side of the drop chute pull down and back, and it will drop coffee. This will clear an opening that relieves pressure on the passage. There is a passage inside the drop chute area that goes to the grinder. Vacuum it out. It will be on the right side of the drop chute. Once that is cleared go to the bean hopper. There is a lever under the bean hopper. Push the lever back to the largest number. You can push the lever to a larger number any time, but it has to be grinding to pull to a smaller number. Now replace everything and make your coffee. Once you have made your coffee you can pull back to a number that was higher than the one you had it on, but only when the grinder is running.
Posted on Jan 25, 2010
SOURCE: DGB-900bc will not grind
I experienced the same problem after many uses. You need to pull the hopper off and clean out the path the grounds take to the filter basket. It is no doubt clogged up. I used compressed air to really clean it out good.
Good Luck
Posted on Aug 31, 2010
Our Saeco Vienna Superautomatica sounds like it's grinding beans but keeps running until the red 'bean' light comes on and we have to shut the machine off. Any suggestions?
The grinder is timing out and stops if the beans do not enter the grinder. This happens because:
1- The grinder outlet is clogged and fresh beans cannot pass through the burrs.
2- The grind setting is too fine and helping clogging in the grinding chamber or the ground coffee outlet.
3- Operator may have been using dark roast oily beans. Like it or not, the dark roast oily beans do not make stronger espresso. Please stop using such beans in fully automatic espresso machines.
4- The grinder has already made over 2000 grinds and the burrs are blunted and not grinding beans as needed.
To solve this malfunction, clean the grinder. Make sure the grinder outlet to the doser is cleaned. This outlet passage is about 2 inches or more. To clean it, lay the machine on its back (water tank side) to allow better view of cleaning the doser and the passage of coffee from the grinder to the doser. Use the link below to find instructions for cleaning the grinder and replace the burrs.
Gaggia Titanium and Plus Espresso machines parts and repairs Saeco...
Oct 18, 2014 | Coffee Makers & Espresso Machines
Why aren't the beans being ground?
try pushing the beans into the grind mechanism while it is grinding or turning the grinder knob but only when grinding, or try different beans
Jun 10, 2014 | Saeco Incanto Classic Espresso Machine
Why does ground coffee not go thru shoot
If using Beans; it is set to fine and due to static it sticks - OR you have a blockage..
If you are putting ground coffee into a grinder; the static will be a bigger issue and in addition there is no weight from the beans to press the grinds into the burrs. A bean grinder is not ment to grind beans that have already been ground.
Get a better grinder and do not buy supermarket beans.
May 31, 2014 | Capresso 560.01 Infinity Burr Grinder,...
Fill beans
the coffee beans are not entering in the grinder disks and since they rotate without coffee the machine understands that their is no beans. You need to clean the grinder disk and grinding coffee funel to bee sure their nothing blocking the coffee movements. Use a vaccum cleaner and try to clean everything in grinder and grinder exits. Try also the machine by regulating thegriding to more gross coffee and when it will start grinding normal then you can udjust step by step back to grinding position you have at the begeining.
Feb 27, 2012 | DeLonghi ESAM 5500M
When grinding coffee beans the grinder is not dropping the beans into the grinder part. I have to stay and shake or bang the grinder on counter to get the beans to fall through.
you must screw off the burr holder plate screw (in center) you will order one special screw, drill shaped, when the burrs roll it will mix and take down the coffee beans. That is solution i applied to many grinders. PS: beware the direction of burrs must be coordinated with new screw.
Feb 07, 2011 | Cuisinart Supreme Grind DBM-8 Electric...
I bought new green coffee beans recently, roasted it myself and wanted to use it in the machine but the grinder gets stuck and won't turn. The new beans are harder and smaller than the type I used to have....
Oct 21, 2009 | Gaggia Paros Espresso Machine
My A-9 Coffee grinder no longer grinds coffee. Have cleaned it and checked it out and nothing. The motor runs but no grounds. Thanks for your help!
Jul 21, 2009 | KitchenAid A-9 Electric Burr Grinder
Spinning but not grinding
Dec 08, 2008 | Cuisinart Supreme Grind CCM-16PC Grinder
Grinder says no coffee beans after grinding, why?
does it realease the grinded coffe beans in the dregdraw with out using it?
if that is the case it a very small electricboard on the grinder that has stoped working or the connecter has fallen of from it.
Jun 26, 2008 | Saeco Talea Touch 14-Cup Coffee Maker
Coffee Makers & Espresso Machines Logo
19 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
