Question about HP 35s Scientific Calculator
Clear a HP35s - HP 35s Scientific Calculator
HP35s minus sign display is incorrect
The minus is always centered while the negative is always at the top.
If you're in algebraic mode, press 1 - 2
You should see the centered minus sign between the one and the two. Now press ENTER, and you should see the top negative preceding a one.
The two are two different things. The first indicates subtracting one number from another. The second indicates a negative quantity.
Are you sure the minus is at the top? Or was the negative centered?
Nov 08, 2013 | HP 35s Scientific Calculator
How to remove RAD from HP35s
Press MODE then 1, 2, or 3 to select the desired angular mode. In any mode other than degrees the display will indicate the mode.
Mar 13, 2013 | HP 35s Scientific Calculator
Printed manual for Hewlett Packard 35s scientific calculator
CalcPro sells the original HP35S User's manual for about 10 dollars. Here is the link.
Dec 31, 2011 | Office Equipment & Supplies
My HP35s keeps flashing MEMORY CLEAR. I removed the batteries and reset it with a paper clip. Nothing works.
I'm not sure if it is the only solution, but I had the same problem and I replaced the batteries. My HP35S works fine now.
Previously, however, there was no "battery" annuciator on the screen. This calculator went four years without a bettery change. My HP48GII, on the other hand won't go two months without a change. Go figure.
May 11, 2011 | HP 35s Scientific Calculator
Who can repair HP35S calculator with loose "enter" botton?
Hi
I fix all the TI , HP, Casio Calculators
i am in New York
ecrdn@yahoo.com
Jack
Nov 03, 2010 | HP 35s Scientific Calculator
HP35s extracting P to R anwsers and place in memory
Given a complex number, ARG (yellow-shift i) will give you the angle in the current angular mode, while ABS (blue-shift +/-) will give you the magnitude.
To extract the real and imaginary components, you'll have to use the relationships
x = r cos(a) and y = r sin(a).
Feb 14, 2009 | HP 35s Scientific Calculator
HP 35s Scientific Calculator Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
