Question about Sirius Satellite Radio Receiver
All stations have dropped off
Started losing stations over the past several days now no stations are available it's a built in siruis radio in a subaru
Problem with my audio system radio
I think you are on the right lines of looking at the aerial! Either the aerial is faulty or the connection to the radio! Check the connection first!
Feb 21, 2015 | Mazda Cars & Trucks
How to turn radio on dell laptop?
There isn't an FM radio built into this unit. So maybe you are trying to get internet connected radio stations to play perhaps?
You can do a search for a program called a "radio Aggregator" which allows you to receive radio stations form all over the world. or you can just go to your favourite radio station an see if the stream live music over the web.
This is a radio station in England that I listen to via the internet from time to time, but most big radio stations stream these days.
BBC Radio 1
Jun 23, 2014 | Toshiba Satellite A135-S2276 Notebook
My three-year-old Model One has started making very loud popping/cracking noises intermittently on the FM band. It can work fine for several minutes, even half an hour or so, but invariably the noises...
I found in some cases that the tuning capacitor collects small particles of dust causing snaps, pops, and drop outs. One solution is get some electronic cleaning spray from radio shack or service shop. now open the back of the radio, look for square plastic box it is transparent and you will see metal plates with small screws. On the top you will see small round holes in the plastic, attach the supplied straw and spray inside two good blasts should do it. rotate the tuning several times back and forth this cleans the plates, until spray dries the station will be on wrong frequency until dries
Jan 07, 2011 | Tivoli Model One
How to reset engine check light for loose gas filler cap
Just disconnect the NEG battery terminal for 10 minutes and the Code should clear. Or you can get a free scan at Autozone or Oreillys and they will use their scanner to clear your computer.
The advantage with the scanner is you will not lose radio station Presets or security codes.
Sep 13, 2010 | 2005 Chevrolet Equinox
Phone appears to lose power entirely, though fully charged
The radio drains the battery as it has to activate a receiver and power up the audio sound.This quite normal here.If it was lasting more before then you may also consider changing the battery.
Aug 25, 2009 | Nokia 3600 slide Cellular Phone
My 2000 Toyota Solara radio has started to lose a strong signal.
Check mounting surfaces at antenna. Corrosion or looseness and the antenna loses its ground to the body.
Oct 27, 2017 | 2000 Toyota Camry Solara
Modulation with my linear
the radio you are trying to fry your amp with is driving the amp to hard. that radio has a toshiba 80 watt final inside the radio you are killing your radio with the dead key at 2 watts it causes the final to overheat and shut down because it is not built to be turned down that much. its best to turn the radio back up and use the radio.
Mar 07, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
Changed car battery & Kenwood execolon kdc-X592 AUX is gone
Try pressing 'menu', scroll to "built in aux", and toggle to the 'on' position. Then the aux input should be available again. The radio losing power would have reset any internal memory causing it to go back to factory defalts. Hope this helps
Dec 03, 2008 | Kenwood Excelon KDC-X592 Car CD/ MP3...
Sirius Satellite Radio Receiver Logo
Top Sirius Audio Players & Recorders Experts
John
John
Steve
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
