Question about Weber Summit S-670 Gas Grill
How to clean burner assembly - Weber Summit S-670 Gas Grill
How do I clean the combustion air intake?
If you are talking about between the outside and the gray flex pipe, remove the pipe and blow the stuff back outside. If it is beyond the gray flex pipe, then a disassembly will be necessary.
To prevent further entrance of anything, debris / bugs to either the intake or exhaust, see my modification to the intake/exhaust pipe here: Thread Toyostove Exhaust Bug Shield .
Jan 08, 2015 | Rinnai Toyostove Direct Vent Heater:...
Flame is high on left back tube of Burner Assembly
The burners need to be removed, cleaned and inspected. Any obstructions on the burners need to be thoroughly cleaned with a wire brush. changing burners to different compartment and still having the same problem in the original chamber, could be a defective heat exchanger.
May 19, 2014 | Goodman GMS90703BXA Heater
Carbon from the back of the burner. higher flame from the back of the burner
Possible that a fully cleaning of the burner is needed as there can be cases of clogging or even food particles having caught up into the burner over a period of time. The use of a pressurised air to clean will be good as it will be worth while to remove and clean the entire burner assembly.
Nov 15, 2011 | Magic Chef 31100 Gas Kitchen Range
Heater begain smoking and producing large yellow flames rather than smaller intense blue flame
The problem you're experiencing may be the result of a clogged air intake valve on the burner or the burner has rusted out. In either case, you will need to turn the unit OFF and disconnect the hose from the tank and remove the tank. This way you can safely dismantle the top of the heater to have access to the burner and the pilot assembly. If you need to lay the entire heater down to work on it, be sure to chock the base so that it won't roll around, while you're checking and cleaning the burner and pilot assembly. A shop vac (if you have one) with a hose and brush attachment works well in cleaning the burner. Canned compress air with a straw nozzle (like you clean your computer with) will help to blow out the burner and the pilot assembly.
Hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Sep 22, 2011 | Fire Sense 02413 Gas Patio Heater
Basemnt flooded water heater wont stay lit ever since, taken out burner assembly severl times now stays on long enough to heat water then shuts down soon after.replaced thermocoupler and have to lite...
Sounds like the air intake is clogged, and pilot and burner tubes are dirty.
All manufacturers say that flooded water heater should be replaced and not repaired.
You can clean air intake and burner assembly, and then next step would be to replace burner assembly and replace gas valve thermostat to see if functionality returns.
Expense of replacing parts is about half the cost of new gas water heater from box store, and still no guarantee that old heater will work.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Jun 22, 2011 | Water Heaters
How do you remove the venturi tubes of a Blue Ember Gas Grill? The manual explains how to clean the venturi tubes, but it doesn't say how to remove the tubes for cleaning. The manual just says...
The venturi tubes are part of the burner. It"s a slot on both sides of the burner tube, where it goes over the burner orifice. You will need to remove the burners to check and clean them.
Hope this helped answer your question.
Apr 18, 2011 | Fiesta Blue Ember Gas Grill
How do you remove the burner part of a coleman grill/stove? I trying to give it a good clean. I got the 4 screws off and grill fuel bar, but for the of me, how do you remove the burner part. Kelly
The Coleman website has a pretty excellent list of owners manuals. (Here's the link for the 9921A700)
I believe that you unscrew the burner assembly on the right, which will then let you remove the cooktop to clean inside and re-assemble.
This procedure is not listed on the Coleman website or in the owners manual, however it appears to be fairly straightforward. I'd recommend using some teflon tape on the threads when screwing the burner assembly back on.
Aug 18, 2010 | Coleman Propane Grill Stove 9921-700
I have a 4000 btu model that is about 3 years old. It will start but shuts down after a few minutes. There appears to be plent of fuel in the tank.
You don't provide the make and model number of the unit, but, I would remove, dis-assemble, and clean, clean, clean the pilot burner and main burner assemblies.
The symptoms you describe are typical of dirt buildup and bugs/spiders getting into the pilot and burner assemblies.
Dec 17, 2009 | Cars & Trucks
GE XL 44
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Aug 27, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Weber Summit S-670 Gas Grill Logo
Top Weber Grilling Experts
paulcarew
Dan Webster
Dan Webster
Treefrog15
Treefrog15
Are you a Weber Grilling Expert? Answer questions, earn points and help others
