Question about Whirlpool duet Washing Machines
Duet whirlpool wfw9200sq12 door reversal - duet Whirlpool Washing Machines
aborcass
  • 2651 Answers
SOURCE: Door reversal for Whirlpool Duet
there is no reversing the door on the washer. the door on the dryer can be reversed and with the execption of a few of the earlier models no kit is required(even then was just a trim kit). is switching theposition of the 2 appliances an option?? as far as wsher vibrating through house heres a new product receiving great response http://www.keshakeaway.com/servlet/StoreFront
Posted on Mar 13, 2008
  • 1073 Answers
SOURCE: whirlpool front load duet
it is very complex to replace
Posted on May 09, 2008
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool duet ht model # GHS9200LW door latch not
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
http://media.fotki.com/1_p,wkkrqtwwwgtsgwdxgtqsskgwtqkq,vi/krqsddwkbxktttdstrw/1/1303472/5961857/image48287img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
blueextc3221
  • 15935 Answers
SOURCE: whirlpool duet washer ghw9250mw1 door won't close ...
1. Unplug washer.
SOURCE: is door reversible on duet model GHW9100LW1
The way my laundry room is set up I have to have the washer door open on the right. There is not way to switch it. My w/d are stacked and the door to the laundry room is on the left; if they open to the left it will always block the door when it is open. My dryer opens to the right which is the way I want both of them.
Posted on Oct 16, 2012
To reverse the door opening do I need a kit or can it be done just so.
These units are made to have doors to open on the left or right. You just have to look at the hook up now and repeat it on the other side to reverse the door opening.
May 15, 2011 | Whirlpool 8579123A DUET DRYER DR REVERSAL...
How to change doors from right to left on Whirlpool Duet
Duet dryer doors cannot be reversed for the swing. They wil only open one way. Depending on your model of washer the newers ones will allow you to reverse the door swing without a kit. The older units require a kit to reverse the washer door.
Apr 22, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
How do I reverse the door on my Duet WED9400 dryer?
It's mechanically reversible, but requires a right-hand hinge cover plate (not included with basic purchase) in order to fit properly. The RH hinge cover is part number W10181197. The reversal instructions are supplied by whirlpool when you order the door reversal kit.
If you can't find the hinge cover or whole door reversal kit, or just don't want to buy it; you could trim the LH hing cover by hand, or leave it off and cover the hole into the interior with some tape or something
Mar 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Can the Duet doors be reversed?
The dryer door can be with the purchase of a door reversal kit but the washer door cannot be reversed.
Sep 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Can the door be reversed? ie open from left to right-----hinge on right side If so do you have instructions on how to do it?
Due to the shape of the washer door, and how it seats against the control panel, the door cannot be reversed on the Duet washer. There are no cut outs along the door opening to accommodate the door hinge screws and the door latch on opposite sides. The Duet DRYER, on the other hand, CAN be reversed. This may be an alternative configuration for you. Let me know if you want to know how to reverse the dryer door.
Jun 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have whirlpool model 9450 dryer. Is it possible to change the door opening from hinged on the right side to hinged on the left side?
It advertises the door as being reversible. Sorry I'm not sure how to accomplish this, but maybe check for an online installation manual?
Jan 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Is door reversible on duet model GHW9100LW1
The technician informed that we cannot reverse the door on the washer.
Apr 09, 2009 | Whirlpool Washing Machines
Mar 13, 2008 | Whirlpool GHW9400 Duet Washer
Whirlpool Duet Sport Washer Door Reversal
well as far as a work around goes you can go to lowes and get longer hoses and cords and swap them around the door on the washer is not reversable because of the door lock how ever the drier door is hope that helps
Jan 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
22 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
