Question about Dell M410HD Projector Projector
Broken focus ring
Need replacement part
  • Juan Edgardo Morell
    Juan Edgardo Morell Feb 13, 2014
    Need to replace the Focus Ring. Looking for part/ reference number and price
Can i replace focusing ring on nikon 18-200 lens
Rubber focus ring can be purchased in ebay.
The rubber ring may be attached to the lens with glue. Use denature alchohol between the rubber and lens to remove the rubber ring. It can be stretched little. Once removed, clean any glue on the lens and stretch the new rubber ring and install.
Nov 01, 2012 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
When the camera is turned on and the 16-105 DT 3.5-5.6 zoom is attached there is a repeated clicking sound that continues until the camera is turned off. A sony camera salesman indicated it was the lens. ...
I had the same problem with my SAL-16105. It turned out that inside the lens the FOCUS DIFFERENTIAL RING (Artnr.: 321020202) was broken. The camera tries to move the focus from one end to the other when it is turned on (probably to check the functionality), but as the ring is broken, focus will never reach its end-point. Thus the camera continues to try to turn the mechanics futher until either the gear on the lens ring or one of the gears inside the lens will jump, making the clicking sounds. Another reason might be that one of the brushes ("focus brush") inside the lens that are used to signal the position of the focus to the camera electronics is damaged. (This might even lead to the mechanical destruction of the focus differential ring I think). I was able to repair my ring, but as I had to glue it, after a few months it failed again. I'm waiting for a replacement ring now.
May 15, 2011 | Sony 16-105mm f/3.5-5.6 Zoom Lens for ...
The lens fell and now the autofocus does'nt work well and the focus ring doesn't move smothly
auto focus involve,sensor,gear-box,etc.better get it serviced,by replacing the broken parts.
Mar 24, 2010 | Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF...
Nikkor AF 80-200mm f/2.8D ED Lens, with broken auto/manual ring
Depending on where you live, you can take it to an authorized Nikon repair place or just send it back to Nikon.
In the US, they are in Melville, NY and ElSagundo, Ca.
Jul 12, 2009 | Cameras
Lens hood broken off and I need replace ment part to screw it bac
you can email me a picture of the broken part and i will send you the part numbers of the broken parts here: electronios@hotmail.com
Dec 30, 2008 | Panasonic AG-DVX100A Mini DV Digital...
Ricoh KR-10 locked focus ring
you can fix this if you have a jeweler's screwdriver ( x- head ).
1-take the lens off the camera.
2-take off the front name plate with a thin knife blade just right of H of RICOH name. gently pry the name plate up till it pops off ( not screwed on ).
3-remove the three screws from the plastic ring, ( large ring ).
4- pull the ring off.
5- where the metal ring touches the plastic lens barrel apply a few drops of light machine oil.
try to move the focus ring back and forth until it's free.
it can be further broken down but then the lens will have to be re-focused. as long as there is no impact damage this will work.
Dec 16, 2008 | Photography
Dell 2200mp doesn't focus
Sounds like a servo motor thats broken (the electric engine moving the focus adjustment) If the system have manual focus it could be the connection between the focus ring and the "focus" thats worn out
Sep 07, 2008 | Dell 2200MP Multimedia Projector
Fuel Pump
number 2 cylinder has broken rings ,or the coilpack/leads need replacing check for current to fuel pump if no power checkfor spark if no spark either it could be immobiliser
Aug 21, 2008 | 2001 Ford Focus
Dell M410HD Projector Projector Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
