Question about Zanussi ZWF1430W Front Load Washer
My washer dryer is showing that its still locked after i turn it on and onpen the door
When i turn on the machine and put my load of clothes into wash if wont let me choose a wash program and just bleeps and shows the locked symbol
    New Friend:
  • 20 Answers
You may have locked the machine by accidentally leaning on the buttons. I can't see a proper clear photo of this machine's control panel, but there may be two buttons on the front of the machine with a picture of a lock underneath them (on mine they are marked 'option' and 'extra rinse'). Hold both in at the same time and this will deactivate the lock.
Posted on Feb 18, 2014
  • 183 Answers
SOURCE: Zanussi Aquacycle 1200
Pump jammed or filter blocked, check filter if not blocked remove pump and replace if faulty. Regards Advisor
Posted on Aug 30, 2007
  • 8 Answers
SOURCE: DOOR WONT OPEN
Hi. Try un-pluging machine,take off top lid slide your hand down between casing and drum until you find lock, then try flicking door casp while trying to open door gentely. when open replace door lock before using again.
Slim jim
Posted on Nov 26, 2007
  • 19 Answers
SOURCE: zanussi zwf14581w front load washer
Are there clothes locked inside machine or water visible inside machine? Either machine has not drained eg.blocked drain hose or pump, or door lock broke .please reply.
Posted on Jun 02, 2008
SOURCE: Zanussi zwf1631w jetwash front loading washing m/c
had to call an enginer out, the problem was down to a faulty motor rota, to identify if e30 is this fault, rotate the drum (so the motor rotates) and try to start the m/c. if it runs ok you know to change the rota. hope this may help someone
Posted on Sep 16, 2008
  • 236 Answers
SOURCE: Door not locking and program reverting straight to end
initially i would replaced the door interlock then if no result the control boart could be faulty.
Posted on Mar 13, 2009
LE error code has popped up & suddenly the control lock is on, I have pressed the control lock & it counted 3,2,1 & nothing happens, won't unlock & LE is still there
if the door locks and wont unlock
LE error
then your machine still has water in it from the last spin/ wash
i think its a blocked up waste outlet
or the pump is blocked up
you need to check the machine is draining correctly and in a timely manner.,..
or it will fail
you need to fully drain the machine then turn off the mains
wait 5 mins and the door will then open
then check the drainage...
Feb 08, 2015 | Washing Machines
My bosch classixx6 1200 express keeps flashing the key/lock symbol and bleeps so I cant start a programme
The door is not locked properly or the door lock switch is not functioning. In the second case the door lock functioning can be checked by bypassing the door switch (for testing only). After bypassing the switch the program can start. If it succeeds replace the door lock switch.
Aug 07, 2011 | Washing Machines
The access door will not open, it is showing the locked symbol in the window
Your problem is either one of the 2 cases below.
1. Door Locked Indicator...'Keyhole' symbol
The 'Keyhole' symbol will illuminate 2 seconds after you have
pressed the 'START/CANCEL' button and will remain lit
throughout the wash programme.
The 'Keyhole' symbol will be flashing at the end of the
programme to indicate that the door is still locked. When the
symbol goes off you will hear a bleep and the door can then
be opened.
2. If the machine has been child locked, deactivate this feature by pressing and holding in the 'child lock' button for 2 seconds.You will hear a beep and the child lock symbol will go out,allowing you to use the machine normally.
Jun 05, 2011 | Hotpoint Ultima WF860 Front Load Washer
Ts show key when i turn on the washing machine, even if i unplug and then plug again. How to remove the lock.
Hold the control panel button with a lock symbol or child symbol in for a few seconds until the light goes away.
Sep 18, 2010 | Siemens WD61392GB Front Load Washer /...
Bosch classic 6 1400 express washing machine - key lock symbol illuminated on panel when machine turned on so machine will not start. No instruction manual so wondering how to turn the lock off? Many...
This is symbol shows that the child lock has been activated. This can only be turned on/off at the beginning or end of washing programme. To activate/de-activate this, just press and hold the Start/Pause button in for 5 seconds. The time settings will then re-appear and then you can proceed as normal
Oct 17, 2009 | Bosch Classixx WFL 2066 Front Load Washer
The digital display is showing a KEY symbol flashing, and i can't program a new load. What does this mean?
This is the childproof lock symbol and prevents you from changing a program once it has been selected The symbol flashes if the program is changed during a wash cycle. If the machine is switched off mid cycle with the lock on then it will continue the program as so as the machine is switched back on. To activate the lock press the START button and hold for 4 seconds and the key is displayed. To deactivate the lock press the START button and hold for 4 seconds until the key symbol disappears.
Sep 30, 2009 | Bosch Exxcel WFX 2467 Front Load Washer
Unusual display on panel (padlock) machine can't be programmed door is not locked however
i just went through the same thing.......you need to hold the option and extra rinse buttons simultaneously for 6 seconds, this will unlock it.....so turn the machine on and press the two icons, dont worry about the beeping and flashing after 6 seconds the padlock symbol will go and you can use the machine as usual.....i wish they put that 'minor detail' in the manual...cheers!!
May 31, 2009 | Electrolux EW1000i Front Load Washer
Machine won't wash because 'child lock' is on
Holding down the Start button for over 5 seconds turns the child lock on and off.
Jan 04, 2009 | Bosch Exxcel WFX 145S Front Load Washer
Zanussi zwf14581w front load washer
Jun 02, 2008 | Zanussi Washing Machines
Zanussi ZWF1430W Front Load Washer Logo
93 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
