Question about Bruder MAN TGA Container Service Truck
Edc 00638-02 problem no start engine
Buna ziua. Am aceeasi problema la camion.
Ati aflat hiba? Imi spuneti va rog si mie?
Multumesc
Posted on Dec 08, 2015
Engine crank but want start why?
Sounds like fuel not getting to engine.
Jun 19, 2017 | Cars & Trucks
It turns over but it wont start
Engine cranks but won't start. Troubleshooting tips
www.samarins.com/diagnose/index2.html
In this guide, we are going to look into no-start problems when the car engine cranks,but won't start. If your engine won't crank at all, check the first part No-start: ...‎Why a car won't start - ‎Crankshaft position sensor - ‎Check Engine light
Engine cranks but won't start - YouTube
? 8:03
https://www.youtube.com/watch?v=1L4nB2NdA0U
May 16, 2014 - Uploaded by jimthecarguy
2003 Ford Taurus 3.0 liter 24 valve no start cranks OK.You will not ... Car will not start trouble shooting guide, wont crank, wont turn over, etc.
Problem 5: Engine Cranks But won't Start
Jan 01, 2016 | Cars & Trucks
My Holden barina won't start and check engine light is flashing
Check Engine Light On - Auto Diagnosis Repair Help
www.aa1car.com/library/mil.htm
The Check Engine Light (which is actually the Malfunction Indicator Lamp or ... you can assume the fault that is causing the Check Engine Light to come on is probably minor and won't hinder your ability to continue driving. ... When the ignition is turned on (don't start the engine yet), the tool will .... flashing check engine light ...
What Causes the Check Engine Light to Come on in a Car?
www.wisegeek.com/what-causes-the-check-engine-light-to-come-on-in-a...
Nov 7, 2015 - When the check engine light comes on, take the car to a reputable mechanic .... I went to go home. the check engine light was blinking and it won't start. ... I looked in my manual book for 2001 holden barina car to see what the ...
Car cranks but won't start, Check Engine light blinking ...
www.evolutionm.net/...engine.../424408-car-cranks-but-won-t-start-chec...
Jun 1, 2009 - I tried to turn it back on but it would only crank and not start, the check engine light is also being really weird, it's blinking on and off pretty quick.Missing: barina
Check engine light flashing car won't start - RX8Club.com
Dec 09, 2015 | Holden Cars & Trucks
How do you start a 19th mtd riding mower
Put your left foot on the clutch pedal and push down all the way on the clutch. Move the throttle lever all the way to the top, this turns on the choke. Turn the key clockwise, to the right, to start the engine. Once the engine has started, move the throttle lever down to turn off the choke. You only need the choke when the engine is cold. If you use the choke while the engine is hot, you can flood the engine (too much gas) and this will fowl the spark plug. If you have flooded the engine, turn off the choke by lowering the throttle lever and try to start the engine a few times. If the engine doesn't start, then you may need to wait 20 to 30 minutes before trying to start the engine again. If the engine still does not start, then you can remove the spark plug to dry and to clean the spark plug. With the spark plug out, turn the key to the start position for 10 seconds, to push out excess fuel and fumes. Replace the spark plug and try starting the engine without turning on the choke.
Oct 08, 2014 | Garden
My car won't start
I am not sure about restart the engine,but I would check the crankshaft sensor or the crankshaft pulley...
When a crankshaft sensor has failed or is failing, certain timing problems will arise in engine function. The engine may start normally in some cases, but will cut off after a few minutes (or seconds) of operation. More than likely the engine will be unable to start at all. Since the crankshaft sensor is responsible for engine timing, the driver may experience engine backfire or irregular rpm function, if the vehicleicon1.png starts at all.
Dec 21, 2012 | Hyundai Motor 1999 Elantra
Outboard engine hard to start.
Press the key inwards to activate the Choke. Also, you only pump the bulb when the tank runs dry. Pumping after a successful run, shutdown, pump and restart can flood the engine.
If that doesn't work, claim under the warranty.
specs
Yamaha F20LEHA Outboard Motor Portable
manual, which oddly, doesn't mention a choke feature.
http://www.yamaha-motor.com/assets/service/manuals/1/LIT-18626-07-17_1378.pdf
Apr 19, 2017 | Boating
Yamaha outboard engine. Model f20leha manufactured 5-2011, has about 30 hours on it. Sinse new engine is hard to start, after finally getting engine started, hard to keep it running untill engine gets...
have you left the choke open ? this mixes more fuel to the engine upon starting but will stall it if left open too long . check your fuel filter too it may be full of debris.
May 02, 2012 | Yamaha Boating
Vw beetle does not start. seems like its some kind of anti theft protection. the car/key icon lights up, it turns over for a second , then off. this is the first time this has happened, but we bought it...
First of all you need to programm all ignition keys using suitable diagnostic equipment (VAS, VAG-Com) connected to the data link connector of the car.
You have an electronic immobilizer key recognition problem. Now your key chip is not recognized by the transponder antenna fitted on the ignition switch barrel.
  • Everytime when you had a new key you must programm all available ignition car keys before trying to start the engine with this new key !!!
  • $(".author").find("img").brokenImage({ replacement: "http://c.fixya.net/fixya20/images/icons/expert-not-found.jpg" }); function ToggleComments(obj,id) { $("#solutionComments_" + id).find(".thComment").show(); $(obj).hide(); }
    This warning lamp indicates that the engine is locked by the immobilizer system, and the engine start sequence must be repeat again.
    From year 1995 in Audi-VW (VAG) cars is used engine immobilizer. The VAG group immobilizer system consists of an immobilizer ECU which controls the recognition of keys and the Engine Management ECU system. Immobilizer is activated when the ignition key is removed and, together with the engine control unit, largely prevents unauthorized starting of the engine. The system uses a transmitter and receiver unit in the ignition key (transponder). Whenever an attempt is made to start the engine, it transmits a new code to the car's electronics. The immobilizing is only cancelled and car motor electronic receives permission to start engine if the key sends a right authorization code.
    Oct 15, 2011 | 1999 Volkswagen Beetle
    My car turns over good, acts like it might turn on then continues to turn. I figure it might be fuel filter since low fuel light had come on.Or could it be th fuel pump got hot and is not working properly?
    common problem is turning car off with engine not reaching normal operating temp and floods engine. try this. DE-CHOKING PROCEDURE WHEN ENGINE CRANKS BUT DOES NOT START
    If the engine does not start, try the following procedure to start the engine using the de-choke mode.
    Failure to do so may aggravate the no start condition.
    1. Depress and hold the accelerator pedal to the floor and crank the engine for 7-8 seconds. (This will clean out any unburned fuel from the combustion chamber)
    2. Release the ignition key to stop cranking.
    3. Release the accelerator pedal and start the engine. If the engine starts while performing Step 1 the engine will rev up. Immediately release the ignition key to stop cranking and remove your foot from the accelerator pedal.
    ^ Do not keep holding the ignition switch in the START position over 10 seconds if the engine does not start. This may result in a weakened or dead battery.
    ^ Avoid racing the engine or sudden take off right after starting the engine.
    ^ If the engine still fails to start following the De-choking procedure, have your vehicle inspected by your Mazda Dealer.
    for your info there is a recall for this problem. contact mazda.
    May 04, 2011 | 2004 Mazda RX-8
    Engine do not start
    take dist cap off and remove rotor look for carbon tracking on it. have a lot of problems with no start cuz rotor is worn and fire shoots straight thru
    Dec 10, 2008 | 1988 Chevrolet K1500
    Bruder MAN TGA  Container Service Truck Logo
    394 people viewed this question
    Top Bruder Toys Experts
    MarK
    Level 1 Expert
    ptpumpman
    Marc Taylor
    Are you a Bruder Toy Expert? Answer questions, earn points and help others
