Question about CEN-TECH Heavy Duty 6/12 Volt Battery Charger/Starter
Cen-tech 60581 charger/starter - CEN-TECH Heavy Duty 6/12 Volt Battery Charger/Starter
I'm charging my battery on my rv new. Artery but it was ran down because my break switch was bad and the light stayed on my new cen-tech charger light stays green and I hear a clicking
Disconnect any wiring to the battery. Connect only the charger. Insure you have the charger connected to the proper polarity.
Does it continue to click? Does it not charge? If it won't charge for you, pull the battery and take it to a friendly service station or auto parts store that can test, and or charge it for you. It could be you discharged the battery all the way and damaged it. The normal safe zone is to never discharge below 50%. They might have to attempt a charge that takes up to 45 minutes. If the battery is over a couple years old I would opt to just replace it. I would never trust it and end up getting stranded somewhere.
Feb 13, 2017 | RVs
Cen tech code reader problems 98568
All OBD Codes are on the internet with
print,charts,video,solutions
You Type your codes & read up
Study OBD 2 Systems also
OBD PO171
OBD PO174
I had to Google Cen Tech as i never heard of it
They appear to be inexpensive low end for sure
You won't get a lot of data out it
If your never planning on going to professional software,
consider the top scan/code reader type tools like Innova Professional or at least mid level Actron & a couple other brands
You really need to see sensors,emission monitors, so
your ready for inspection
You will only get Generic Codes from a code reader
not body functions likes abs,air conditioning,srs,& others
More data is better-- you will learn these systems as time goes by
They have been with us for 35 years now
OBD1 15 years
OBD2 20 years
Aug 17, 2014 | 1999 Ford Ranger SuperCab
I need battery charger cen-tech 69368 manual
Sorry to say, but Harbor Freight's parts list has no internal parts listed. So to fix it yourself, you may be able to find the little tiny diodes that usually go bad. They don't even have a wiring diagram in the owners manual.
Apr 03, 2014 | CEN-TECH Heavy Duty 6/12 Volt Battery...
On a CAN OBD2 cen-tech whats is this code saej1850pwm
our shop www.obd2works.com supply obd2 scanner,welcome to our shop http://www.obd2works.com/
Dec 06, 2013 | Roadi Office Equipment & Supplies
When hooking up the cen-tech 60581 charger/starter the charge status light flips back and forth from green to red while the ammeter also flips back and forth. Is that what it is supposed to do until fully...
I don't think so, It did that on one of my lawn tractor batteries but not on the other lawn tractor or car battery, I suspect something is wrong with the battery.
Oct 01, 2013 | CEN-TECH Heavy Duty 6/12 Volt Battery...
Where can I down load an Cen -tech item 92375 5-1
Maybe Cen-tech can produce a manual or Harbor Freight might be able to help
Aug 09, 2013 | Measuring Tools & Sensors
Need manual or operating info for a cen-tech stud finder mdl 92375
Re: above answer. There is no button on this model. Now what?
Dec 22, 2012 | Measuring Tools & Sensors
Cen-Tech code P0113 intake air temperature sensor 1 circuit high.
Check intake air boot or duct for a small 2 wire sensor, you may have not seen it as u pulled duct out of your way, don't feel bad I've done it before check that first , if u can't find one that it will be a internal part of the m,a,f, mass air flow sensor , usually a big round sensor inline of intake duct both of these will be before the throttle body ,mag has 4-6 wire connector !
Apr 17, 2012 | Cars & Trucks
Maserati Gran Sport 2006 - Car was idle for a couple of weeks w/ a trickle charger. Disconnected trickle charger and attempted to start car. Lights on the dash lite up normally, pushed starter...
probably your battery cant conform minimum requirements of digital circuits used to drive starter motor in high tech cars. that is why it works only with external charger. measure your abttery. it should be showing at least 12.4 volts. normally battery should show 12.5. to 12.65 volts. probably your battery has sulfation. end of its life.
Nov 18, 2011 | 2006 Maserati Gransport
CEN-TECH Heavy Duty 6/12 Volt Battery Charger/Starter Logo
164 people viewed this question
Top CEN-TECH Hand Tools Experts
Don Numinen
Don Numinen
Ivan
Ivan
Level 1 Expert
Bill Boyd
Are you a CEN-TECH Hand Tool Expert? Answer questions, earn points and help others
