Question about New Balance Nx990 Gps Trainer Heart Rate Monitor, Black
My NX990 gps trainer stops receiving data from the heart rate monitor during exercise sessions. What can I do?
The heart rate monitor works on start but in custom (weight lifting and x-c skiing) workout modes, it stops receiving a heart rate until I stop and then start the session again. It (mostly) works in running mode. I've only had a couple of short outages here. Is this something with the monitor, setting or transmitter?
Garmin 205 and heart rate monitor
What is the problem?
If you are looking for a heart rate monitor, one can be found here.
http://www.gpscity.com/garmin-heart-rate-monitor-with-soft-strap.html
Jan 05, 2012 | Garmin Forerunner 205 Gps Training Watch
I'm trying to find the owners manual to download for the SE332. Where can I find it online?
The manual and quick-start guides for the Gaiam Fitness Trainer 2.0, SE332, are both available as PDFs from the Oregon Scientific site: http://us.oregonscientific.com/cat-Sports-and-Health-sub-Heart-Rate-Monitors-prod-Gaiam-Fitness-Trainer-2.0.html . Click on the Manuals tab.
I hope this helps.
Feb 25, 2011 | Oregon Scientific Watches
The battery was flat. renewed it and all working EXCEPT it no longer can pick up heart rate from monitor (tried it with another monitor and still will not pick up heart beat) Help Please...about...
i guess stopped of use your strap for a long period of time. so you need to nicely clean the strap and try a lot of times until it work again.
I happend to me before and the strap worked only after the 10th session on the treadmill
Feb 11, 2011 | Polar FT60 Heart Rate Monitor (Purple)...
It appears my F6 monitor is not keeping accurant time on calories and heart rate. I like the watch but while checking my sitting heart rate is very low. When checking the heart rate on a blood pressure...
First you need to understand that the Polar system is a medical grade device and it is calculating calories based on specific information that you have inputed and heart rate data from your heart.
Most treadmills and other exercise machines use a much simpler counter that is height and weight based to calculate calories and are generally over generous with their numbers.
Depending on the blood pressure machine you are using, the pulse (not heart rate) is coming through the brachial artery, again not quite as accurate as measuring r-r variance from your heart. There is a ton of literature you can read if you are into the accurateness of the system, but I will sum up with saying that you actual calorie expenditure will be closer on the Polar than on most other devices outside of a hospital. As too the heart rate this is also true, so more likely you are getting inaccurate numbers from the other devices.
If you want pinpoint accuracy then you will need to use the Polar RS800 or S810 devices that measure and display true R-R.
Jan 12, 2011 | Polar F6 Wrist Watch
How do i reset the Timex Zone Trainer Digital Heart Rate Monitor Watch T5J983 for each workout?
There are two ways to find the user manual for your Timex watch.
  1. Find your watch on the list below and click on the language link for your manual.
  2. Find the 3-digit module number located on the caseback of most Timex products and click on the corresponding language link for that number in the Module Table.
If you are still unable to locate your user manual, you may emailTimex Customer Service or call us toll-free at 1-800-448-4639.
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Nov 18, 2010 | Timex T5J983 Zone Trainer Digital Heart...
Manual of Timex Zone Heart Rate Monitor watch . Model T5H881F5
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals. Rate me, please .
Apr 14, 2010 | Timex T5J983 Zone Trainer Digital Heart...
I can't find a manual online for my model and I am trying to pair my heart rate monitor. Timex T5J983
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Dec 14, 2009 | Timex T5J983 Zone Trainer Digital Heart...
I have a mio euorfit heart monitor watch. During my workout I
Yes, you definetely need battery replacement.
As the hart rate monitoring is most sophisticated part of the device, it has more IC (Integrated Circuits) than any other features.
More IC's means more power is needed, so, if the heart rate monitor is starting to malfunction, that's the very first sign of underpowered battery.
Find your nearest watch repair shop and ask for battery replacement.
Do not forget to rate, please.
Jan 23, 2009 | Mitac Mio Fit Heart Rate Watch
Polar F6
It sounds like most of you have the heart rate set to display in % of max heart rate. Most Polar products have the option of heart rate in BPM(beats per minute) or percentage of max.
If you look at the display during the exercise, you will see a % icon. You can turn it off in by hitting the back button and go down to HR view settings.
Hope this helps.
Chris @ Polar USA
Aug 02, 2008 | Polar F6 Wrist Watch
F6 problems
I just purchased one as well and may be returning it, I don't believe it has a stop watch, which is incredible at this price point as it's a pretty basic feature.
Jun 27, 2008 | Polar F6 Wrist Watch
New Balance Nx990 Gps Trainer Heart Rate Monitor, Black Logo
23 people viewed this question
Top New Balance Watches Experts
Ansel Alberto
Ansel Alberto
Are you a New Balance Watch Expert? Answer questions, earn points and help others
