Question about Electrolux E30DF74PS Dual Fuel (Electric and Gas) Kitchen Range
Oven door locked
Electric Range oven door will not open
  • Official Brand Answer
  • 4,342 Answers
Good Morning ljm_email, I am happy to assist you!
I understand the door of your Frigidaire range will not unlock. Here are a few simple troubleshooting tips that you need to take:
  • First, locate CLEAR/OFF or CANCEL button.
  • Then press button in for approximately 3-5 seconds.
  • If that does not work, then reset your appliance by either unplugging it or flipping the household circuit breaker. It is necessary to wait roughly ten minutes and then turn your range on.
  • If the abovementioned steps do not resolve your issue, you may wish to contact a professional as your range may possibly have a defective door lock assembly, wiring, or communication problem with the EOC (Electronic Oven Control).
Best of luck!
Posted on Feb 20, 2014
ndguy2481
  • 251 Answers
SOURCE: How to clean lower oven of 30" electric range by electrolux
try a lemon heated and the acid will eat away the food
Posted on Dec 01, 2008
SOURCE: How to set the oven timer?
To Program Oven for a Delayed Start Time and to Shut-Off Automatically 1. Be sure that the clock shows the correct time of day. 2. Place the food in the oven. 3. Push "Bake Time". "00:00" and the words "BAKE TIME" will glow in the display window. 4. Push and hold up or down arrows until the desired baking time appears in the display. 5. After the bake time has been set, "----°" will appear in the display and the word "BAKE" will flash. The display will flash and beep once until the oven temperature has been set. 6. Push "Stop time". The time when baking will stop, will appear in the display window. The words "BAKE STOP TIME" will glow in the display. 7. Push and hold up or down arrows until the time that you want cooking to be completed appears in the display. 8. Push Bake (or Conv). "---°" will appear, and the word "BAKE" will glow in the display. 9. Push and hold up or down arrows until the desired baking temperature appears in the display. 10. If the baking temperature is not set, the control will beep. "---°" will flash and the word "BAKE" will appear in the display.
Posted on Oct 21, 2009
  • 401 Answers
SOURCE: Frigidaire Model ES200 White Electric Range f1
F-1 USUALLY MEENS THE MAIN PCB OR CLOCK ***. I WOULD RECOMEND REMOVING THE POWER AND PULLING IT AWAY FROM THE WALL .TAKE THE BACK PANNEL OFF AND LOOK FOR A BURN MARK. THAT SHOULD SHOW WHAT BLEW.
GOOD LUCK!
ERIC
Posted on Mar 06, 2010
heatman101
  • 43501 Answers
SOURCE: The oven cleaning feathure was
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker
Posted on Jan 05, 2011
  • 246 Answers
SOURCE: oven door will not fully close allowing heat to escape and light stays on
Is the door locked? if it is it won't close all the way if it was in the locked position before it was closed. like if it was programmed for "self clean" without the door being closed, the lock would be engaged still.
Posted on Jun 10, 2012
I get a code f90 when trying to either lock the oven door or attempting to clean the oven
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question####
Jun 26, 2010 | Kenmore 95822 / 95824 / 95829 Electric...
What dose f90 mean
unplug the range.
wait 1 minute.
wait 2 minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@$##%^
Jun 20, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
F93 error code
unplug the range.
wait 1 minute.
wait 2 minutes.
Apr 24, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
Frigidaire FES367FCC. Oven is flashing F90.
unplug the range.
wait 1 minute.
wait 2 minutes.
Apr 11, 2010 | Frigidaire FES367 Electric Kitchen Range
My frigidaire gas range has a F90 on it when I tried the self cleaning oven feature
unplug the range.
wait 1 minute.
wait 2 minutes.
Feb 16, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
F90 code on Fridgidaire range/oven
unplug the range.
wait 1 minute.
wait 2 minutes.
Jan 04, 2010 | Frigidaire FEF352 Electric Kitchen Range
Opened oven door before it could lock while I was
try unplugging the unit,
depending on your exact model it may just be lost in the programming becuse it sensed the door open while locking so it shuts down the lock for safety
just unplugging if for a few minutes might clear the error enough for the lock to rotate back to closed
position
Nov 03, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven door
unplug the range.
wait 1 minute.
wait 2 minutes.
Feb 17, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Kenmore 790 Oven Locking mechanism problem
hold down the stop/clear button for 3+ seconds
Jan 13, 2009 | Kitchen Ranges
After using my electric range self cleaning oven an f90err appeared and the door will not open. I would really like to cook my new years dinner .Can you help please ?
unplug the range.
wait 1 minute.
wait 2 minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#$%^
Dec 31, 2008 | Kenmore 96212 / 96214 / 96219 Electric...
Electrolux E30DF74PS Dual Fuel (Electric and Gas) Kitchen Range Logo
97 people viewed this question
Top Electrolux Kitchen Ranges Experts
Rommel Balcita
Mike Henne
Level 1 Expert
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
