Question about SharpVision XV-DW100U Multimedia Projector
Projector cuts off in 30 seconds
Projector shuts down when turned on
  • 1 more comment
  • Arthur Wilson sr
    Arthur Wilson sr Feb 11, 2014
    Hi Arthur Wilson sr, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? I changed light o
    And I put it back together and i tune it on the power goes off on it
  • Arthur Wilson sr
  • Arthur Wilson sr
    I changed the lamp and when I put it back together and turned it on the power goes off 30 seconds later and I unplugged it and pluged it back UFO and it works great
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 729 Answers
1,the lamp is good
2,it seems that the mother board is broken
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Posted on Mar 04, 2014
ASK Proxima C420 shuts down after 30 seconds. No indication of overheating or lamp problem.
Might be a problem with the video input. Try a different cable. If HDMI, you will need a really good cable for HDTV or 3D, and they are very expensive. My 12 foot cable cost $180.
Sep 12, 2014 | ASK Proxima C420 Multimedia Projector
Shut down after 30 seconds
Many projectors shut down if they cannot find anything attached to them.
Make sure you have a computer attached and sending an image out to it before you hit the projector reset button again.
It's a bit like the chicken and the egg since some laptops won't send an image out the cable unless it senses a projector, and the projector shuts down if it does not detect an incoming signal fast enough.
Apr 23, 2014 | Acer PD528W Bulb
Turned on the projector and it immediately shut down and now has no power
it seems that the lamp ballast is failing
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD
chip,color wheel,motherboard,powersupply,ballast... with high quality and
competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
lampdeng@hotma
Mar 09, 2014 | Boxlight Cinema 13HD Lamp
Epson Projector, Model: EMP-X5, Epson projector shuts down after 30 minutes work
There are several things that can cause this problem, but the first thing I would check is the filter. The projector requires airflow to keep it cool. If airflow is blocked, the projector will overheat and shut down automatically.
Jan 02, 2013 | Epson ELPLP41 EB S6 Lamp
Projector turns on for about 30 seconds then shuts down. the fan kicks up high, and led light flashes yellow for about 4 min until the fan shuts off. does not feel hot so overheating does not seem to be...
if the lamp lights and then shuts down, replace the lamp. it's at the end of it's life. to rule out overheating, blow the projector out with canned air. dust retains the heat that the projector is trying to expell. also see if all of the fans are working. if you do get an image for a short time, try to get into the menu to reset the settings to factory default. lastly, if all else fails, you have a ballast issue. unfortunately, infocus no longer sells parts for this model.
Nov 28, 2009 | InFocus LP 630 Multimedia Projector
My projector doesn't stay on. what's wrong?
either the lamp cannot strike (meaning a ballast or lamp issue) or there the fans are not up to speed to sufficientl;y cool down the lamp and therefore shut down to avoid damage.
Feb 27, 2009 | Eiki LC-XB20 Projector Multimedia...
Viewsonic PJ556d shuts down after 30-60 seconds
My solution sounds dumb, I had the same issue. Took the lamp cover off the bottom. The screws were loose holding in the lamp. Maybe they heat and expand and eventually work their way out and the lamp doesn't make good contact. Just tightened mine up, the unit would power off after 45 minutes prior. Been on now for 5 hours, no trouble.
Sep 15, 2008 | ViewSonic PJ556D DLP Projector
Infocus x1a projector shuts down after 30 seconds - dust problem ??
There is a safety themostat inside the unit (looks like a silver button the approx size of a dime) that will shut the system down if you do not have adequate airflow. You can dis-assemble the projector by removing the screws on the bottom and rear of the housing and pressing in the plastic locking tabs inside the cover all around the perimeter but I would advise against this unless you are comfortable with delicate nature of the projector.
Dec 17, 2007 | InFocus X1 Multimedia Projector
Shuts off
projector turns off after 30 seconds problem solution
Sep 16, 2007 | Sanyo PLC XU35 Multimedia Projector
SharpVision XV-DW100U Multimedia Projector Logo
41 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
