Question about Tefal T-fal TFal Filtra One Deep Fryer
Fryer turns on but will not stay on. shuts off constantly for no reason that I can think of and as a result frying ANYTHING takes forever
Product is only a month old and seems to have never worked properly. I turn it on, light goes on and then I look again a minute later and light is off . Its driving me crazy! What am I doing wrong
  • Lauren McCain
    Lauren McCain Feb 11, 2014
    I should add that I have to continually turn fryer back on in order to get food cooked. Any insight or advice would be much appreciated!
  • CYNTHIA BAXTER
    CYNTHIA BAXTER Feb 11, 2014
    it sounds like you have a short in the wiring, I know that it's easyer said then done, but you can fix it. make sure that it is cleaned and unpluged, then find a good work aera, make sure that you have some kind of cup or something like that to but the scewres in. if you have a contiuaty tester after you have the houesing off test each wirer. you can make your oun c.tester just go on line, may be u tube,any waycheck each wirer if your light comes on it should be a good wirer.But if you do not see the light come on then thats where the short is.
2 Suggested Answers
geox29
  • 65 Answers
SOURCE: Tefal FV9255 Iron
i do believe is something wrong with the thermostat or the electronic board.That model i do believe(but i`m not sure) have a small circuit board controlling the temperature and the safety.Make sure also your thermostat handle is working properly because sometimes the connector between the handle and the thermostat can get bad and not adjusting the right temperature
Fabio
Posted on Jun 21, 2008
Pico fryer not operating at full preformance>
Hi there.
Check the gas pressure; low gas pressure results in low oil recovery.Check also the fire tubes for soot build up, clean as needed. The quantity and quality of product should also be considered, overloaded and/ or frozen product reduces the oil recovery.
Regards.
May 24, 2013 | Pitco Frialator 35CD Deep Fryer
Why is my fryer rapidly bubbling
Hi there!
Check the deeper part of the fry pot, crumbs or food debris may have accumulated there causing oil to produce excessive bubbles during frying.
Also, overloading with products more than usual water content will also result in this.
Regards.
Jun 27, 2012 | Frymaster Dean SR42G Deep Fryer
Our battered chicken and fish is sticking to the basket what do we do?
Hi there:- You mean the products you put into the deep fryer stick to the basket or sunk down to the bottom and stick to the bottom basket. It can be a number of reasons but the most important is the temperature of the oil, it should be 350 degree F or more to do the frying , any temperature below that will be call boiling not frying. Secondly the batter mix ( you should try out and make your own batter mix ) Hope this can help.
Sep 23, 2010 | Rival CZF725 Deep Fryer
The item will turn on and begin to heat but it then starts to heat and takes a very long time to get to the temp set. Then once we add the items to fry it stops heating..we cannot tell if it is shutting...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If this is electric then you have a burned out element...
if this is a gas unit,,,
Your problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Sep 09, 2010 | Star 301HLD Deep Fryer
Defective fryer
There is nothing better that some fish and chips but I don't think this fryer is the one for that. The reviews I have researched say it is unreliable and dangerous due to the lid pops of at high heat. Maybe you can return it for a refund I don't know. Wish I had better news for you but I don't. The best southern way to deep fry is in a cast iron pan. A BIG one! Season it and start cooking! Cholesterol? Whats that? Have a great day and hope this helped you.
Aug 25, 2009 | Rival CZF625 Deep Fryer
French fries always turn out soggy
It seems to me that if the fries always turn out to soggy what you need to do is to cook them at a higher temperature for a shorter period of time, I think they are sitting in the oil far to long hence the soggy result.
Mar 20, 2009 | Presto 05430 FryBaby Deep Fryer
Oil Level Stains
Manufactures are constantly changing the properties in the stainless steel. They are dropping the nickel and alloy contents that they used to use, that's where the dull finish is coming from !
All manufactures are changing there materials to compete in this industry. These units may have been manufactured at diferent times.
Scoota
Dec 01, 2008 | Pitco Frialator SG14 Deep Fryer
Heating
Some Deep Fryers heat up faster than others, please see details below for pre-heating times: Non-Immersion Element (No element in the Oil): 25 to 30 Minutes Immersion Element (Element in the Oil): 7 to 10 Minutes Are you by any chance overloading the fryer? try smaller batches. Preheat the oven to 180 to 200 F. Heat the oil in the fryer to 280 or 290 F. In small batches appropriate to the size of the fryer (fries for a serving of 4 people may need to be divided into 2 or 3 groups), fry each batch for about 8 minutes at this temp. Remove to a holding bowl. They will look limp, nasty and oily. (This uses 1/4" square fries from baking pototoes cut with a standard mandoline.) When all the fries have been precooked, increase the oil temp to 375 F. Add the fries back to the oil in the same sized batches as before. It will take 3 to 5 minutes for them to crisp and brown. Drain, salt, and move to a cloth-lined bowl and hold in the 180 F. oven. Let the oil temp recover to 375 F. and cook the next batch in the same manner. Repeat, holding interim fries in the 180 oven, until all the fries are done. When all batches are done, toss to distribute salt and the new fries with old, and serve immediately. Properly done, all commercial french fries pale in comparison to these. However, I cannot guarantee that this method works with frozen commercial products. I always use fresh baking pototoes. That said, the frozen product should work to its optimal advantage when done in small batches with the first batches held in the warming oven as the other batches are done. If it still doesn't reach 300 F then by all means take it back to the shop and ask for a replacement. If you're out of warranty get an estimate for a repair. Good luck and bon apetite ;]
Jan 24, 2006 | Black & Decker DF200 FryMate Fryer
Tefal T-fal TFal Filtra One Deep Fryer Logo
43 people viewed this question
Top Tefal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paul
paul
Gerry Harvey
Gerry Harvey
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
