Question about Honda Electrical Supplies
How do i remove the starter on a Honda ES6500 generator
Need to remove/replace 12v starter on ES6500 generator - how to do this?
    Problem Solver:
  • 8 Answers
Remove ground wire from battery post. Make sure unit is off too. Remove start wire and cable from starter and both bolts. Reinstall in reverse order.
Posted on May 25, 2014
5 Suggested Answers
  • 76 Answers
SOURCE: I am need of a starter for a Honda RV generator EV
ELECTRIC START WILL BE MOUNTED BETWEEN THE POWER UNIT AND THE GAS MOTOR IF YOU TAKE THE OUTER COVERS OFF YOU SHOULD BE ABLE TO SEE IT IT WILL LOOK LIKE A MINI CAR STARTER IF YOU NEED MORE HELP I MAY BE ABLE TO GET SCHEMATICS FOR YOU BUT I WOULD NEED MOTOR INFO MODEL BRAND SERIAL #S AND FROM THE POWER UNIT ALSO
Posted on Jun 24, 2009
spekgt
  • 60 Answers
SOURCE: My Honda ES6500 watt generator keeps blowing 15 amp fuse
Hi there .
In my opinion you should remove the starter and check the starter first . After you remove the starter get a good 12v battery and 2 wires and test the starter . Make sure to not invert polarity . After you touch the wires on the contactor (small solenoid on the side) see if the overrunnig (part with gears) comes out easy and with no obstruction . If the overrunning does not come out you could have a bad contactor (part # 31204-ZA0-003) or a bad starter (part # 31200-ZA0-701) .
Hope this help
Posted on Sep 02, 2009
GeneratorDan
  • 44 Answers
SOURCE: I need a repair manual
Try ebay thats were i go to find a hard to find manual. Hang onto that generator those es 6500 s are hard to come by . Hope this info helps
Posted on Nov 07, 2010
  • 223 Answers
SOURCE: Upon replacing old battery, I accidently got the
Your charging regulator has failed. The reverse voltage caused one or more diodes to fail shorted, and this short is blowing the fuse.
lp
Posted on Jan 08, 2011
Why is there gas in crankcase
Hello Ricky, I would check the carburetor needle valve and seat along with the carburetor float. You could get lucky and just need to clean the crud out of the carburetor float bowl.
Nov 04, 2015 | Honda Es 6500 Gas Generator Electric Start...
Does anyone know how to clear error codes for a honda es6500 generator
Depending on generator the error code is a wrong set governor, or a GFI on the electric side of unit. Push the reset button on the GFI an that should clear it. If not you will need a dealer.
Jan 27, 2015 | Honda Cars & Trucks
Honda es6500 won't start has fire,compression , gas, not voltage at carb, oil light on then goes out when cranking
If you run 12volts to the carb, will it run? I assume since it has no power at carb as you stated, that it has a fuel shut off at carb and will need voltage to activate magnet.
Apr 03, 2014 | Honda EU6500iS Inverter Generator
Have a honda em5000sx generator 1986. installed battery and pos and neg cable leads, tested and there is 12v at the solonoid and 12v to the starter when the key is turned to on. problem is the starter...
My goodness I just saw your post and I see it has been around since Dec 2010. Your post appeared after I answered a much newer post. (site operates in this manner)
Anyway if you have a 1986 generator and you have 12V DC to the starter with the key on the most likely problem is the brushes in the starter PN: 31215-ZE2-003 or 31215ZR2003
http://ssl.jackssmallengines.com/jacks-checkout/shopping-cart.aspx?CFID=179837&CFTOKEN=92541317
The only problem I have is that I do not know if this is a set or an individual brush. Use the toll free phone number on the link above to confirm quantity.
Once you have the starter removed use some 220 grit or above sand paper and clean up the copper contacts on the starter armature and lubricate the bearings.
If you do a continuity test of the armature using the copper contacts your meter leads must be exactly 180 deg from each other (opposing) to get a resistance reading.
Reading out the stator winding is a matter of reading the + lead terminal to the case.
Thanks for choosing FixYa,
Kelly
Dec 30, 2010 | Honda Mmd 5000 Watt Electric Start...
I need a repair manual for a Honda ES6500 generator, can you tell me were to find it.
Nov 01, 2010 | Honda Electrical Supplies
Hi there .
Hope this help
Aug 27, 2009 | Electrical Supplies
Electrical Supplies Logo
240 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
