Question about Frigidaire FGGF3054KF Gallery Series Freestanding Gas Range with 5 Sealed Burners, 5.0 cu. ft,, 2, 3, 4 Hours Scroll thru Self-Clean, 6 hours Timed Shut-off, 17,000 BTU Front Right Burner, 9,500 BTU Front Left Burner, 5,000 BTU Rear Right Burner, 15,000 BTU Rea
Range completely died. Oven, igniters and EOC not working
Hello, I'm really hoping someone can help me out, because I've hit a dead end. I was using my oven and all of a sudden it completely died. I've done all the standard troubleshooting: checked to make sure the outlet has power, unplugged the range for a while and plugged it back in. When I called Frigidaire, they recommended replacing the EOC. But before doing that, I opened up the back panels and began testing the connections with an Ohmmeter. What I found is that when I test for contact between the hot wire on the plug and the black wire (BK-1) on the EOC, there is no contact. Based on the Troubleshooting diagram the hot wire on the power cord (BK-4) leads to BK-1, and so there should be contact there. Does my thinking seem correct? My thought is that maybe there is an issue with the connector between BK-4 and BK-1, but unfortunately I don't see any way to get to it, without disassembling the whole range practically. It doesn't look like it's meant to be accessed. Also, I tested the neutral wire (W-4) with the Ohmmeter and all the connections on the EOC look good. W-1, P-1, T-1 and PR-1) all have contact with W-4. Does anyone have any suggestions? Thank you very much for your help in advance. Best regards, Mark
  • Mark Rosenberg
    Mark Rosenberg Mar 31, 2014
    I solved the issue. Wire BK-4 was cut due to poor design, and possibly bad installation by Frigidaire. The wires were pulled across a sharp metal corner, which wasnt curved or grommeted.
  • 4 Answers
Check the Auto Timer is on Maual .
Posted on Feb 11, 2014
Testimonial: "Hi Wayne. Thanks for the tip. In my range's manual there is no mention of an Auto Timer and how to set it on Manual. I don't think this applies to my model. Do you know of something different?"
  • Wayne Mason
    Wayne Mason Feb 13, 2014
    Sorry no, just the obvious . Call electrition ??
3 Suggested Answers
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: can i open (lift) the cooktop on a frigidaire ffgf3053ls gas range?
    Hello Frank - Since a gas range is such a complex unit and for safety and liability reasons the unit is not designed to be lift open. However you may clean the burner grates, burner caps, and the surface burner heads.
    Posted on Oct 04, 2012
    chrispolkele
    • 4342 Answers
      Verified Fixya Pro
      SOURCE: Frigidaire Gas Self Cleaning Oven door open in lock position
      Hello ericndiana6b - Was the unit in self-clean mode? Try pressing and holding the "Clear/Off" button to stop any operation of the EOC. Do this at the same time while pushing and hold the light switch to the left of the door lock. Usually this will trick the oven into unlocking the door. If it is ineffective, try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and redo the steps. If door continues to maintain locked while open, the unit may possibly have a faulty door latch or a communication problem with the EOC. Contact a professional to move forward accurately.
      Posted on Dec 12, 2012
      All 5 spark igniters not clicking
      Could be range of problems including:
      Power not connected/turned off
      Ignitor ports clogged
      Incorrect operation
      Manual is available via Google
      Aug 09, 2015 | Frigidaire Gallery FGGF3032MF 30"...
      Popping noise in oven when baking
      Hello friend, thanks for your inquiry!
      From what you have described there is a popping noise within your Frigidaire oven when it is baking. It could be some food residue left on the element or an issue with the thermostat. I would recommend checking the inside of your oven for any food residue near or on your element that could cause a noise of any sort. I hope this information is helpful to some degree. -Matt
      Mar 16, 2015 | Frigidaire FGGF3041KF Gallery 30"...
      One igniter won't fire?
      I appreciate your inquiry, Mark Waggoner!
      From what you have described one igniter on your Frigidaire range will not start. It sounds like a possible issue with the burner or igniter. I was unable to locate any steps on how to disassemble your range. I did locate a parts manual which provides a through breakdown of all the parts within your range. If you continue to have issues I would suggest contacting a technician for proper disassembly of your range. I hope this information provided is helpful. -Matt
      Frigidaire Manual Search Results
      Jan 05, 2015 | Frigidaire FGF337GB Cooking Products :...
      Bosch gas range error code F11
      Disconnect the ribbon from the control panel and clean it using pencil eraser. then carefully reconnect it.
      If the F11 is still there most likely it's the control panel.
      God bless you
      Feb 01, 2013 | Bosch Evolution 500 HGS5053UC 30"...
      Broiler shuts off
      Make sure you keep the oven door OPEN when using the broiler, otherwise the thermostat will shut it off.
      Jan 18, 2013 | Maytag Gemini MGT8655X 30" Freestanding...
      Nov 27, 2012 | Frigidaire GLGF376DQ Free-Standing Gas...
      My Remington Keratin Therapy Flat Iron Doesn't Turn On.
      see thi steps and fix it.God bless you
      If the iron doesn't heat, make sure 1) power is on to the outlet, 2) check the electrical cord and 3) check the thermostat and replace if necessary. Use the VOM.
      Oct 15, 2012 | Remington Style Therapy: Keratin Therapy...
      I have a black & Decker digital advantage iron. it is about a year old and when I plug it in it beeps and comes up with err or. Can you tell me what is wrong or what i can do
      Hi!
      I really hope someone can come up with an answer to your problem.
      Personally, I have an iron, and a toaster, and a toaster oven with the old-fashioned dial where the degrees of heat are approximately displayed.
      I had them for decades it seems, and I've never had to suffer any fallout from either ironing my shirts at plus or minus 5 degrees from the digitally recommended temperatures, nor from toast that was slightly darker one day and lighter the next.
      I'm not a caveman, just in case you wonder. I do have a microwave oven with a dial timer as the only variable, and I must say on its behalf that it has served me without a hiccup the dozen times I used it to either warm my tea, or help defrost the odd TV dinner, which ended being cooked in the toaster oven.
      In all seriousness however, needlessly digitally controlled appliances just because it's cheaper to manufacture them, don't score highly with me.
      Furthermore, these electronic circuits appear to have a predetermined and highly predictable life expectancy, and oftentimes the appliances they control are cheaper to replace than to repair.
      Feb 14, 2011 | Black & Decker Irons
      Frigidaire FGGF3054KF Gallery Series Freestanding Gas Range with 5 Sealed Burners, 5.0 cu. ft,, 2, 3, 4 Hours Scroll thru Self-Clean, 6 hours Timed Shut-off, 17,000 BTU Front Right Burner, 9,500 BTU Front Left Burner, 5,000 BTU Rear Right Burner, 15,000 BTU Rea Logo
      108 people viewed this question
      Top Frigidaire Irons Experts
      Thomas Perkins
      Thomas Perkins
      Ken Wieczorek
      Ken Wieczorek
      Are you a Frigidaire Iron Expert? Answer questions, earn points and help others
