Question about Home
Fix sliding door
Slider won't slide
  • 4 Answers
If you clean it out and oil it where the marks of it rubbing are it may help
Posted on Feb 13, 2014
2 Suggested Answers
jaden_smith9
SOURCE: How to fix a home interior pocket sliding door?
Sliding doors are also made of glasses. One should not opt for glass doors or glass partitions, if they want some privacy. Go for it only if you want an elegant look for your home. One should always go for glass partitions of good quality. Most of the glass partitions come with warranty. So, select those only of great quality, since low quality sliding doors are not that reliable. For more detail;s regarding installation of sliding doors visit this blog
Design Your Home with Interior Doors
Posted on Jan 15, 2014
2013 ford raptor - any info power rear sliding glass worked intermittently a few days, now not at all. Suggestions? ?
Probalby it's the elcetric motor which raises the windows. Disarremble the door and replace it
See some tutorial how to do it:
How To Fix your Car Electric Windows Slow Moving or Stuck They can be...
2010 ram sliding window repair
Power Window Repair Window Slider Replacement Second Generation Saturn...
How to fix Honda Odyssey automatic sliding door
If after haveing watched these videos you feel that you can't do it yourself, take tor car to a proper repair service, they should repair it in aboout 30 minutes.
Aug 20, 2015 | Ford Cars & Trucks
Sliding rear door stuck in open position
Is it a power slider? What side is it? If it's a power slider it's possible the fuel door was left opened when the door was opened? If so, turn off the power slider switch on the left side dashboard (left of the steering wheel), then manually close the door. Make sure the fuel door is closed before turning it back on.
Jul 26, 2013 | Honda 2012 Odyssey EX-L
How do i open the battery door on my D3000
Try again. Slide the tab and pull on the door lightly. Or after sliding it, keep the slider in that position and turn the camera upright so that the battery presses against the door.
May 16, 2012 | Nikon D3000 Digital Camera
Can I have a dog door in a sliding glass door?
It is possible to have a dog door in a sliding glassdoor. You open the door about a footwide and insert a panel that has a small dog door at the bottom. You are able to lock the panel to the windowand wall as well as lock the dog door itself. These are very common and useful products because most people don't wantto drill a hole through their front door!
May 15, 2012 | Pets - Others
My 16k slider hitch does not slide. the handle moves from maneuvering to tow, but the hitch won't slide. It's like it is jammed in the tow position. Any answers?? THANKS
Most "Sliding" Cequent products won't slide by hand. You will need the full weight of a trailer in order to do so. All CURT rollers glide with ease.
Apr 13, 2011 | Slider 18K Select Plus Fifth Wheel Trailer...
Removing a slider door to patio
open the slider 7/8 of the way open and lift the slider up and out of the track. you may have to get a helper as the slider is heavy. there might be little plastic clips in the top track of the door that need to be removed before lifting the slider out.
Jun 06, 2009 | Anderson Manufacturing Greg Anderson,...
06 Sprinter van slider door
there is an adjustment on the rear of the door on the inside. remove the cover and have the door shut completly then loosen the torx head bolt slide the assembly to the front of vehicle then tighten. if this does not work make sure all slider wheels are good.
May 11, 2009 | 2006 Dodge Sprinter
Sliding Glass Doors Open to Wrong Side
framing, drilling, moving the track for the sliding door... 1-10 its a 5 on the pro scale of difficulty.
Mar 23, 2009 | House Brand Unknown House Deluxe 13 / Va:...
Remote unit slides open but cant find battery cover-model AR-DL10
When sliding the bottom part of the remote down, you have to lift it slightly (I did this with a letter opener - very carefully) to pry the door up from two stops that normally prevent the dorr from sliding down too far. If you look carefully, you can see what I mean.
Feb 04, 2009 | Fujitsu 24C1 Air Conditioner
Slider Prob
Dang, what a weird design. The lens needs to go threw a cycle before it can reach the idle position where it waits for a comand from the user. If its in the closed position and you turn it on it extends to its full range then stops at the idle position. It sounds like it is stuck in some spot between close and idle. Since it cant reach the closed position or idle its shutting down. The only way to get it to work is to try and free the lens so it can cycle threw. There must be a lip on the slider and the lens is stuck on this lip so you cant slide it. Remove the batteries then try and slide the door open try and slide somthing between the lens and the door to free it up. This is the only way to get it threw the cycle. It may need to be serviced It sounds like the switch for the slider door is warn or has broken. It may work again if you can free the lens.
Aug 31, 2005 | Canon PowerShot S30 Digital Camera
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
