Question about Panasonic KX-TG6633B 1 KX-TGA660B Cordless Phone
Earpiece volume how to adjust volume
How do I turn down the hearing volume on this phone?
It was very simple for me. Here is what I did:
1. I did a google search for Uniden DECT 6.0 manual
2. I downloaded the manual and searched for the word Volume
3. I looked at the table of contents - and lo and behold the was an entry for Adjusting the Earpiece Volume on page 36.
So you will not have to repeat the simple steps, here is your answer:
Adjusting the Earpiece Volume You can choose from six volume levels for the handset earpiece. To adjust the earpiece volume while on a call, press the up arrow (to make it louder) or the down arrow (to make it softer). The handset display shows the current volume level for the earpiece.
May 20, 2015 | Uniden DECT 6.0 Cordless Phone ID
Earpiece volume control
On the upper left edge/side of your phone, you will find your "Volume Up/Down Keys". Use these DURING a phone call to adjust the volume of your earpiece speaker. If you don't do it during a call, you will just be adjusting the ringer volume. Hope this helps.
Mar 29, 2014 | ZTE Warp
Please advise as to how to increase the VOLUME on my DECT 6.0 phone.
To adjust the ringer volume:
  1. With the phone in standby, press ^ or v. The display shows the current volume level and the handset sounds the ringer at that level.
  2. Use ^ to make the ringer volume louder or use v to make it softer or turn it off completely.
  3. When you hear the ringer volume level you want to use, stop pressing keys. The handset will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset won't ring. If you have any accessory handsets, other handsets will ring according to their individual settings.
To adjust the earpiece volume:
You can choose from six volume levels for the handset earpiece. To adjust the earpiece volume while on a call, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the earpiece.
To adjust the speaker volume:
You can choose from six volume levels for the handset speaker while on a speakerphone call. To adjust the handset speaker volume, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the handset speaker.
Note: The handset earpiece and the handset speaker have separate volume settings.
Apr 06, 2011 | Uniden DECT 6.0 Cordless Telephone...
How to adjust hearing volumn on samsun cell phone
Adjusting the volume during a call Use [up navigation /down navigation ] to adjust the earpiece volume during a call. Press [up navigation ] to increase the volume level and [ down navigation] to decrease the volume level.
Nov 27, 2010 | Samsung SGH-D900 Cellular Phone
Incoming calls: the caller can hear me but I can barely hear the caller
If you have already adjusted the volume of your cellphone, then the problem is in the earpiece. If the phone dropped accidentally the earpiece loosens its contact and you need to open the phone to adjust the contacts. If the phone was not dropped, the earpiece is busted and needs replacements.
Nov 02, 2010 | Motorola Mobility RAZR V3
How to increase the ear piece volume in Nokia 5800 express music and what is the default pin code to reset
You have to be on a call to adjust the earpiece volume. Just call your voice mail and turn the volume up. It's the same button you use to turn the phone ring volume up and down. When you're not on a call the volume is for how loud your phone rings. When your on a call the volume buttons adjust the earpiece volume
Sep 03, 2010 | Nokia 5800 XpressMusic Smartphone
I have a problem hearing with the phone i have turned the adjusted the Volume
The problem with your phone is the earpiece, since you have adjusted and try increase the volume, yet, same problem. The earpiece on your phone is bad that is why you cannot hear the party calling you or hear anything while you call.
All you need to do is to replace the earpiece on your phone and you will see that you can hear whoever you are talking to on your phone.
Replace the earpiece on your phone and you will see that the problem is solved. meanwhile, you can keep using the headset pending the time you will replace the earpiece.
Take care.
Aug 06, 2010 | Nokia N73 Cellular Phone
Earpiece volume very low - can you adjust it
You adjust the earpiece volume during the call itself. Make a call, and press either the right button or up button on the navigation key.
Nov 29, 2009 | Nokia 6500 Classic Cellular Phone
Need to adjust earpiece volume
You can increase the earpiece volume by pressing the UP volume key (located on the side of the phone) *during* a phone call. I simply called my voicemail and once it connected, I hit the UP volume key and the volume meter displayed. Then I pressed it til it was the max and pressed SET. That worked for me, hope it works for you.
--Edriss
edriss@yahoo.com
Aug 17, 2008 | Cell Phones
Open Questions:
Panasonic KX-TG6633B 1 KX-TGA660B Cordless Phone Logo
21 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
