Question about HP Workstation Xw8000 PC Desktop
Xw8000 add in card
I want to change the hard drive from an add in card to ide
  • 1 more comment
  • Mark Mc Feb 11, 2014
    Hi dghoul005, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    What type of add-in card are you referring to (scsi, sata)? Do you want to install an IDE hard drive and move the data? What are you trying to do? What is the problem you are trying to solve?
  • dghoul005 Feb 12, 2014
    add in card is a scsi and i want to use the ide hard drive
    when i go to bios it say for the hard drive add in card so how do i make it an ide hard drive
  • 4 Answers
You are a bunch of jackasses!! No help at all with my problem!
I am outa here!!
Posted on Feb 12, 2014
  • Mark Mc Feb 13, 2014
    No need to be mean, Please provide more detailed information on what you are trying to do.
    Sergeant:
  • 274 Answers
This system should already have a built-in IDE controller on the motherboard. Simply connect your IDE drive to the primary IDE connector on the motherboard. You may need to adjust the bios to turn on IDE if its disabled.
If the CD/DVD Rom is also SCSI, you should replace that too with IDE, then remove the SCSI card.
When I open Dell 24000 I get an error sign primary drive 0 not found It tells me to hit f2-- but when I do I get no response. A colleague told me it was a loose cable so i have opened the tower but I do...
the hard drive IDE cables are flat, ribbon cables, usually grey and about 3 inches wide. do not confuse this with the floppy drive cable, which will look identical, except that it is 2 inches wide.
the cable could be loose on either the motherboard IDE controller end or the hard drive end, so wiggle it in tighter, or unplug and then re-plug it at both ends, and then try to boot. if that does not work, then replace the cable.
if a new cable does not fix it, then the hard drive itself may have failed. install the hard drive in a DIFFERENT working computer as a secondary (slave drive) by installing it to the middle connector of the IDE cable (IDE cables have a connector for the "master" or only drive at the end, and a plug for a "slave" drive in the middle of the cable), and see if you can access it. it will probably show up as the "E" drive under "computer" or "my computer". if it does not show up, check and see if it shows up under "administrative tools>computer management>disk management". if the drive is not showing up, then it is dead. if the drive works in the second computer, then the IDE CONTROLLER is the culprit.
if the motherboard's integrated IDE controller is dead, you may want to try the OTHER IDE controller socket. most computers from that era have 2 IDE controller sockets, and usually attach the hard drive(s) to one, and the cd/dvd rom(s) to the other. since the hard drive cables have plugs for 2 devices, you can attach both the hard drive and a single cd/dvd drive to the 2nd ide controller socket, in cases where the 1st ide controller soocet no longer works. attach the hard drive to the end of the IDE cable, and the cd/dvd drive to the middle of the IDE cable, as the "master" or boot device should always be attached to the end of the IDE cable.
you can also purchase an add-in, pci card ATA/IDE controller card, and use this instead of the motherboard's integrated IDE controller sockets.
Nov 06, 2010 | Computers & Internet
SUPER X5DPA-GG mainboard doesn't find connected ide hard drive. All bios and mainboard drivers are current. Board finds cd-rom in ide 1 and 2 but wont read any hard drives. IS THE MAINBOARD FRIED. IDE...
Never put the CD on IDE 1
The IDE hard drive should always be alone on the first IDE channel.
CD-ROM drives can slow down the transfer rates and cause other screwups, and so they should always be on IDE2 or as high as possible (Add in Cards)
Sep 05, 2010 | SuperMicro X5DPA-GG (672042882748)...
Sata power supply with ide only mother board?
If all the motherboard has is IDE connectors,then you can with an add in card. To do this you need to run the installation floppy during a fresh windows installation when it prompts for 3rd party scsi or raid drivers. I'd take the easy road & install a slave drive on the IDE or run an external hard drive in a usb port. Or the ultimate option,build a system using a board with sata on it. Prices are way down on hardware in general,but it's not going to stay that way.
May 14, 2010 | Computers & Internet
Ide controller for dell inspiron 2500 laptop
Any 20GB disk-drive has built-in drive-electronics,
which interface with the IDE hardware on the motherboard of the laptop -- typically, laptops do *NOT* have "plug-in" adapters for such "basic" functions, unlike desktops, where you can change video/audio/network hardware via add-in cards.
You probably can use any disk-drive that is _smaller_ than 32GB -- disks larger than 32GB require newer motherboards, due to the larger capacity of those disks.
Dec 11, 2009 | Computers & Internet
Want to connect a new samsung hard disk to computer
There are two main types of interface for disk drives in personal computers. If you give us the model numbers from the drives we can tell you for sure.
The older style drives are called IDE. They normally have a flat ribbon cable with 40/80 wires. This is probably what the 40GB uses. If your 160GB drive uses a different interface it may be a SATA interface this uses a small plug with only 3 or 4 wires. These are used in modern desktops. You can't get an adapter to simply change from one to the other. But you may find that your CD/DVD Rom uses an IDE interface and you can share the cable with two devices (if so ask here for tips on sharing a cable). You may also find an unusd IDE port on your motherboard.
If there are no IDE (40pin) interfaces to be found you can get a add on interface card that will let you run ide devices. Common cards will go into a 32 bit PCI slot on your motherboard. You will need to make sure you have a spare slot of the right type before you buy an interface card. You can get these on ebay fairly cheaply.
I have made quite a few asumptions here. Post some more information about your motherboard and the the drives you have and we can confirm things for you.
Jul 21, 2009 | Computers & Internet
945GCT-M/1333 recognize Primary IDE Master as IDE 3 Master
Start by simplifying the configuration. Disconnect the second IDE cable from the motherboard and disconnect the power to the DVD drive. Disconnect the SATA device. On the #1 IDE cable, connect the master drive to the connection on the end of the cable. Connect the Slave drive to the middle connection on the cable. Start the computer and press the key indicated to enter setup. Verify that drives are properly indentified as master and slave. If they are, shutdown the computer. Now add the IDE DVD drive to the end connection on IDE cable #2. It should be set as a Master drive. Start the PC again and go into setupand verify that the DVD is IDE #2 Master. Shut down the PC. Add the SATA device and start eh PC again. Go into Setup to verify that all of the drives are properly identifed. Restart the computer and let it boot into Windows. Open Windows Explorer to view the drive settings. If the drives are all present, but the letters are not what you want, click on START and then right click on MY COMPUTER and then left click on MANAGE. Under Storage click on DISK MANAGEMEN. The drives will all be displayed with their assisgned letters. If you need to change a drive letter, right click on the drive you want to change and select 'Change drive letter . . .'. Change it to a hight letter in the alphabet, then change the dive you want in the original postion to the now vacant letter. Finally change the original drive to the first available letter. Example: C:=IDE M1 D: E:=IDE S1 Change D: to H: then E: to D: and finally H: to E: they drives would then be: C:=IDE M1 D:=IDE S1 E:=IDE M2(DVD). Restart the PC and the drive should come up as you want them to be labled.
Good luck and please let me know how it works ouot for you.
Feb 26, 2009 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Installing a 2 port ATA-133 IDE adapter card to a desktop w/a hard drive & DVD
I don't think you can boot off of the ATA-133 so you will have to boot off of the IDE on the mobo and have the DVD drive jumpered cable select on the 2nd IDE. Boot that way to make sure the system boots. Shut down. Then instll the ATA-133 adapter with NO DRIVES on it and boot. The system should ask you for drivers for the new hardware. Intall the drivers. Shut down. Attach the new drives to the ATA-133. Reboot. You still might have to go into admin in windows and assign drive letters to the new drives. Anyway, if you are trying to boot off of a drive on the ATA-133 adapter, I don't think you can do it. I have mostly used Asus boards with Award Bios and there was no way to point the boot process to an add-on ATA Controller.
Jan 12, 2008 | Promise Ultra133 TX2 ATA Controller
HP Workstation Xw8000 PC Desktop Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
