Question about Yamaha RX-V573 7.1-Channel Home Theater Receiver - Black
Yamaha rx-v573 sound delay problem
Hi all, i would like to ask for a help how to fix an issue with my yamaha receiver, i have the following connections, music coming from a PC to a focusrite saffire sound card, from the focusrite saffire the connection goes to allen & heath xone 42 dj mixer, from the allen & heath xone 42 mixer i have 3 outputs going to 1 active studio monitors, 2 active pa speakers 3 yamaha rx-v573 av receiver (using 2 front speakers and sub) i use these 3 sets of speakers separately for their purpose, but sometimes i like to put them all 3 at the same time, at first i didnt had any issues, all three sets were going in sync when music played, now i have the first 1,2 in sync and the 3 yamaha receiver slightly off sync the yamaha is off sync with the 1 and 2 speakers if i use the 2ch stereo setup in music mode (and in any mode with the sub on) only if i engage the receiver in direct mode the sound is back in sync with the 1 and 2 , but than i dont have the sub i havent changed anything in the setup so cannot really tell what made this difference i tried connecting from the focusrite saffire sound card straight to the receiver but the delay is still there and it's out of sync with speakers 1 and 2, so hope for some help how to bring the receiver back in sync with the other speakers when i have the sub on the speaker on, thanx in advance jovanja
3 Suggested Answers
bunnydawg
  • 5158 Answers
SOURCE: Sound card in PC is operable
Look at the plug.... is it metal then a little band and then the tip or is it metal a band then metal and then the tip.
Posted on Aug 30, 2008
SOURCE: ipad not connecting to yamaha receiver (airplay and iPad app)
Same for my receiver to, used to work, did you find a solution? Thanks.
Posted on Jan 06, 2013
Yamaha receiver will not connect to Airplay
I have the same problem, it seems the airplay connection is easily lost, it never plays for longer than an hour without itunes losing the receiver, then i have to reset the receiver so that it appears in itunes again, very annoying. I spoke to Yamaha and they are not aware of any issues but clearly there is one. A quick workaround is to bring the receiver up in a browser by typing in its IP address, go to IP Address tab and simply apply without changing anything, this causes the receiver to initialize its network function as you will see the amp resetting and it will then appear in iTunes. This doesn't work through the units setup without changing settings and then changing them back again. Hopefully this is just a glitch that will Yamaha will fix in the next firmware update, I am running 1.14 update.
Sep 28, 2012 | Yamaha RX-V473 5.1 Channel Network AV...
Get 'No Content" when trying to play music from yamaha Rx-a1010 receiver
Double check the actual file contents. Right click on your music files and verify that the data exists. This will be evident by the value of kilobytes the song is made of.
Next verify that your connection method to the receiver is viable...there should be either an indicator on your computer or the receiver to confirm the connection integrity.
If you find that your data does not actually exist then it would be up to your discretion exactly what to do about that as that problem is NOT relevant to the Yamaha HT receiver.
If you find that the data DOES exist, disconnect the computer from the receiver and restart the computer. Reconnect the computer and try again.
May 07, 2012 | Yamaha AVENTAGE RX-A1010BL
Subwoofer
Without being able to access the receiver in person, the best advice I can give you is to sit down with your user manual and follow the instructions. You'll find, starting on page 85, the necessary settings for hooking up a subwoofer to the receiver. If you don't have the manual, you can obtain a pdf file at Yamaha.com: http://www.yamaha.com/yamahavgn/Documents/YEC/AV_Receivers/Manual/RX-V663_U-1.pdf
May 16, 2010 | Yamaha RX-V663 Receiver
I have distortion coming out of my front right channel of my AVR
Yes, sounds like your DSP chip has an issue. Not an inexpensive repair if that's the culpret. Around 400-500 to replace the chip. It's an awesome receiver and worth 300-400 in repair, however, a 3800 or 1800 can be had for 600-800 depending where you look. If you need more help, post a comment and I can help you some more.
Aug 10, 2009 | Yamaha RX-V2600 Receiver
Yamaha HTR-6130 sound only from centre, rear or front speakers
its not how there connected its in your settings. rehook up all your speaker connections properly,then make sure you proram the reciever to recieve fiber optic,hdmi,digital coax etc in the reciver.
May 18, 2009 | Yamaha HTR-6130 Receiver
Yamaha RX V800 w/ iTunes Airport Express
thats cause your patch cable is mono get a stereo 3 ring connector.
Apr 01, 2008 | Yamaha RX-V800 Receiver
Hi from the Philippines
as far as DSP surround processing is at question, yamaha will do best but when you ask for audio performance, output clarity and performance.... Denon or HK.
Feb 17, 2008 | Yamaha RX-V661 Receiver
Getting to work your pc music files through the usb connection
how should i connect my yamaha rx-v2700 to my desktop pc and which software i should install on my pc and where to download this software
Feb 12, 2008 | Yamaha RX-V2700 Receiver
Yamaha Usb Midi driver connection to Yamaha Keyboard PSR E403
solved it thanks to this webpage :
http://www.rme-audio.com/english/faq/10entrye.htm
has to do with registration entries and after following instructions on this page to delete double entries and reinstalling the driver, it works perfect
Jan 25, 2008 | Computers & Internet
Yamaha RX-V573 7.1-Channel Home Theater Receiver - Black Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
