PET741M/37 - BLANK SCREEN
I can hear the dvd, but can't see the it. The screen is blank. Philips Portable DVD PET741M/37
jomaru
  • 337 Answers
SOURCE: Blank Screen
The screen in your dvd might not be getting the volts it needs to work,the ribbon cable that comes from the base gets broken sometimes because of the hinge action of open and closing constanly.You need to call RCA at 877-794-7977 and ask for an estimate or an idea of how could cost to repair.Good luck.
Posted on Oct 17, 2006
SOURCE: WHITE SCREEN
Our Philips PET702/37 Portable DVD player has white screen, when i press the screen appears the image. please help me. thanks
Posted on Aug 28, 2008
I don't know if you ever got an answer or not, but we have this same unit and also had this problem. (now we have a different problem) Anyway, there is a small button on the mail base that I think is on the upper right. When the screen is closed the button is compressed, when the screen is opened it should fully pop out, but ours did not. It appeared to be, but if you pressed it in, it would fully pop out and the screen would work. Sometimes we had to do this several times during a trip. For some reason it would not stay fully popped out? We had already taken the exact same DVD player back to Target because of this same problem, only to have the second unit do the same. I bought this particular player because I assumed with the "Eddie Bauer" name it would be quality. I was mistaken. Hope you already figured this out. Sincerely, T
Posted on Sep 23, 2008
  • 4234 Answers
SOURCE: Portable dvd player, Screen is blank
The white screen is an indication that either the digital processing is defective or that the screen drivers have a problem. The more likely problem is the screen drivers. Normally the screen would be dark. If you can gain access to the inside, try reseating all of the cables and connectors. Becuase the signal levels are so low, it does not take much to interfere with the signal. Also, a poor ground on one pin can cause this too. Let us know if the reseating helps.
Thanks,
Dan
Posted on Mar 18, 2009
  • 12 Answers
SOURCE: the screen is blank and white and the sound works
maybe the set-up of your dvd is pal. try to select auto
Posted on May 07, 2009
Why the screen comes on blank
Check the user manual which is available at: http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?slg=en&scy=ie&ctn=DVD750/002
Nov 17, 2014 | Philips PET710 Portable DVD Player
Blank screen
There is a function called "Monitor Off" that may currently be activated. Please press the [LCD-SIZE] button repeatedly while playing a disc.
Mar 27, 2014 | Panasonic portable dvd player DVD-LS80...
Second screen not working for dual dvd player
see the diagram and test it:
some block inside can be defective, however tight any wires connectors inside, you must open the DVD.
if you can not do it go to the repair shopt TV for fix it
God bless you
Jul 20, 2012 | Philips Televison & Video
I have a Philips Model PET702/37 DVD player. It has constant static in the speakers, even if I have the DVD player on pause. I can't hear the person speaking on the DVD and it is VERY annoying. Can you...
It sounds like that you might have a high voltage arch or a bad connection on the audio amp board. You can take the back off and with the lights off, or in a dark room you can look for something arching.
Nov 11, 2010 | Philips PET702P/37 Portable DVD Player
Unlock a Philips portable DVD Player Pet 741/37
It worked for my Philips PET741/37:
1. Power ON the DVD player without a DISC inside
2. Press the skip keys in this order (the keys are under the "disc menu" and "stop"): right, left, right, left, right, right, left (YOU DON'T HAVE TO GO TO SETUP MENU, just do this in the "blue screen".
3. It will show a menu with region, now use the arrow keys to select "region" and change to "test 0" (all regions).
4. Press OK to confirm. Enjoy
Silmara
May 15, 2010 | Philips PET724 Portable DVD Player
Magnavox portable dvd mdp1810a - no picture
I have this player. It's sensitive to power fluctuations. If the power isn't steady, the picture goes out. You don't need to shut the lid, just quickly press the tiny plastic pin near the hinge under the screen. It does the same thing as closing and opening the lid would do. Not sure this will solve it, but I found that to help. By the way, I broke the car charger for mine and am looking to buy one. If you ditch your player, let me know.
Feb 19, 2010 | Philips Televison & Video
DVD plays and you can hear sound but the screen is blank. Any solutions?
have you tried a dvd/cd laser cleaning disk ,as the laser in the player gets dusty.you can buy these for a couple of quid from most corner shops or super markets
Jun 13, 2009 | Philips DCP851 Portable DVD Player
Blank screen no picture
connection between the dvd output and screen has broke link somewere. pull it apart and check it out
Jun 05, 2009 | Philips Magnavox DVD/VCR Dual Player
Televison & Video Logo
Top Televison & Video Experts
