Question about RTO Sole F80 Treadmill
Sole F80 Treadmill squeaks
Between Incline 0-3 there's a loud squeak coming from the front near the motor. This is independent of speed. When incline is 4 and above, there's no squeak.
5 Suggested Answers
SOURCE: Brand new Sole F85 incline shows e2 and stops
Same thing happens to me. Any solutions?
Posted on Dec 04, 2010
  • 586 Answers
SOURCE: my sole f83 treadmill is
Hello there,
When the treadmill remains in 0% incline and then comes up with a message showing elevation error, it is quite clear that there is a problem with the treadmill and the problem is related with the mechanism that controls the elevation of the treadmill.
The mechanism responsible for the elevation of the treadmill is some hinges that are located in the lower front part of the treadmill. They are weak and cannot lift up the treadmill anymore.
The solution is for you to have them replaced, then you turn on the treadmill, then you press the incline control key and it will increase in % this time.
Hope this helped. Goodluck Elect_Comp
Posted on Aug 26, 2011
ercupa190
  • 12223 Answers
SOURCE: My Sole F80 deck bounces excessivly when not at an incline.
1) Lube the deck belt, this problem is lack of maintenance, maybe the deck belt is worn.
2) You must align the deck belt see the diagram
3) Lube the rollers bearing very well very important too
see the video: God bless you
Posted on May 15, 2012
ercupa190
  • 12223 Answers
SOURCE: My control panel on the Sole F80 Treadmill lights up but nothing I press works
adjust the REED SWITCH, see the diagram attached, clean it and tight the wires connector very well.
tight the ribbon cables insides from keypads +tight the wires connector from display board vs lower board and clean it.
God bless you
Posted on Jul 23, 2012
Sole f60 incline error E2
does the incline work at all. if not try to calibrate the incline. if this fails something could be wrong with the incline motor
Oct 20, 2014 | Sole Fitness Sole F63 Treadmill
Incline comes up and down
please RUN the software calibration for easy diagnose , troubleshooting, and fix it.
However you must see the diagram attached, and test the relais+motor for dirty, or faulty.
God bless you
Dec 07, 2012 | Sole Fitness Sole F80 Treadmill 2011 Model...
Incline displays e2 code
adjust the speed sensor, test it, clean it, and tight the plug or connector very well.
2) Test the input voltage motor, if there are the motor need repair.
3) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Nov 29, 2012 | RTO Sole F80 Treadmill
God bless you
Jul 22, 2012 | RTO Sole F80 Treadmill
May 15, 2012 | RTO Sole F80 Treadmill
When standing on treadmill, if incline # ie:5 is entered, bed raises, pauses, then lowers back down while #5 continues to be indicated. this occurs with all incline #s but not a problem if I'm not sta
If your incline is not working it can be a few different things.
1)There may not be any signal from the console which could be a damaged cable tight the flexible cable vs keypanel( spray too with contact cleaner spray) vs display board.
2) the console itself has failed :tigh the connector comming to lower board (main motor controller board).
3)The motor control board may have failed from a worn treadmill belt and deck(exchange it) Test if the Voltage with DVOM is there present 120VAC
4) the motor may have burnt out Test the motor with 120VAC.
5)also a potentiometer geared to the motor so the console knows what height the incline is at ADJUST IT.
6) the gearing can slip, giving the console false information which can cause chassis damage FAULTY.
12_7_2011_6_27_57_pm.gifNow with the block diagram you will have strong resultant for determine what is wrong. This I did for people like you, and to know how the main motor board controls functions by 90% aprox of any treadmills. sincerely.
E.CUADR
MANAGUA, NICARAGUA. C.A
Dec 07, 2011 | RTO Sole F80 Treadmill
Treadmill will incline but not stay up. incline # stays after bed lowers
incline Motor is not working it can be a few different things.
1) may not be any signal from the console which could be a damaged cable(tight the flexible cable from keypanel vs display board)
2) Tight the connector from display board vs lower board ( main motor controller board the console itself has failed.
3) The motor control board may have failed from a worn treadmill belt and deck measure 120VAC input for the board
5) the motor may have burnt out Test try to measure 120VAC.
6) potentiometer geared to the motor adjust it so the console knows what height the incline is at.
7) the gearing can slip, giving the console false information which can cause chassis damage.
Now see the block diagaram that I did , for person like you, for to know how the main motor board has aprox 90% of functions of any treadmills. sincerely. Good luck, G-d bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Dec 07, 2011 | Sole Fitness F80 Treadmill
Treadmill squeaks
There's a special silicone-based treadmill lubricant that you put between the belt and rollers See this treadmill accessory kit
Jun 24, 2010 | Proform CrossWalk TreadSoft Treadmill
RTO Sole F80 Treadmill Logo
343 people viewed this question
Top RTO Exercise & Fitness Experts
Jim London
Jim London
Howard
Howard
Jax Planet
Jax Planet
Are you a RTO Exercise and Fitnes Expert? Answer questions, earn points and help others
