Question about Proform 760 CrossTrainer Treadmill
While walking the track comes to a stop,when you get off it starts again
STARTS AND THEN ITS STOPS??
If the timer is set it will always stop at EXACTLY the same time.
If the motor is overheating, it will usually slow down before it stops; and the time will be a little different each time.
Congratulations, I only know one other person who has worn out a nodic track.
Feb 03, 2015 | Nordic Track Nordictrack C2200 Treadmill...
Treadmill stops but has power
the motor could be going bad or the control board.if you are able to remove the drive belt off the motor and then run it. this will determine the motor or board from the walking belt or other items being bad.the motor should not be too hot to the touch
Apr 17, 2014 | Nordic Track Exercise & Fitness
Motor stops Dead
The motor is fine, you need and new walking belt and possibly a deck.
Oct 23, 2017 | Nordic Track Treadmill Motor 215392
Belt stops while using nordic track c2255
this happen to due the lack of maintenance according the schedule manintenance. see the video and proceed.However if after you did, the problem remain,is TIME to replace the old board deck. God bless you
Mar 26, 2013 | Nordic Track NordicTrack A2350 Pro...
What lubricate do i use on my treadmill to stop the mat from gripping
The walk belt should not be "griping", Are you sure that The roller may be stopping and starting? Hard to tell with out watching with the hood off. You will need to check the front pully where it is pressed on the metal tube that is the front roller. The pully looses its grip on the metal tube, and it starts griping then slips and grips again. I believe that is what you are feeling. The repair is to repalce the front roller.
Hope this helps, let me know
Matt
Sep 23, 2011 | Nordic Track NordicTrack A2550 PRO...
My nordic track treadmill's walking belt stops when I start walking on it but the motor is still running although the front roller is not moving when I start walking on the walking belt. Do you think the...
Unplug the unit remove the motor shroud inspect the drive belt if the rubber feel slick then my recommendation is to replace the drive belt. Adjusting the drive belt may take care of the problem if you do not need to adjust it too tight. If you choose to do the adjusting and feel you have adjusted the running belt thinking it would resolve the slipping, then back the tension down until it the running belt is slipping then adjust until the slippage is resolved.
May 17, 2010 | Nordic Track Exercise & Fitness
My Nordic track 1000 runs great for about 25 minutes then the belt stops working. The display is working. I have to use the stop button and wait a minute to restart the track. Then it will only run for a...
Your drive motor is over heating. Usually caused by friction from the walk belt. The belt needs to be lubricated. (silicone only) Loosen the adjusting screws on the rear of the macine ten revolutions lift up the belt and using a spray silicone lubricant (from any big retailer) spray a light film on the deck (walk board). Retighten the adjusting bolts ten revolutions. If this does not help I would suggest replacing the walk belt.
Nov 09, 2009 | Nordic Track Exercise & Fitness
Nordictrack treadmill C2100 belk is not slipping motor stops when you step on treadmill at low speeds, step back off and it starts working
Several issues, drive belt that drives the walking belt could be loose but you should smell rubber if its slipping.
Something could be caught in the track causing extra drag, its easy to do if you have kids or pets
Check for when you last lubed the track and walking surface, with no silicone it will drag and bog at low speeds
Oct 21, 2009 | NordicTrack Exercise & Fitness
Proform 760 CrossTrainer Treadmill Logo
20 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
