Question about GE Sentrol 2707a-l High Security Door Contacts
Instillation in metal door frame
Can you show more detail on how this unit is mounted on or into a steel door frame and door.
  • 694 Answers
This unit would be mounted in the top of the door and the other sensor above the other they need to b cut in to the door on the top of the door and on the top frame reason being you then have a tamper proof security door that very few will know is a security door to achive this you will need a plasma cutter or hire out to get the holes u need cut thanx Chris
Posted on Mar 01, 2014
Where can I get a heat resistance double sided tape to affix the external glass of the oven to the SS frame on my slide in GE stove .
Most of the time that GE attaches any type glass to hot metal these days they use silicone seal. It is uses to attach glass cooktops into the metal frame of the cooktop. Get a tube of GE clear silicone seal and glue the glass around the complete edge getting a good seal and contact at the glass edge and metal panel. Let it dry 24 hrs before reassemble. The silicone seal turns to rubber when dry and is quite heat resistant. It won't stand up to direct flame but should hold your glass well.
Apr 27, 2015 | GE Ovens
The wireless doorbell does not work in our house.
Remove the door bell button and verify that it works not mounted on door frame. If that is the case then you are getting interference from the structure....not necessarily from the door itself but it won't help. The door bell runs on RF and at that distance it will most likely be from electrical interference (too close to an outlet or light switch.)
Feb 16, 2015 | Home Security
Door will not latch
open door and on door frame you will see a metal catch that the door hooks to pull its self closed and creates a seal. this catch sometimes needs to be adjusted by loosening 2 screws and moving forward most likely.
Apr 16, 2014 | Maytag MDBH955AWS Stainless Steel 24 in....
Show me how to pull the control panel out
The control panel is fixed to the stainless steel inner panel. You will need either a phillips or a T20 torx screwdriver depending on what fixing have been used. You will need to take out all the screws which line up with the control panel plastics. There is usually one in the left and right sided at the top of the inner frame also. The screw by the door lock along the top will have to come off if it has one. Looking at this unit it is an older design so it should do.
Now sometimes you will need to loosen off the screws holding the front decor panel a bit, I normally loosen the top and middle ones enough to free up the control panel a bit to jiggle it out of position. It is easier to take this decor right off and get the control panel out but takes longer.
Now if you have the unit I think you do the plastics on the control module will be quite brittle so be careful not break it if you need to check it for some reason. There are a few plastic clips around the module which clip it into the metal frame. The metal frame clips into the display fasia. You should see the clips round the edge of the metal frame which are tricky to get off sometimes. Once you have the display plastics separated, then you can un clip the module from the metal frame. As I said be careful especially of the buttons.
Also be careful not to pull on the cables to much if removing witht he decor panel still on the unit. The edge of the metal may cut into the wires.
As with any work on electrical equipment, please stay safe and make sure the unit is unplugged.
Apr 08, 2014 | Bosch 24 in. SHU43 Built-in Dishwasher
The door spring came off of hamilton beach 31100
The door of the Hamilton Beach Model 03008 or similar toaster oven does not stay closed when the door return spring or the hook it connects to breaks. The repair is very simple and takes just a few minutes!
The door spring is about 1 inch long and connects to a small clip on the inside of the left side panel of the unit. To see the small clip and the door spring, you simply remove the left side panel of the toaster oven which is done by removing just one screw.
The mounting clip on the side panel for the door return spring is located about half way up the side panel near its front edge.
The other end of the spring (its bottom end) connects to a metal hook. If the spring is not connected on its bottom end then the wire hook is broken. This is a simple repair that only requires a few inches of metal wire.
The other end of the metal hook (its bottom end) is connected to the bottom of the door hinge where it inserts into a small hole in the left side mounting hinge of the door.
When the steel hook breaks on either end then the spring cannot function, so the door does not stay closed.
To fix this problem, you simply get a piece of steel wire that is about 1/16 inch thick and a few inches long.
Bend the wire to make a hook at one end that the spring will connect to.
Then insert the other end of the wire into the small hole on the left side mounting hinge of the door. Then bend the wire on the inside of the hole to make a U or hook so the wire stays mounted in the hole of the door hinge.
Then adjust the position of the bend on the other end of the metal wire so the spring will have good tension when it is attached to the hook and to the clip on the side panel.
To do this you make the U shaped bend on this end of the wire to be about 1/2 inch from the end of the open end of the spring when the top end of the spring is attached to the mounting clip on the side panel.
To attach the spring to the wire hook, first remove the spring from the mounting clip. Then hook the spring onto the hook (bend) you made at the top end of the wire, then just stretch the spring to connect it to the mounting clip. The door will now stay closed.
Nov 10, 2013 | Hamilton Beach 31197 120 Watts Toaster...
Is there a stainless steel door panel replacement for bosch dishwasher shx43c02uc
If there isn't, you might try having a local metal shop cut you a piece of stainless, fold and weld the edges to make a cover for the door and adhere it either with epoxy or a small tack-weld. I wound up having to have a cover made for my Mom's stainless-steel fridge when only white and black ones were available and a metal shop doesn't charge much for it.
Alternately, if the metal panel is housed in a frame, try taking apart the frame, removing the panel and flipping it over. They usually just paint the one side, and if the other side is bare metal, such as aluminum, you can use sandpaper to give it a brushed finish and some clear-coat spray paint to give it that shiny stainless look and durability. Then just reassemble the door with the stainless-looking side facing outwards and the wrong-color side facing in. Worked for Mom's dishwasher!
Aug 31, 2012 | Bosch Dishwasher Door Panel White - 245067
RE DOORS FAILING AT HINGE
Look at the hinges. If they are bolted and the only problem is they are loose. Try to tighten tem. A tig weld in place will burn odff any paint and if welded poorly you will have alignment problems. The welder will be welding heavy metal to sheet metal The bolts that hold the door on pass through a heavy steel threaded plat behind the sheet metal. Good Luck, Ned
Oct 06, 2009 | 1995 Jeep Cherokee
Speaker Failure
If your receiver's ground wire isn't connected probably your going to cause a chain of small short circuits that will continue to arise. The head unit needs to be properly wired and installed. It is a possibility that you may have a problem with the speakers building a magnetic force onto the steel frame of your speaker mounts, causing it to give you the "faliure beep and message" and the cd player takes action in cutting off the source of problem. I would remove your head unit, if you are unable to do so bring your car to a a local service tec, and have it removed, but watch carefully so you know how to do it next time. And once out, trace all your wires to each other and assure a contact is made. The ground is easy, If its fair sizes wire in length and it isn't connected. Look for a mounting screw inside of your dash, preferably one running to your metal dash itself. If you cant find one, you can always mount the same screws your cd player mounts onto. BUT look for a stand alone spot for it to screw in for insurance that its not gong to come loose.
Good luck and ask more questions so i can further assist you.
Sep 11, 2008 | Car Audio & Video
Glass on sliding door
this is the link to the information http://www.swisco.com/Screen/how-to-repl...
Opening your patio sliding glass door should be an easy task. If your sliding door is giving you a work out every time you open it, most likely it is your rollers that are causing the problem. The rollers are located on the bottom of the sliding door and give the door the ability to slide. Often times they get dirty and wear out, making it difficult to open the door. If you have an older sliding glass door your rollers may have become rusty because sliding door units did not always use stainless steel rollers.
Hiring a professional to replace your rollers could cost you around $100 not including the cost of the replacement parts. Below are detailed steps containing all the information you will need to know to replace your patio sliding glass door rollers yourself.
* Before you start, understand that you need to take the sliding glass door out of its frame to work on the rollers. The sliding glass door is heavy. You may need the assistance of another to help you remove the door.
1) Your patio glass door will have two separate glass units. One unit is the door that you slide and the other unit is stationary. First, stand outside your house and look at your sliding glass door. If the stationary unit is between you and the sliding unit you will most likely have to remove the stationary unit so that you can get to the glass sliding unit.
Before you go through the trouble of removing the stationary unit, first try to go inside your house and see if you can remove the sliding unit. Usually you cannot because there is a lip along the bottom of the patio glass door frame (it keeps moisture out of the house) that prevents the sliding glass door from being removed from the inside.
If the rollers on the bottom of the door are difficult to get over the lip, you can adjust them to help you create more room (go down to step 2). If it is not the rollers but the sliding unit�s frame preventing you from pulling the sliding unit out of the door frame, you are going to need to remove the stationary unit first before you can remove the sliding unit.
To remove the stationary unit, you first need to take out your screen door (if you have one). Lift one end of the screen door frame and use a screwdriver to lift the roller on the bottom of the screen door frame off of the track. Do this to both ends of the screen door and your screen door will pull out of the door frame.
The stationary unit is held in place by a metal piece that runs along the bottom of the track from the corner of the stationary unit to the bottom of the side jamb (there is a chance this piece is missing but if you do have one remove it from the track). After you have removed the metal piece, look for screws holding the stationary unit frame in place. After removing all of the screws try pulling the stationary unit out of the door frame. If you are having trouble pulling out the stationary unit, try placing a screwdriver between the stationary unit�s bottom frame and the track it is resting on. Lift up on the screwdriver while you have a helper pull out the stationary unit from the door frame. Be careful not to use too much force with the screwdriver so that you do not damage the door track.
2) You may need to create more room when you attempt to remove the sliding unit from the door frame. To create more room you can adjust the rollers on the bottom of the sliding unit. By turning the adjusting screws on the rollers clockwise the wheels move up into the sliding unit�s frame giving you more room. The adjusting screws are located either at the bottom of the sliding unit�s frame or in the sides of the frame. There is a chance that there are plugs covering the screws.
After you adjust both rollers (one on each side of the sliding units frame) try to remove the sliding unit from the door frame. If the unit is still getting stuck you may need to get someone to help you. Have your helper lift one side of the unit and pull outwards while you try to pry the other side of the unit over the track.
3) To remove the rollers from most sliding units you need to remove the bottom of the sliding units frame. Most likely the screw that holds the roller in place is the same screw that holds the frame together. Remove the screw from both sides of the unit. Then try to remove the bottom piece of the frame off of the sliding unit; you may need to use a rubber mallet or a piece of wood and tap on the bottom of the frame until it comes off of the sliding unit.
Now that you have removed the bottom of the frame you can take a close look at your patio glass door rollers. Remove one of the rollers and match it up with one of the rollers on this page http://www.swisco.com/page/SI/CTGY/patio...
It is a good idea to replace both sliding door rollers at the same time to prevent extra wear-and-tear to one new roller, which will have to work twice as hard when paired with an older roller.
4) After your new rollers come in, replace your old rollers with the new ones. To make it easier to install the sliding unit back into the door frame, adjust the rollers to be all the way up into the frame. Once you have the sliding unit back in the door frame you can adjust the rollers for optimal performance. Keep adjusting the rollers until the door is sliding back and forth easily
Jun 22, 2008 | 1996 Ford Windstar
GE Sentrol 2707a-l High Security Door Contacts Logo
44 people viewed this question
Top GE Home Security Experts
Michael Galve
Michael Galve
Are you a GE Home Security Expert? Answer questions, earn points and help others
