Question about Consew 206RB
What needles do you use for a Consew 206RB-5 for topstitching jeans very heavy cotton thread? The new designer top stitch. and Can you??Helplindablake@cfl.rr.com
    Sergeant:
  • 333 Answers
Hello Linda, The information I have on the Consew 206RB-5 is that it is a walking foot machine that has a needle system 135X17 also known as DPX17. Needles in that class range in size from 80/12 (narrowest) to 180/24 (widest) However, They do make larger sizes up to 200/25 in a leather point. Keep in mind, the smaller the needle size, the smaller the needle eye is. I make truck tarps out of 18 ounce heavy vinyl. I use a 140/22 size needle with a 138 size thread. As to what you are sewing, I think a midrange size such as 120/19 or 125/25 will do for you. It also depends on the size of thread you use. Good luck, I hope this helps you.
Posted on Feb 21, 2014
2 Suggested Answers
  • 35 Answers
SOURCE: have a new consew, 206RB-5
If you have not already done so, take about 2 arm lengths of thread off your spool to make sure you have not hit a bad spot in the thread. Inspect your needle plate where the needle passes through it and make sure there are no bad nick's or mars on it. If there are use a peice of emery paper to sand them out. Also run a pecice of lighter material through your top tensions discs to make sure no debris has gotten caught in them. Hope this helps you out?
Posted on Feb 10, 2011
Iam sewing seats. but the threed stared braking at the needle & it want saw.
Most likely, it has to do with incompatibility of the needle, thread, and fabric. The force of the needle penetrating the fabric multiple times is actually causing the thread to (wear &) fray and eventually break. There are needles with larger grooves that tend to protect the thread during stitching. Some may recommend a Top Stitch Needle (Home Machine Needles Superior Threads Why Topstitch? The Topstitch needle is the most common needle type used and recommended by professionals and educators. We recommend the Topstitch for piecing, quilting, embroidery, appliqu?, and construction. These needles are available in four sizes to accommodate all thread types, including metallic threads. The Topstitch needle has a larger eye and deeper groove. It is often referred as the MAGIC NEEDLE. It really does make a difference in your sewing experience.)
Why Use Topstitching Needle
Also, if the thread is a tight fit through the needle eye, it will also tear the thread. Make sure that the thread will slip easily through the eye. Go to a larger needle, instead of 90, try a 100.
Be sure to use a brand-new needle.
All About Needles
The Parts of Sewing Machine Needle
You may also consider changing the type of thread you are using. Go with a stronger thread, ie polyester, rather than cotton. Cotton will shred and break easier.
You will probably need to re-adjust the thread tension. If it is too tight, it will also break the thread. If you are using a heavier weight of thread, you will need to adjust both the upper and bobbin tension to accommodate the heavier thread.
Bobbin Tension How and Why Tension is Adjusted
If you sewing fabric that is sticky, ie vinyl, oilcloth, you should try to use a roller presser foot, a teflon presser foot, or a walking foot to help the fabric move with the feed dogs.
Sewing Heavy Fabric with NON Heavy Duty Sewing Machine SEWING IN GENERAL
Tips
Sewing through many thick layers of fabric Sactin
http://www.kollabora.com/q-a/sewing-denim-and-thick-fabric
14 Fantastic Sewing Tricks and Tips Making the World Cuter
How to Sew Upholstery DoItYourself com
Apr 22, 2016 | Sewing Machines
I'm trying to sew jeans hem and stitches are uneven on top and loops are showing underneath. Also the foot and needle will not sew over cross seams and thread keeps getting snarled up underneath. Tha
a lot of machines struggle with denim because it is such a heavy and dense textile. Many domestic machines won't stitch it at all due to this. Things you can try however:
  • Denim needle, this has a deeper groove at the back and is a heavy gauge needle, or use size 110 if you don't have denim needle.
  • Bash the side seams with a hammer in the area you will be stitching, to soften up the fibres.
  • Use a seam jumper, this is a piece of plastic to put in back of the presser foot as you approach a cross seam to help keep the presser foot pressure even across the fabric. Sometimes called a "thingy-a-jean" or similar.
  • Don't bother trying to use the heavy gauge yellow jean thread unless you put it through the bobbin and sew with the right side down. But even then, many machines can't handle having this heavy thread underneath and the regular 50 cotton on top, my Janome 1600 won't do it.
  • put your machine on slowest speed if you have a variable setting and turn the flywheel to assist it through the heavy side seams.
Personally, I never bother with the twice turned hem on denim if shortening, I just overlock the raw edge, turn up 1 cm and stitch around in a matching blue thread so it is seen as little as possible.
Feb 03, 2014 | Elna Sewing Machines
My Thread is shreading and breaking off at the needle site
Change your needle, and try a different type of thread. You may also need to use a larger needle size to allow for the type of thread you're using.
Jan 29, 2014 | Consew 206RB
12 wt thread
12 wt thread generally will not work well in the bobbin...
"Aurifil 12wt Thread
Aurifil 12 wt thread is ideal for hand quilting, big stitch hand quilting and machine quilting. 12 weight thread creates a more defined and often primitive look. It's great for designs that use a longer stitch length if using a machine. When machine quilting with 12 wt thread, use 40 wt in the bobbin, increase your stitch length, lower your tension, use Topstitch size 90 needles and stitch slowly."
May 08, 2017 | Bernina Activa 140
The lower thread does not bring up , so that the uper thread does not come in contact with the lower thread .I hear unusaul noise while sewing.All these happend when I tried to sew a jeans .i used a thread...
As a general rule, domestic machines don't like buttonhole twist, that heavy yellow thread you see on the RTW jeans. Sometimes you can put it through the bobbin but use a regular weight thread on top but this means sewing upside down as you'll want the yellow on top. And lots of machines dont like different weight thread top and bottom so it just makes for awful stitching anyway.
Best solution to top stitch jeans is use a regular weight thread, large size jeans needle but thread up two spools of thread on the top with both threads going through the same needle eye. It still may not solve the problem though.
To your machine, firstly change the needle as it may be bent. Then unthread the machine and manually turn the flywheel through a stitch cycle and listen carefully, if you still hear a noise as the needle touches the rotary hook, you've knocked the timing out. Service man visit time.
Probably if you check the manual, it will say 50 weight thread, and you'll need to stick with that in the future.
Those big industrial sewing machines that they top sew jeans on are very different to a domestic SM, many make a chain stitch or fell the jeans seams and are very heavy duty.
Jun 05, 2011 | Toyota STF17 Sewing Machine
Consew 206rb bending needle
I have three possible solutions:
1. If sewing on heavy fabric or thru several layers, change needle to a larger size.
2. Make sure to let the fabric feed by itself, don't pull on it.
3. Make sure the upper thread is not catching on something (like the end of the spool), this will cause the needle to bend and break.
good luck!
Jan 30, 2009 | Consew 206RB
Thread skips
Well, Hello Kim. Once the Needle for the machine is changed, there is a good possibility of the timing of the stitches being altered and hence the problem.
  •  Firstly, make sure that the needle is in correctly with the scarf of the needle towards the hook. Take the needle plate off and the presser foot off.
  • Turn the handwheel towards you until the needle is in the lowest position, and on the needle bar you will see two lines somewhere near where the needle bar enters the machine.
  • When the needle is in the lowest position, the top line of the two lines should be flush with the body of the machine.
Jan 05, 2009 | Consew 206RB
Thread keep breaking
It might be a burr on the point of the needle.
Oct 10, 2008 | Consew 206RB
Thread tension problem when sewing on heavy fabrics
Sometimes when I need to use heavy thread for top stitching to reinforce a seam that has come undone, I will use the heavy thread on the top and regular thread on the bottom. I haven't tried it the other way around for hemming but I would think it would work. I do not currently have a Bernina.
Jan 15, 2008 | Bernina Artista 180
Consew 206RB Logo
128 people viewed this question
Top Consew Sewing Machines Experts
SewTechWayne
SewTechWayne
Shehu Pro
Shehu Pro
Irene Tulloch
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
