Question about AKG SolidTube Professional Microphone
Problem With the Power Supply for AKG SolidTube
The fuse blows out after one time.  I replace the fuse and I can record for half an hour or more, after that, the power supply shuts down.
  • rcerratoc Feb 27, 2008
    Thank you mike
    Could the mic cause troubles even though this sounds good? If so, Could it be the Tube? I made a test replacing the fuse 125ma (the power supply keeps on for 1 minute and blows out afterward) for one 250ma (the power supply keeps on but gets hot and shut down after a hour some times less time)
  • Anonymous Jul 09, 2008
    Bought my new SolidTube in January 2008. Used it on three different days. After 10 minutes of warmup, I get no noticable sound level when singing into mic, although I can hear my voice very faintly, as if it's on another channel with the fader right down. Then....after 2, 5 10 0r 20 minutes...suddenly...there's the vocal ...!! Makes me crazy. Maybe the PSU is made by Behringer. I expect more for $1300...! Pete LeRoy Cape Town South Africa
    email: lyrixunltd@telkomsa.net if you have a solution. Thanks!
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 17 Answers
Well your obviously drawing too much current.
The other given is that it takes time. This means its a thermal problem. Temperature goes up and current goes up with it.
Look for plastic or cold solder joints. A plastic joint is dull and brittle also look for islands in the solder joint where the solder
is actually disconnected from the part.
Components like regulators also can go thermal.
Look for discoloration.
Get the unit to act up and carefully spray freeze mist at
various locations and you may agrivate it.
Problem may be in MIC and not SUPPLY.
Good Luck
Posted on Feb 27, 2008
Akg repair
spray it with contact cleaner or wd40 and work it back and forth a few times
Jul 26, 2014 | AKG SolidTube Professional Microphone
Crest audio ca4 blowing fuse
There is two possibillities to fuse blown off due to hi current flowing through fuse more than 3amp.because power supply componant like rectifying diode, filter capacitor or regulator ic ,regulator transistor shall be short circuited.
if you are tech......just remove amp. supply.from main power supply...try with another fuse........if fuse ok, fault is amp side, or if fuse blow off ...power side problem just....maximum fault comming on varistor ,diode, filter capacitor, .........
if you are not tech......... give to local authorised tech.......
Feb 04, 2018 | Crest Audio CA4 Amplifier Amplifier
When I turn on my SolidTube and let it warm up for a couple of minutes it sounds great. After like 20-30 minutes or so the volume fades. You can still hear it, but barely audible. I've tried put put in a...
I would be inclined check your +48v phantom power supply to make sure the correct voltage is coming out and to check your cable. Failing that, if you have changed the tube once I'd be inclined to contact AKG Directly via email to find a service center or get furthur advice.
Jan 16, 2011 | AKG SolidTube Professional Microphone
LaserJet 5550dtn Printer: blows mains fuse and power supply board fuse and b...
The fuse blows all time on High Voltage Poewr Supply, on HP Color Laserjet 5550dn,
May 16, 2010 | HP LaserJet 5550dtn Printer
Did i blow my speakeres in my akg 701's
Blown speakers get replaced not repaired. U may have overdriven the units.
Jun 20, 2017 | AKG K 701 Professional Headphones
My RCA DRC 8335 won't turn on, it justs keep saying "HELLO". What could be the problem? Have unpluged for more than 48 hours hoping it would reset it's self. DIDN'T. Was starting to have problems with it...
The problem is with a capacitor on the power supply that is too small and blows out. Its number c226 on the power supply, it is rated to be 16v, but that is too small. So all you have to do is go to radioshack or a store like that and get a replacement. I have fixed about ten of these systems and I found that it works best to use a 35v 470uf capacitor as the replacement. It costs about a dollar and a half. All you have to do is remove the power suply board find the capacitor number c226 and replace it with the bigger one. It is an easy fix that works great.
Sep 12, 2009 | RCA DRC8335
Lots of white noise and crackles, and intermittent problems.
check and make sure on the back of the power supply that it is set up for your local voltage(120/240)
Sep 06, 2008 | AKG SolidTube Professional Microphone
Akg mic buzzing
constant unrelenting hum?
check the fuse housing and make sure it is setup for your local voltage(120/240)
Jul 23, 2008 | AKG SolidTube Professional Microphone
Sound Problem
What are you running this mic into ?, an interface mic pre ?, a soundcard ? A console/ mixer ?
Since this is a tube mic it should have its own power source and I am assuming you plug that in when using it ? Don't use phantom power on this mic, even though it's a condenser mic, since it's a tube mic wich have their own power supply you don't need phantom power on them and in fact it may damage its power supply.
Jul 06, 2008 | AKG SolidTube Professional Microphone
AKG C535 microphones pop and hiss
if they are "condenser" mic's, the condensor module, as in the case of capacitor, failed as time goes. <condensor = capacitor>. Might be a good idea to check other capacitors inside.
pc-cook
Nov 16, 2007 | AKG C535EB Professional Microphone
AKG SolidTube Professional Microphone Logo
1,030 people viewed this question
Top AKG Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Vito Vacirca Jr.
Are you an AKG Audio Player and Recorder Expert? Answer questions, earn points and help others
