Question about LG Televison & Video
32lc46-zc and I Dont understand how to tune i channels. I have no picture/channel,
SOURCE: Sharp LC-52D62U HDTV won't tune-in channel 21.
I finally got Sharp to repair the TV. It was under warenty but they said if the problem wasn't with the TV they were going to charge me for the service call. I told them I wanted a new TV. They sent the tech instead of a new TV. He replaced the turner card and it worked!! Now I get all the channels as well as channel 21.
Posted on Mar 01, 2008
SOURCE: Full screen view
in order to get the full HD experience you should be using HDMI cables. if you're using the white/red/yellow cables then your HD channels will not broadcast in full HD and you'll be stuck with the annoying black things around your screen
Posted on May 27, 2008
mistersony
  • 320 Answers
SOURCE: tuning problem
The tuner is bad. Could also be the video process, since the hi-def is decoded there
Posted on Oct 18, 2008
SOURCE: 37" Polaroid LCD TV No signal appears when select channel
I was having same problem, and think I got lucky and found fix.
Try unplugging the TV and waiting 30 seconds, then plug back in.
You will likely get blue screen with "No Signal".
Go to Menu, then scroll down to "Setup". Select "Factory Reset" then hit "Yes."
This did it for me. Wish you all luck.
Posted on Dec 03, 2008
SOURCE: sony trinitron kv-x2982u - how do I tune a channel in?
my sony trinitron wont turn on, its just come back from the repair shop and they had it up and running for 2 weeks. it came on breifly then went back to not turmnning on useing to remote.
Posted on Feb 09, 2009
Cannot tune tv onto new channel,76 says invalid format, can get all other channels have soundbut no picture
although channel 76 is starting transmissions on Sunday 25 feb press releases and statements from channel 7 state that channel selection and programming for sets may not be effective until Wednesday 2 march
if you have the latest digital led you beaut tv , it will still not select until 76 comes on line as there is nothing to select ( there has to be a signal transmitted for the tuner to find it)
ask the question again if you are not successful after Wednesday
Feb 27, 2016 | Televison & Video
Telefunken analogue color TV model MP-A2055VT-H to connect up digital decoder set-top box. The TV only has an RF input. no other plugs. Searched all 80 channels and I cannot find an AV channel on the...
The simplest solution would probably be the use of an RF Modulator. Feed the RF Mod with the A/V signals from the Conia CSTB12, set it to transmit on Ch 3 or 4, tune the Telefunken to either channel.
In most Telefunken TVs we have worked on, the A/V INput/OUTput would be on the SCART connectors as shown below.
To my understanding, a Conia CSTB12 as sold in Australia has a composite RCA (yellow) Video OUTput and L/R White/Red audio OUTputs. What would be needed would be a A/V signal to SCART adapter/converter.
If your Conia CSTB12 has an S-Video, then this may be used.
If your Conia CSTB12 has an HDMI, then something like this may be used.
Incidentally, should you be interested, there are comparable receivers to a Conia CSTB12 that has SCART OUTputs.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 14, 2008 | Televison & Video
Cannot get local channel 8 for NBN Central Coast.
Try my switch.digitalready.gov.au to locate the channels numbers to manually tune.
Nov 20, 2013 | LG Televison & Video
Iv tuned in a new dgital tv, but channel 1 and 2 dont tune it, programs start a 3, if u go backwards, its channel 805 i think press the remote button to analauge and u get channel 1 and 2 but not good...
If you've got a digital box from your cable provider, your tv most likely needs to be on channel 3. At that point you would use the remote that came with the digital box to change the channel. (in other words, your tv would always stay on channel 3)
Mar 09, 2011 | Televison & Video
How to tune the channels
You can tune the channel by Auto programming button in the setting area and then press Auto Scans all available channel option to tune the channel automatically, try it and still facing the problem read the manual carefully for better understanding or you can also call the online customer care available in the manual.
Kindly rate my help++ Thank you
May 09, 2010 | Philips Magnavox MT1905B 19" TV
Hi, i have a ps one i want to connect to my tv via the aerial. iv plugged it in and checked the av channels but cant find it, is there anything i need to do?
Hi, right now as your plugging it in via the aerial socket then this means you wont be using any of the input channels or source channels such as av ok.
now what you can try is when its plugged in and switched on go through the channels on the telly using the telly remote try channels you dont use such as 0 6 7 8 9 10 if after trying these you still have no picture then you need to put the telly on a channel you dont use say 0 then make sure ps is switched on with a game in then on telly remote choose menu or setup then you need to use the tv setup function to search the frequency as if you are tuning a channel in so do this till you see the game then store it onto that channel, now when ever you want to play the ps you just plug it in and put it on the channel you tuned in.
or an easier option would be to go to the well known auction site and buy a ps1 scart lead then when you plug this into your telly you just choose av1 or av2 and then you can play it without tuning the channel in so this owuld be the easiest way
let me know if you have any problems
Feb 08, 2010 | Video Game Consoles & Games
TELEVISION
Samsung tellys top level menus should have a choice of four or five sub-menus.
The one you want is that represented by a picture of a satelite dish / antenna. Dont worry if you dont get your TV via satelite, this is just the symbol they use to denote the tuning options.
Down arrow to the satelite dish sub-option and select enter. This should then give you several more options, one of which is Tuning, Select this and then select Auto Tune, then press enter and the set will completely retune itself.
If youre asking this as a result of yesterday's Freeview retune, then you may well end up with some "dummy" channels - i.e. they either have nothing at all displayed or a message telling you the channel has moved - or some of the channels have an incorrect name. I'm hoping that now the retune has happened, in the near future these dummys or errors will be fixed.
Some Samsung TV's dont have a "tuning" sub-menu but "Channel(s)". Selecting this will then give the Auto Tune option.
Oct 01, 2009 | Televison & Video
Can not get menu option for retuning
If youre asking this as a result of today's Freeview retune, then you may well end up with some "dummy" channels - i.e. they either have nothing at all displayed or a message telling you the channel has moved - or some of the channels have an incorrect name. I'm hoping that now the retune has happened, in the near future these dummys or errors will be fixed.
Sep 30, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
Problem getting cable to tune in to Daewoo TV
you need to get back origenial daewoo remote control to do the setup input & output. good luck!
Mar 02, 2008 | Daewoo DTQ-20U4SC 20" TV
Televison & Video Logo
21 people viewed this question
Computer Repairing
Computer Repairing
