Question about Kyocera FS-C2126MFP Printer
Installed new magenta toner in Kyocera FS C2126MFP and red light flashes and display says "add toner (M)" Removed toner and installed same toner in another printer and worked o.k. what's the problem?
SOURCE: Kyocera fs-920 static red light
Your more than likely out of ink.
Posted on May 28, 2009
M2Tech1
  • 313 Answers
SOURCE: kyocera fs-1920 printer fault
if the machine is starting up and you just replaced the toner cartridge make sure it is seated properly also did you shake the cartridge slightly before fitting sometimes the cartridge can compact the toner and it doesnt agitate to the dev unit properly. check also if the dev unit has been reset properly and the lever set in place..
Posted on Jun 12, 2009
n25an
  • 622 Answers
SOURCE: Kyocera FS-3900 and FS-4000 Prints very faint. New printers affected
sounds good
Posted on Dec 24, 2009
  • 62 Answers
SOURCE: Kyocera laser printer toner refill
refill...uh oh probably wouldnt try it..there's is like only 1 company that does kyocera refill toners.....call KATUN... you can try to find that on the internet..you most likely willl have to buy actuall kyocera toner..
Posted on Feb 01, 2010
shawn38
  • 200 Answers
SOURCE: i have a Kyocera FS-2000D i've installed a new
Turn of the printer unplug and then turn back on.
Was the toner you installed a Kyocera toner or a after market toner? If it was an after market toner that could be your issue.
Posted on Mar 02, 2011
Kyocera service codes
Magenta developer unit non- install-
ing error
• The toner sensor 1 inside the magenta
developer unit did not output the den-
sity detection signal, judged the
engine controller PWB (KP-1054) the
magenta developer unit is not
installed.
You may want to leave that to a certified tech!
Aug 29, 2014 | Kyocera Office Equipment & Supplies
How kyocera laser mfpsenses toner bin and powder
toner and developer are different the developer is usaly by the drum check too see if its in the machine or installed correctly
Jul 27, 2014 | Kyocera FS-1035MFP
Get message " toner container is improperly installed."
Hi - What have you tried?
Process to check - simple but worth going back to basics
1 - Remove toner and reseat
2 - check you have removed all transport tags stickers etc
3 - Chck all arrears where a sensor could be blocked
4 - try a 2nd new toner (1st may be faulty)
4 - if there is a waste bottle or OPC drum attached to the toner itself ensure it is seated properly and fully locked into place
if none of the ablve work consult a printer repair or IT company
Jun 24, 2014 | Kyocera FS-C2126MFP Printer
How do I install a new genuine kyocera developer unit (dv-172) in a Kyocera Y FS-1320D?
1-5-4 Developing section
(1) Detaching and refitting the developing unit
Procedure
1. Open the top cover.
2. Open the front cover.
3. Remove the developing unit (with toner container).
4. Check or replace the developing unit and
refit all the removed parts.
5. When the developing unit is replaced with a
new one, carry out the following procedure.
6. Perform toner install mode in the service
mode (see page 1-3-12).
May 26, 2014 | Kyocera Office Equipment & Supplies
My Kyocera FS-C2126MFP is saying that the toner is improperly installed
NEVER use aftermarket or refilled cartridges in your printers.
Dec 05, 2013 | Office Equipment & Supplies
Developer unit not installed
yocera ecosys fs-1124mfp toner container 0r the developer unit is not install
Apr 09, 2012 | Kyocera Office Equipment & Supplies
FS 3900 "Unknow toner istall" shows in display?
The message is indicating that you do not havea real Kyocera toner installed in the machine.
Apr 04, 2011 | Kyocera Mita KYOCERA/MITA - FS-3900DN Mono...
I have a Kyocera FS-2000D i've installed a new toner kit, but the printer is stuck on saying "please wait" adding toner.
Feb 12, 2011 | Kyocera FS-2000D Laser Printer
Install MK? What does this mean?
Its because you've gone past a certain number of pages printed.
Its asking you to install a new Media Kit
To reset the message -
1 Press the MENU key.
2 Press the or key repeatedly until Life Counters > appears.
3 Press the > key.
4 Press the or key repeatedly until >New Toner Installed. appears
5 Press the ENTER key. A question mark (?) appears.
6 Press the ENTER key.
The toner counter is reset. The message display returns to Ready.
Mar 01, 2010 | Kyocera FS-3830N Laser Printer
Kyocera fS-920KX. Not printing
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem
YBC (/\)
Jun 01, 2009 | Kyocera FS-920 Laser Printer
Kyocera FS-C2126MFP Printer Logo
73 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
