Question about Samsung RF217ACRS Bottom Freezer French Door Refrigerator
Where is the main control board located on the Samsung RF217ACRS?
Where is the main control board located and how do you access it?
    Master:
  • Samsung Master
  • 676 Answers
Check the top of the refrigerator
Posted on Feb 14, 2014
Where is the main control board located on a Samsung model number rf217acrs
On the back behind a protective cover or under the back bottom section enclosed inside a protective cover.
Main Control Board DA41-00695A
Appliance 911 Sea Breeze
Nov 17, 2015 | Samsung Refrigerators
Where is fuse located...part #3601-001197
The part number you provided is invalid--Samsung parts start with DD such as the main board is listed. The main board part number is DD92-00033B. There is no fuse--I've scoured the exploded diagram and parts list--there is a leakage sensor located at the bottom of the unit, directly in the center of the bottom frame. If water is detected, the sensor tells the main board to shut down. The main board is located behind a cover at the base of the dishwasher below the door. You will have to remove the kick panel to access it. WARNING--that main board cover can be tricky to put back on. It's metal, has a relatively sharp edge, and if installed improperly, will cut into the wiring harness--and that will be a BIG oops! Make darn sure you route the wiring harness properly so the cover fits properly without pinching anything(ask me how I know this--and I'm a tech--it can happen to the most experienced person). BTW, did you have a power outage recently? Maybe 3-4 weeks prior to the problem. Outages are notorious for damaging circuit boards. If your unit is totally dead, you might have a blown main board--that's why I gave you the part number. The user interface board(touch panel) is DD92-00037A. The display board is DD92-00038A. I hope I helped you!
Sep 12, 2015 | Samsung DW80F800UWS 24" Stainless Steel...
Samsung tv model P2270hd, every time i turn off tv my stored channels r gone when i turn it back on, i have to do auto store to regain them. i,ve tried reding set up, ive tried to access service menu but...
Main system control memory IC fault. Replace it with same number. The number will be printed on it. This IC can be located very near to the main system control IC at the main board. An 8 solder terminal one. Will look somewhat like this.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 26, 2014 | Samsung Televison & Video
Main control board
Kenmore model number looks like this 795.51313012 90364894-0494-4d01-a2bd-9abc6a90a2c6.jpg
I am here should you need me, Thanks John Tripp Appliance 911
Apr 23, 2014 | Kenmore Refrigerators
Where is reset button on samsung RF217ACRS
There is no reset button per se on the refrigerator. Since this model doesn't come with a water or air filter there is nothing to reset. If there is a problem with the operation you could just unplug the unit for 60 seconds and then plug it back in.
Mar 02, 2014 | Samsung RF217ACRS Bottom Freezer French...
I need to locate and replace a main board on a Samsung RS 67 LASH
Hi, Usual positions are either on the top or behing the panel at the rear of unit on RH side if your facing the back..
Dec 13, 2013 | Samsung RSG257AARS (241 cu ft) Side by...
What's your problem?samsung ln37d550k1fxza repair blown fuses
There is some shorted component/s on the main power regulator section. Locate them and replace.
Aug 24, 2012 | Samsung BN96-23347A Main Board for...
Model RF217ACRS cannot control freezer temp doors were taken off to get fridge into kitchen
Check the electrical connections on upper hinge cover to make sure they're connected properly.
Jul 21, 2011 | Samsung 25.8 Cu. Ft. Side-By-Side...
Mcu and ccu
MCU = Motor Control Unit. A control board that is located in the rear of the washer at the bottom adjacent to the drive motor. Remove the back panel for access.
CCU = Central Control Unit. A control board that is located directly behind the wash tub. This is the main "brain" of the washer. You can access by removing the washer top panel.
Jun 30, 2009 | Washing Machines
LCD controller board location on Vizio L37
Display controller is usually under the Main board which you remove to get access to it. Display controller connects to the suis-boards which then send signal to the screen of the TV.
Mar 17, 2009 | Vizio L37 Television
Samsung RF217ACRS Bottom Freezer French Door Refrigerator Logo
160 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
