Remove fan blade from airflex sff21c - Televison & Video
3 Suggested Answers
SOURCE: Need a fan for an Sony SXRD model KDS R50XBR1 Sony TV
ANDREW ELECTRONICS 1-800-274-4666 SONY M#8-835-860-31 MOTOR DCSFF21C/C-N $22.31
Posted on Feb 14, 2009
  • 197 Answers
SOURCE: Can't complete fix: Fan won't disengage from "magnets".
replace lamp fan P/N 8-835-860-11
Posted on Jun 09, 2009
How to replace condenser fan blower wheel and where can i get one ?
Hello, in order to replace the condenser fan you will need to remove the motor aseembly and use a hub puller to remove the fan blade. When removing the fan blade spraynsome wd- 40 on the motor shaft and then attach the hub puller to remove the fan blade. You csn buy the fan blade at any heating and cooling store.
May 07, 2012 | Continental Heating & Cooling
Led is flashing red 4 times--replaced lamp--not the problem. How do I check the fans, and how do is get them to work?
the exhasut fan is most likely the culprit. it is the fan directly on the back of the tv on the side that the lamp goes into the tv. u can get a flashlight and look back throught the vent to see if it is spinning after you turn the tv on before it goes into shutdown. if you can get a screwdriver in the slot to spin the fan qucikly after power up it may start again but will most likely just be quick fix and fail again soon. the fan is a 120mm fan part number SFF21C best to get them from sony or at least under sony part number.
Dec 17, 2010 | Sony KDS-R50XBR1 50" HDTV
How to remove fan on a 5.2L engine
Hi, 5.2L Engines
  1. Disconnect the negative battery cable.
  2. The viscous fan drive and blade assembly is threaded into the water pump hub shaft. Remove the fan drive and blade assembly from the water pump by turning the mounting nut counterclockwise as viewed from the front while securing the water pump pulley. Do not remove or unbolt the fan drive and blade at this time.
Fig. : Fan blade and viscous drive (click for zoom)
The threads on the viscous fan drive are right hand threaded.
  1. Remove the 2 fan shroud-to-upper crossmember nuts.
  2. Remove the fan drive, blade and shroud as an assembly.
WARNING Do not place the viscous fan drive in a horizontal position. If stored horizontally, silicone fluid in the viscous fan drive could drain into its bearing assembly and the assembly would have to be replaced.
CAUTION Do not remove the water pump pulley-to-water pump bolts. The pulley is under spring tension.
  1. Remove the 4 bolts securing the fan blade assembly to the viscous fan drive.
To install:
  1. Install the fan blade on the viscous drive. Install the bolts and tighten them to 17 ft. lbs. (23 Nm).
  2. Position the fan shroud, viscous fan and blade into the engine compartment as an assembly.
  3. Position the fan shroud to the radiator. Insert the lower slots of the shroud into the crossmember. Install the upper attaching nuts.
Ensure the upper and lower portions of the fan shroud are firmly connected. All air must flow through the radiator.
  1. Install the fan drive and blade assembly to the water pump shaft and tighten the nut.
Ensure there is at least 1 inch (25mm) between the tips of the fan blades and shroud.
  1. Connect the negative battery cable.
Take care
Aug 04, 2010 | 1993 Jeep Grand Cherokee
Sony KDS-R50XBR1, where can I buy the fan?
online look up sony kds-r50xbr1 or go to a TV repair shop.
Aug 25, 2009 | Televison & Video
KDS-R60XBR1 red light blinks four times when turning on
Replaced fan. Big one in the back p# 883586011 motor,dc sff21c/c-np. the four blinks indicate fan power is nt supplied (ASU board) , fan connector is loose, wires caught in fan ,fan stopped turning.
May 02, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Cannot remove blades
hi! there,
there are two type of removing the blade of electric fan,one is there is a center knob with mark arrow loosen and tight direction at the center holding fan blade, this to lock fan blade on its shafting. to remove fan blade.loosen holder knob on clockwise direction while holding the fan blade,to release the knob check the arrow on the knob. after loosening knob pull out blade from the shafting.
the other type the fan blade has lock in bolt at the back side of the fan blade bolt in on the shafting of the fan, you need here a tools such as set of socket wrench small one to loosen the bolt
after loosening lock in bolt, pull out fan blade.
besure doing this tha electic fan was unplug to elecrtic source. have a nice day.just rate me,thank's
Apr 18, 2009 | Heating & Cooling
Need to take off fan clutch, have taken off parts in the way
4.9L SFI
SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Fan Clutch Holding Tool T84T-6312-C Fan Clutch Nut Wrench T93T-6312-B
Removal
  1. stj~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: The large clutch assembly nut has a right-hand thread and must be rotated counterclockwise to remove it.
    Remove the fan clutch (8A616) from the water pump (8501) by turning the large nut, which is part of the fan clutch, using Fan Clutch Holding Tool T84T-6312-C and Fan Clutch Nut Wrench T93T-6312-B.
  1. Remove two screws retaining fan shroud.
  1. Remove the fan blade (8600), fan clutch and shroud.
  1. If the fan blade and fan clutch have to be separated, remove the remaining bolts attaching the fan blade to the fan clutch
5.0L, 5.8L and 7.5L Engines
Removal
  1. Remove screws retaining fan shroud (8146) to radiator (8005).
  1. Remove four screws retaining clutch on water pump hub.
  1. Pull fan clutch and fan blade off water pump pilot and remove fan clutch, fan blade and shroud from vehicle.
  1. Remove four screws and separate fan clutch from fan blade.
Item Part Number Description 1 8509 Water Pump Pulley 2 57632-S Screw and Washer Assembly, 5/16-18 x .62 Hex 3 8600 Fan Blade (5.0 and 5.8L) 4 8600 Fan Blade (7.5L) 5 8A616 Fan Clutch 6 380288-S2 Screw and Washer Assembly, 5/16-24 x .88 Hex A — 16-24 Nm (12-18 Lb-Ft)
Mar 10, 2009 | 1994 Ford F150 Styleside Supercab
Feb 01, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Removing ceiling fan blades
Wait? Why would you want to remove the blade? Are they broken? Is the fan unbalanced? Try cleaning the blade. If the fan still wobbles, try tightening the screws. If the fan still wobbles, Unscrew the blade and unconnect the blade from blade iron. Buy the new blade iron. If the blade is broken, Also buy the new blade.
Jun 13, 2008 | Angelo Brothers Westinghouse (r) Savona ES...
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
Electro Med Services...
