Question about Marantz CD5001 CD Player
Hi _ I have a Marantz CD player a littl;e over 6 years old. Performed perfectly until today, when it started inserting brief gaps in the music, approx 1-2 seconds; at the same time the track / time display goes blank. Then the music & the display pops back. Not skipping forward or back so far, just the silent gaps. I know the problem is in the player, not the discs, since the gaps occur at different points during multiple plays. I have an AudioSource CD laser cleaner CD, but I don't think the Marantz will read it. The unit displays 'TOC reading' and then having found none, does not spin the disc. I may have to take the unit in, but can anyobne recommend a laser cleaning CD that the Marantz can handle? - thanks
    Genius:
  • Marantz Master
  • 1,054 Answers
Laser cleaning cd's very rarely work. the only thing they are good for is if there is a build-up of dust on the lens. Sounds like you most likely need to have the laser replaced.
Posted on Feb 13, 2014
5 Suggested Answers
satavlad
  • 405 Answers
SOURCE: My Marantz CD63SE SPECIAL EDITION CD PLAYER won't read discs
Most likely, new optical (lazer) pick up required to solve this issue.
Posted on Dec 01, 2009
  • 2976 Answers
SOURCE: 5 disc cd changer CC4000 will not read
All players need cleaned from time totime. Do NOT try to clean it with anything other than a CD / DVD lens cleaner. They are available almost everywhere that sellsBlank media. It will clean the lens without scratching or smearing it.
Posted on Dec 06, 2009
  • 99 Answers
SOURCE: My one-year old Marantz CD5001 CD player
these models use the 12.1 philips laser mechanism and it is a very common problem for failing to read discs.
various technics / marantz / philips / cyrus cd players etc also use it and are plagued with the same fault.
it's a 90% chance the laser is dead!
philips realised the unreliability of this laser and uprated it to the identical looking VAM-12.
do not dismiss the spindle motor as these also fail quite alot on this mechanism.
hope this helps.
Posted on Sep 12, 2010
  • 99 Answers
SOURCE: Marantz CD48 - CD spins backwards
Check the small signal transistors BC338 and BC328, they're under the transport mech and will be near where the spindle motor plugs in to the PCB.
One of the transistors acts as a brake which momentarily puts the motor in reverse polarity to stop the CD rotating during 'stop' or 'open tray' modes. The reason the CD is spinning backwards is that the transistor which drives the spindle motor forwards during playback is faulty and is triggering the braking transistor hence spinning backwards.
The transistors should be 'BC328-25' / 'BC338-25' (25v)
Replace these and all should be well.
Hope this helps
Posted on Sep 01, 2012
We have Marantz PMD 325 CD players. Usually TOC REading comes up when you put a CD into the player. However sometimes we now get the following message "PMA Reading", What does this mean.
Hi Wendy CD-Rs and CD-RWs have a component that ordinary music CDs do not have -- an ...This additional track space includes the power memory area (PMA) and the ... which tells the CD player what part of the disc it is reading at any particular time. ...uncorrected error on a music CD only means a bit of fuzz or a skipping noise. GOOD LUCK !
Jan 05, 2014 | Marantz SA8260 CD Player
My Marantz SA-11S1 sacd player can't read many hybrid SACDs anymore. Do you recommend lens cleaning? Help please...!
hi,
just purchase a lance cleaning cd. It will be available in cd shops. insert it in the player. it will clean the lance. after cleaning insert the hybrid SACDs and watch is it reading. If not then the laser pickup unit of you player have some problem. You have to relapse the same.
ok
Mar 08, 2011 | Marantz SA-11S1
Hi.I have CD Recorder Marantz DR6000.After reading and initalizing blank CD-R Audio next on display show OPC ERROR.It,s reading all audio CD,s,oryginal,and CD-R.When I wanna finalized old CD-R,recorded by...
DR-6000 only accepts CD-R audio or CD-R music discs, not the standard CD-R discs. the difference is that the audio and music discs have the OPC formatted differently and they cost a bit more because they include the royalties fee. Standard CD-R discs won't work in this recorder. The correct discs have compact disc "digital audio" logo on them.
Oct 01, 2010 | Marantz DR-6000 CD Player
Marantz CDR 615: Msg: ''No CD''
I've owned one for years, and yes... depending on how many discs you burn, you may need a new tray. You can call Marantz and they will ship one to you. They will also send you a diagram of how to replace it. Pretty simple.
Mar 10, 2009 | Marantz Audio Players & Recorders
hope this helps.
Dec 20, 2008 | Marantz CD5001 CD Player
Marantz cr2020 cd player
I have had this problem twice now in ten years, each time took it to get repaired at a marantz dealer and they replaced the laser. First time was about $150, second time they didn't charge me. No problems otherwise - which for an integrated item like this, where so many things can go wrong, is pretty good.
May 21, 2008 | Audio Players & Recorders
No Sound Through Speakers
Hi Jake,
If you haven't done so already, I'd try double checking the speaker wiring, you may have some exposed or badly kinked wires behind the unit.
Cheers,
Matt Coyote
Feb 20, 2008 | Car Audio & Video
Popping sounds in stereo during playback of burned cd's
Is it just the analogue inputsthat do this? Soulnds like a faulty input board.
Sep 16, 2006 | Marantz CDR631 CD Recorder
Marantz CD5001 CD Player Logo
231 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
