Question about Amana ABB1927DES Stainless Steel Bottom Freezer Refrigerator
Amana br18 freezer not cold - Amana ABB1927DES Stainless Steel Bottom Freezer Refrigerator
4 Suggested Answers
  • 20 Answers
SOURCE: amana bottom freezer problem
It sounds like the condenser coil might be freezing up. This happened to me on my bottom freezer. The cooling part of your fridge is only in the back of the freezer compartment. The cold air from the freezer blows up through a vent in the back to the fridge and comes out at the top. If the coils do not defrost (which is what happened with mine) the air flow is blocked by the ice and can't get to the fridge compartment. Your freezer will still be cold but your fridge won't. If you pull the plug on it and time things right you can defrost the coils but this will only postpone the problem. Both will work for awhile again until the coils ice up again. You can also pull out the freezer drawere and try to defrost the coil with a blow dryer. You have to disconnect the icemaker and pull out the back panel behind the freezer to get to it though.
Posted on Jun 04, 2009
  • 239 Answers
SOURCE: amana refrig refrig wont get lower than 42 degrees
that is defrost timer every 8 hrs it turns on heater to defrost evap coils, unless there is major ice behind freezer panel after 1 day which i doubt, that would not be problem ...im trying to go through steps i would take as tech at your house
Posted on Jan 03, 2010
walterkunesk
  • 683 Answers
SOURCE: I have the amana refrigerator
try cleaning the condensor coils and let me know. how about a rating? thank you.
Posted on Apr 14, 2011
We have a Amana BR18 Easy Reach bottom freezer. The fridge is turned up all the way, barely keeping food cold. The freezer is not freezing anything (ice, etc.). The freezer is still blowing cool air, but...
Low refrigerant assuming the compressor is always running and not being shut down by the thermostat.
You can hook up an ammeter to the unit to see if the current consumption is below spec, another sign of low gas situation since the motor is not working as hard as under normal conditions.
Jun 10, 2017 | Freezers
Freezer not freezing nor ice maker
Is the refrigerator still working? Is there any cold air in the freezer? If your compressor stopped working it would cause the refrigerator to be warm also. I had a problem with my amana refrigerator where the freezer wasn't getting cold enough and it was due to a condenser fan running intermittently. i replaced the fan and was back in business. i would check to make sure both your fan and your compressor are operating...
Mar 03, 2010 | Amana ABB1927DE Bottom Freezer...
Amana refrig refrig wont get lower than 42 degrees
Jan 03, 2010 | Amana Easy Reach 18.1 cu. ft. Bottom...
Amana BR18 fridge/freezer. Fridge is cool but not cold, freezer is at about 20 degrees. Ice cubes are frozen but ice cream is soft. Any ideas?
you maybe blocking the circalation in the freezer the way you have things packed in there. Move large items away from where the cold air blows in.
Oct 04, 2009 | Freezers
Amana BR18 Doesn't get cold
Mine is doing the same thing
Jul 05, 2009 | Amana Freezers
Refrigerator model BR18 has a defrost problem, have removed the back panel in the freezer and melted the ice, now what?
well there is a few things to check like defrost thermostat, timer or heating elements, give me a call and i can walk you through it for free..whirlpoolpartssurplus.com
Jun 23, 2009 | Amana Easy Reach 18.1 cu. ft. Bottom...
Amana Side-by-Side Refrigerator Not Cold
can be a few things, if you open the freezer door do you hear afan running?? perhaps the fan is no good?? is there a large amount of frost on the lower plate of back wall of freezer??? very common issue to have a bad defrost thermostat.
Feb 19, 2009 | Amana ARSE66MB Side by Side Refrigerator
Amana side by side does not freeze nor does it get cold
first check you freezer back for frost if a lot of frost defrost the whole freezer ,,, then plug back in and see if it will work..
let me know
Jul 05, 2008 | Amana SXD524VW Side by Side Refrigerator
Refridgerator and freezer is no longer cold
evaporator freezer fan motor has low voltage. Amana M # SCD22NW S # 9403120669. Could use some help. Thanks
Oct 23, 2007 | Amana ACD2232HR Side by Side Refrigerator
Amana ABB1927DES Stainless Steel Bottom Freezer Refrigerator Logo
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
