Question about LG WM-2277HW Front Load Washer
LG diagnostic code INC2 - LG WM-2277HW Front Load Washer
LG ERROR CODE ID56 AND IU 10
to better help you with these error codes from your LG washer what model is this washer?
Aug 22, 2016 | LG Washing Machines
I have an lg front loading an it showing pe signal
the PE error code is a power error code normally happens when there is a power failure you can turn the washer off then back on (not unplugging it) and this will clear the error code however if it happens with out any other reason then there maybe a power problem inside the diagnostic computer in the washing machine
Aug 05, 2016 | LG Washing Machines
My LG LDE3777W dryer comes up with the code U01 18:F1 what is that and how do I fix it?
The service manual states several reasons why this could be happening. You can find the manual and download by clicking=> HERE I am here should you have questions. Diagnostic test begins on page 20
APPLIANCE 911
Nov 22, 2015 | LG Dryers
LG washer IF82 code. What does it mean? This is a washer not a dryer.
LE error is hall sensor is bad or bearing not letting motor turn
Aug 05, 2014 | LG WFT1071TP Top Load Washer
Lg washer fills, starts to wash but stops
have you checked brushes on motor
Jan 27, 2014 | LG Washing Machines
Kenmore elite error codes
There is a tech sheet inside the control panel o r in the owners manual that will give you the instructions on running the diagnostic program. Run the diagnostic program and it will tell you what the problem is and what tests are needed to accurately diagnose and fix the problem.This is unbalanced load code... many similar models were recalled by LG (LG manufactured this unit for Sears) due to a programming issue that interfered with normal operation... this may be the case for yours... Post your diagnostic results... if tech diagnostic sheet is not available then google it with your model number and download the instruction sheet or call lg and they will do a diagnostic test over the phone and or walk you th rough the process... its very simple. Take care
Dec 30, 2013 | Washing Machines
Htc inc2 will not play youtube video
HTC can support the videos which are MP4 and 3GP.
youtube videos are FLV ones.
So you need to convert FLV files to MP4 or 3GP. Then i use this one to deal with that. you can take a look for this Free FLV Video Converter.
Jun 04, 2012 | Motorola Mobility Droid (2 GB) Cell Phone
How to acces the diagnostic code an a new lg tromm washer
The codes should be in the manual
au.lge.com
Go to this site and download the pdf file for your
model
Jun 13, 2009 | LG WM2688HWM TROMM SteamWasher
LG WM-2277HW Front Load Washer Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
