Question about FoodSaver T000-03430 Professional Iii Plus Kit Vacuum-sealing
Foodsaver troubleshooting the machine is in a locked position. when plugged in, three green lights keep flashing, but will not unlock
The progress light on the food saver is flashing red
The heater bar is too hot. Allow it to cool for a while before resuming sealing.
Oct 15, 2014 | FoodSaver Tilia 801 Food Saver Vacuum...
Foodsaver V3840 Won't vacuum air out and wont go to seal. A label states the seals are not removable. Do you know how to fix?
you are not using a "good" bag. Make sure there are no holes and that the bottom and sides of the bag are properly sealed. It will run all day and not pull the air out if the seal is broken anywhere.
Sep 11, 2014 | FoodSaver V3840 Vacuum Packaging System
My dc59 doesnt work green light flashes when you press start button
Hi there, it's Jack at Dyson.
A green light flashing when you try to use your DC59 could mean the battery has no power. If you're confident it's been allowed to charge for at least 3.5 hours, it's possible that the charger cord isn't connecting correctly with the machine itself, so no power is reaching the battery. This is more likely to occur if you're recharging the machine in the docking station, and the charger cord isn't correctly positioned.
We're happy to help you check for and resolve this - if a replacement part is needed we can also confirm if this is covered under our 2-year parts and labour guarantee. When you have your machine to hand, please give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Aug 27, 2014 | Dyson DC59 Animal Bagless Cordless Stick...
FoodSaver V3240: Lights flash,,,won't operate...what's wrong?
Pull out the long rubber piece on the top, clean any debris, replace firmly.
Aug 10, 2014 | FoodSaver V3240 Vertical Vacuum Sealer
Dc31 flashes green
Usually if the indicator light flashes green when the trigger is pulled, this means the machine needs to be charged. If you have had your machine connected to the charger assembly for over 3.5 hours and continue to see the flashing green light, this could mean the machine isn't recharging correctly.
In order for us to diagnose which part is at fault we'd need to take you through some simple diagnostic checks when you have your machine to hand. You can reach our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
Aug 03, 2014 | Dyson DC31 Bagless Handheld Vacuum
Foodsaver vacuum sealer tray full light
Clean the two little contacts on the tray. Make absolutely sure there isn't anything across the two wires that run the length of the tray. It doesn't take much to trigger the light.
Jun 03, 2014 | FoodSaver V3880 Vacuum Sealer - The Master...
Why there say tray full red light
The tape trick didn't work for me. Had to cut the wires. Works for now.
Sep 27, 2012 | FoodSaver Smart Seal Vacuum Sealer V3825
I got as vacuum sealer at a yard sale - I don't know the brand/make/model to find instructions for it.It is electric - has a cord to plug in - white - 2 lights on front - 'seal; ;vacuum' under unit is a...
I have the same machine, foodsaver BS828, and no instruction manual.i need to know how to use it properly...anyone have or know how to find a manual?
Oct 16, 2010 | Vacuums
Foodsaver
Here is the link to your foodsaver manual.
http://www.foodsaver.com/Support.aspx?id=spma&mgid=1
Sep 09, 2009 | Vacuums
Belt
Hi.
If its not all floors machine just turn the three plastic screws under the machine to unlock .
lift off sole plate remove brush roller fit new belt over brush roller then stretch belt over motor drive shaft.
Replace sole plate turn 3 screws to lock position & thats it.
If your machine has a clutch unit & is all floors type this is more harder to do & will need a lot of explaining so try this site for Dyson Service Manuals.
http://dysonmanuals.inc.io/
Chris.
Dec 02, 2007 | Dyson DC14 Animal Bagless Upright Cyclonic...
FoodSaver T000-03430 Professional Iii Plus Kit Vacuum-sealing Logo
15 people viewed this question
Top FoodSaver Vacuums Experts
Lawrence Oravetz
J.D. Browning
J.D. Browning
ray gallant
Are you a FoodSaver Vacuum Expert? Answer questions, earn points and help others
