Question about Toshiba 44NHM84 44" TV
THE OPERATION INDICATOR LIGHT FLASHES GREEN CONSTANTLY AND NO SOUND OR PICTURE
I HAVE CHANGED THE LAMP AND THE LIGHT ENGINE, IT WORKED BEAUTIFULLY. THE NEXT TIME WE TURNED IT ON THIS IS WHAT WE GOT
    Top Expert:
  • Toshiba Master
  • 74,383 Answers
These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating, to many popular brand TVs and other devices.Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Posted on Feb 12, 2014
  • frontierpaul
    frontierpaul Feb 12, 2014
    The light FLASHES CONSTANTLY AND WILL GO FOR HOURS IF I LET IT
3 Suggested Answers
daniel719
  • 240 Answers
SOURCE: power light flashing. No picture.
you have a shorted CRT
cathode ray tude.
if yoiu are a electronics tech do this
if not you run a high risk of electro shoch and posibil deth.
this is for tech only to do.
Unsolder resistor r902 going to green crt gun on socket.
atach a test clip to positive side of c909 (200 Volts) turn on tv set briefly toching other end clip to green gun pin on crt socket
this will remove the short in pictor tube and get you a bit mor life out of it.
regards,
daniel
PS if your not a tech do not try this method a q tech is best for the job.
Posted on Jan 12, 2009
jan mczeal
  • 632 Answers
SOURCE: I had a bad lamp and replaced it.There wasno
Make sure that the lamp is put in place correctly. Ensure that the lamp cover is securely installed. Review your installation then reinstall.
Posted on Sep 24, 2009
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
No Picture, but sound for a minute, then shuts off
I think your Display card not proper work so please contact LG Technician.
Thanks.
Feb 17, 2014 | LG RU-44SZ61D 44" TV
I have the 60 inch mitsubishi dlp. There was a sound just like a light bulb going out. Then there was no picture or sound. I replaced the lamp and still no picture or sound. I hear clicks when trying to...
If the status led is blinking yellow its indicating that the filter cover on the side is open. If its the lamp indicator thats blinking yellow its indicating the lamp door cover isnt attached properly.
Sep 24, 2011 | Mitsubishi WD-52825 52" Rear Projection...
When you turn of the TV the POWER indicator flashes green for several minutes. The TV never comes on. After the several minutes of the POWER indicator flashing green, it stops, I hear a click and the...
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
May 11, 2011 | Panasonic PT-52LCX66 Projection Television
My sony grand wega 55 constantly will turn off picture and sound, green lamp light stays green and then after about 30 seconds the picture and sound return, it has the original bulb in the tv and is around...
The LED light "LAMP" indication stay on or flashes in this problems?Yes,the projection lamp is the causes and problems.Change the projection lamp,should solved the problems.
Jan 30, 2011 | Sony KDF-E55A20 55 in. LCD Television
KDS-R60XBR1 no sound no picture continuous green flashing a pause 6 green flashes then continuous red flashes from the lamp indicator. Is it the lamp or something else?
It is lamp that is dead/ broken, replace lamp to get back tv in working.
Lamp replacement procedure is written in user manual and its easy.
Thanks.
May 11, 2010 | Televison & Video
No Picture - Lamp Indicator Blinking
This may be the main power supply, or the lamp supply. This is providing that the new lamp is okay.
The service tech will swap out the modules to service the set.
Jerry G.
May 15, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Panasonic PT 50LC14 problem
You have to close the lamp door. It has a switch in it much like a clothes dryer door in that when it is open it wont operate.
Feb 23, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Toshiba 44NHM84 44" TV Logo
81 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
