Question about Polaris 2004 EDGE Touring 340
I have a polaris 340 edge touring it cuts out on 1 cylinder idiling and when it slows down on grades and in deep snow
It dies out and seems to have a problem picking up speed if you keep it going fast on flat ground it seems fine
    Top Expert:
  • Polaris Master
  • 2,044 Answers
I believe you are going to find out that your PTO Cylinder has lost compression and when it gets under load, it is not able to function properly. Do a Compression Test and you will find that the PTO Cylinder is going to be well below 90 and your Recoil is going to be right around 110-120. The Repair is not difficult and only takes 4 hours when you get rings installed. I would also recommend that you purchase a new piston with rings, normally you are going to see Piston Slap on the Walls that will prolong the life of the Engine if you do it right the first time.
Posted on Feb 12, 2014
Testimonial: "my pto side is down to 100 . would that be enough to cause a problem thanks"
  • Todd Arndt
    Todd Arndt Feb 13, 2014
    What is the Compression of the Recoil Pistion? If there is more than a 10 PSI difference then absolutely, The Compression probably gets worse as you heat it up..
2002 Polaris classic touring 500 how does fuel get from tank to carbs
please refer this manual to have deep understanding http://polaris-snowmobile.brssm.com/
Dec 27, 2016 | ATVs
Torque specs
PDF]Engines - Vintage Snow
www.vintagesnow.com/Polaris_files/85%20engines.pdf
ENGINES. Engine Specifications. 1985 . .... Torque Specifications . .... Indy Sport. EC34-2PM-03. 339. 62. Indy Trail (All). EC50PM-01/02. 488. 72 .... 1989 Models ......Polaris snowmobiles are equipped with dependable, high-performance two.
Jan 13, 2016 | Winter Sports
Why would my Polaris snowmobile overheat?
My sled overheated - HCS Snowmobile Forums
www.hardcoresledder.com > ... > Rush/Switchback (Pro-Ride Chassis)
Jan 6, 2013 - 12 posts - ‎3 authors
Hey guys, I was out riding my sled yesterday, and out of no where, it threw a code, and it went into limp ... I would be worried about where did the coolant go? ... (Knowledge + results / corrected HP)Polaris + Als input = WGAF ... overheating
Feb 23, 2013
05 Polaris Switchback 800 overheated
Dec 23, 2010
Overheating...
Dec 23, 2008
2001 xc 600 overheating
Nov 29, 2006
More results from www.hardcoresledder.com
02 800 rmk overheating - Snowmobile Forum: Your #1 Snowmobile Forum
www.snowmobileforum.com/polaris-snowmobiles/67778-02-800-rmk-o...
Mar 4, 2012 - Does anyone know where I can get free service manuals for my sled so ... for a 05 polaris edge touring but i have used it to fix my 02 edge 600. Edge 600 overheating
Jan 2, 2013
Snowmobile Overheat Problem :( F8 LXR
Jan 16, 2012
2000 touring 600 overheating
Jan 13, 2011
need help with overheating issue
Nov 20, 2005
More results from www.snowmobileforum.com
800 Pro RMK, overheating, coolers... a
Jan 01, 2016 | Winter Sports
Polaris troubleshoot
If I was a betting man, you should do a compression Test on your Engine. What you are going to find is the PTO Cylinder has a lower compression than the Cylinder on the Right. Doing a Top End Repair on your Sled will only take 4 hours to do correctly. You can do RINGS ONLY but you may want to replace the Piston if the SKIRT has marred the Cylinder Walls to ensure a longer life. It is also recommended that you make sure your Oil Injectors are not clogged and functioning correctly.
Feb 11, 2014 | Polaris 2004 EDGE Touring 340
What different types of cross-country skis are there?
there are two types
1. general touring skis -these are for track skiing. They are long, narrow, and light compared to metal-edge skis, making them more efficient and very fast. This makes them better to use for the groomed trails.
2. metal-edge skis -for skiing out-of-track or on steeper terrain. They are heavier than touring skis and have metal edges to grip the snow and ice. The edges also help with turning on steep slopes. They are meant for deep snow and icy terrain. They are wider in order to be more stable.
Feb 27, 2013 | Winter Sports
2000 Polaris Xplorer 400 4x4 when going through water or mud (About ancle deep) The motor bogs down and it seems as if it wants to die.... any ideas???
see if you have a hose-clamp on your clutch exhaust it may have come off. if it did your motor WILL bogg down until the water is either run out or drains out.Also check your belt cover(when your on the seat its the big black cover on the left side.if there is a hole in it or the gasket is not sealed it will take in water.
Harley
1997POLARIS Xplorer 300
Gorilla lift with Silverback tires
Warn winch SNORKEL
Happy trails!!!!!!!!!!
May 05, 2010 | Polaris ATV
Polaris 2004 EDGE Touring 340 Logo
376 people viewed this question
Top Polaris Winter Sports Experts
Larry Fostano
Larry Fostano
toddgilbert
toddgilbert
Todd Arndt
Todd Arndt
Are you a Polaris Winter Sport Expert? Answer questions, earn points and help others
