How to remove agiator on a clothes washer
Told to pull up on it , I have and pecked it with a rubber mallet no luck
  • 4 Answers
Gentle Annie : remove the Softener unit in the center, it just pulls out , look into the center to see if there is a large Wing nut at the bottom , if there is reach down & unscrew the nut anticlockwise , then the center agitator should lift up. Some one said to use White vinagar to clean of old soap residue but I have never used it for that .
Posted on Feb 11, 2014
5 Suggested Answers
  • 686 Answers
SOURCE: roper washer will not agitate
could be the transmission or the drive motor to transmission coupling. You say the agitator doesn't work but it washes fine please clarify your problem.
Posted on Apr 04, 2009
  • 1937 Answers
SOURCE: trying to remove agiator, flat across thae top -
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Also see the following illustrated description of how to remove agitator(s)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=329f760a99d92f01a1ba376753d0d4fc
Some washers use a 1/2" plastic nut to hold the agitator in place.
I've found that using a 1/2" extension for a socket set works very well.
Posted on Dec 07, 2009
  • 66 Answers
SOURCE: washer will not agiatate, makes funny noise, will not spin
transmission sounds like its gone bad, will it spin, if it does it mite be ur timer
Posted on May 22, 2010
blueextc3221
  • 15935 Answers
SOURCE: I have a kenmore portable
This advice is for a washer that fills and will not shut off, resulting in an overflow. Or, water is leaking from the washer while filling. The symptoms can apply to either a TOP LOADER or FRONT LOADER washer. This may be able to save you from an expensive service call by making these simple visual checks.
Water Does Not Shut Off and Overflows: The water level in a washer is controlled by the Pressure Switch. The switch is usually cylindrical in shape and has an electrical connection and an air hose attached. In many cases, the small air hose comes loose from the Pressure Switch fitting and/or falls off. This air hose is required to detect the air pressure from the wash tub as tub fills. With no air pressure, the switch will not function and the result will be a wash tub that fills continuously to the point of overflowing. The same would be true, if the air hose has any cracks, splits or holes in it.
Water Leaking While Filling: The other end of this hose runs to the air dome fitting on the side of the wash tub. If the lower end of the hose comes off, the water will begin to spill onto the floor under the washer, but the tub will not fill.
What to Look For: Check for the obvious. Make sure the air hose is still attached to the pressure switch and air dome. Then, inspect the entire length of the hose, paying particular attention to areas where chaffing may occur and at the points where the hose connects to the pressure switch and air dome. Vibrations from the washer can cause some wear if the hose is rubbing against anything, and the ends of the hose can stretch over time and not seal properly.
On most top loaders the Pressure Switch is located inside the operator console behind the knob that controls the water level. This knob is commonly referred to as the “Load Level”, “Load Size” or “Water Level”. On front loader washers the pressure switch location is usually located in the back of the washer behind the wash tub, or along the interior cabinet wall adjacent to the wash tub.
How to Correct: If the hose has slipped off, cut about ½” off the end of the hose and reattach to the pressure switch and/or air dome fitting. Take a small zip tie and place it around the hose at the point where it connects to the fitting. DO NOT over tighten as this can damage the air hose fitting. Just make the zip tie snug enough to keep the air hose from sliding off. If the hose has any cracks or holes, you can attempt to seal them by using electrical tape. Replacement tubing can be purchased at any hardware store.
NOTE: This is not an all inclusive fix, as the Pressure Switch can fail in some cases and cause similar symptoms. This is merely a preliminary check for a common occurrence that I have discovered. It can give symptoms of a major problem, resulting in a call for a repairman, only to turn out to be a simple fix that any Do-It-Yourselfer should be able to check and correct themselves. I hope this information is found to be helpful and saves many of you a future service call.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
Cannot remove basket
Hit the mast with a rubber mallet. The caked on soap acts as a glue. The mallet breaks that bond.
Apr 17, 2014 | Whirlpool WTW5600XW Cabrio HE Washer
My problem is the agiator tears my clothes what is wrong this does not happen everytime just sometime and ravels towels?
Perhaps you need to remove the agitator and look under it for objects that do not belong.
In the past I have found items of clothing and such.
Cabrio service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 29, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
How hard is to change front bearings and special tools??
No special tools, not hard, get the parts, rubber gloves, can of grease, and a couple hours time, turn off the cell fone. Pull the wheel, remove dust cover, pull cotter pin, remove brake caliper, hang from wire, remove nut on spindle, bump rotor with rubber mallet, the bearings should pop out, pull the hub off, knock out the inner seal and bearings, replace with new bearing packed with grease, replace seal, put hub back on, put on outer bearing, packed with grease, washer, nut, tighten up snug by hand, then back off so wheel spins free and doesn't rock, put in cotter pin, dust cover, caliper, tighten up, your all set. Too tight will burn up bearings, too loose and you will hear it rocking back and forth. Hope this helps.
May 03, 2010 | 1996 Ford Windstar
The washer aggitator is very lose . moves up and down about 1-2 ins.
If there is a bolt to loosen under the dispenser remove it and see if you can pull up the entire agiator. If so, the drive hub is the problem and needs replacement.
May 03, 2010 | GE WVSR1060A Top Load Washer
Trying to remove agiator, flat across thae top -
Dec 07, 2009 | Kenmore 24032\24036 Top Load Washer
How do you rmove rear brake drum 2004 frontier 4x4
Hope this helps.
Good luck,
Removal & Installation
  1. Remove the hub cap and loosen the lug nuts.
  2. Raise the rear of the vehicle and support it on jackstands.
  3. Remove the lug nuts, tire and wheel.
  4. Release the parking brake.
  5. Pull the brake drum from the hub. If difficult to remove try the following:
    1. Strike the face of the drum with a plastic or rubber mallet. This will break free any rust that may develop between the drum and the hub.
    2. Install 2, M8x1.25mm bolts into the holes in the drum and gradually tighten them to pull the drum off the hub.
  6. 0900c152801a5f72.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Install and tighten 2 bolts to remove a stubborn brake drum
To install:
  1. Install the brake drum to the hub.
  2. Install the wheel.
  3. Remove the jackstands and lower the vehicle.
  4. Road-test the vehicle to ensure that the brakes are working properly.
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Drain the brake fluid, as necessary.
  3. Release the parking brake.
  4. Raise the vehicle and support safely.
  5. Remove the tire and wheel assembly.
  6. Pull the brake drum from the hub. If difficult to remove try the following:
Oct 23, 2009 | 2004 Nissan Frontier
Maytag Preforma washing machine won't drain water
The drain line is probably clogged. Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. In this case it may then get into the drain hose that's attached to the pump.Remove the hoses from the pump and pull the item out. In case it clean there, check the outer tub port- open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port.
Good luck !
Sep 12, 2009 | Washing Machines
The water continuously drains and the tub won't fill up
Good luck !
Sep 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Roper washer will not agitate
Jan 12, 2009 | Roper RAS8445KQ Top Load Washer
Drum is stuck
Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub. Open washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port. keep a rag nearby to dry up spillage of water when removing the rubber host. Good luck !!
Jul 01, 2006 | AEG Lavamat W1050 Front Load Washer
Washing Machines Logo
76 people viewed this question
Top Washing Machines Experts
