Question about Cooktops
Amana easy touch control 500when we use bake only, no problem.when we use broil only, the bake and broil indicators flash. the manual said pull the plug for a few mins and try again. did that. problem repeats itself.
Why the off switch, temperature control dial, timer do not work when baking?
could be that it knows it is already being used and locks all controls until the timer runs down .
Feb 14, 2016 | Whirlpool Gold GGE388LX Double Oven...
My frigidaire fef368gch was working fine and then the oven just stopped baking. It will broil but not bake. What causes this and how do I fix it?
Good Morning Shari,
I see that you are having trouble with your Frigidaire range, model# FEF368GCH, and the bake element not working while the broil element is. I suggest giving your appliance a hard reset, by shutting the power off at your home's circuit breaker, for 2-3 minutes. When power is restored, you will have to reset the clock by entering in the time and pressing start. Start a bake cycle, and if you notice that the bake element is still not working, I suggest contacting your local authorized technician. Hope this is helpful.
-Best Regards-
WP
Apr 23, 2014 | Frigidaire FEF368GC
Propane oven won't light
Can you post more details like: Does the oven ignitor come on (glow orange)? Can you hear the oven gas valve click open and/or smell gas? Do all the stovetop burners work fine? Have you checked your propane tank to be sure you are not out of gas?
Mar 13, 2014 | Amana AGR4433XD 30" Freestanding Gas Range...
How can I adjust the volume of the touch controls on our Amana Gas Range?
Hello not sure volume can be changed but if it can look on the back of the unit or inside the back top plate there will be a tech sheet if it can be done it should be on it
Dec 01, 2013 | Amana 30 in. White Freestanding Gas Range
E1234 flashing
I noticed the same thing with my Samsung oven. The repair tech was just here and figured out (with Samsung phone support's help) that it is normal behavior when the divider is inserted. You will notice, if you look carefully, that the E1234 is showing in some pictures in the manual when it talks about using the oven with the divider in. Bottom line is you can ignore it.
Sep 10, 2013 | Samsung 5.9 cu. ft. Freestanding Flex Duo...
Oven dont turn on ihave checked the braker is ok
have you turned the control knob to broil and the temp all the way up, this will check to make sure you have a good switch on your selector. then turn onto bake and turn all the way up. let me know
Feb 03, 2010 | Cooktops
The on indicator light stay on all the time on Maytag touch 500
you have a bad switch, you need to unplug the wire going to the conector marked P on one switch at a time til you find witch switch is bad. if you have turned off the breaker to it and the light is still on then the power is not off to it there is not a batery in it, careful that glass breaks easy when out of it's can
Dec 25, 2009 | Maytag MEC5430BDS Electric Cooktop
Bake and broil do not work
assuming that the worst case senario has taken place
first thing i would check is ensure i have proper voltage at the outlet, 120 from each side to ground
220 across L1-L2
the elements are the only thing on the range that uses 220v
if you know how to use a mutimeter
you can test both the elements
disconnect the range at teh breaker
take out the screws at the back wall that hold the elements in
pull out about an inch becareful they dont leave much slack on the wires
disconnect on element terminal and apply your leads your looking for continuity, your meter should beep
if not replace the element
if yes, let the element hang ensureing niether terminal touches anything, reconnect the other terminal
now turn the stove on bake if your doing the lower
turn you meter to ac voltage
you should read 220v
anything less than that, your problem is before that
Aug 02, 2009 | Maytag 30 in. Admiral LGC1330 Gas Cooktop
Amana Electric Smoothtop Cooktop heat control knob.
1st remove the control knob by off position & pull it one by one then clean it by using vacium.tnx
Nov 16, 2008 | Amana Cooktops
Sve47100 oven doesn't heat
Test the swtich w/ multi tester /connect tester as a jumper to the switch dettach one line on and off switch /if does not reponse / replace the switch.
Jan 03, 2008 | Jenn-Air JED8430 Electric Cooktop
Cooktops Logo
56 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
