Question about Delta 1310049 Chuck
Jaws stuck on drill press chuck
Jaws stuck
3 Suggested Answers
  • 5603 Answers
SOURCE: Where can I buy a new chuck for my 15-091 dp?
You cn find MANY chucks on eBay. You need to verify the size and the mounting which is LIKELY a Morse taper. ONLY buy new ones. There are some for as low as $8.
Prefered brand is "Jacob's".
Posted on Jul 16, 2010
  • 885 Answers
SOURCE: I just bought a used DP200 Delta drill press. The chuck seems to be locked up in the closed position. I want to try to open and insert a bit, but am afraid of breaking something.
If it's locked up that tight the only thing you can do is turn the key as hard as you can until it either breaks free and works or just plain breaks. If it breaks free, spray a bunch of WD40 or like lubricant up into it, cycle the chuck to full open and full closed a few times to let it soak in then blow it out. If it's working freely throughout the travel and not sticking it should be OK. If it broke while trying to open, sticks while cycling it or just plain won't open, replace it. You need part number 1310049 from Delta to replace it (shop the internet for one). The chuck is just pressed on to the tapered spindle so you have to extend the spindle all the way down and hit the top of chuck, sometimes hard depending on how long it's been on there.
Posted on Dec 30, 2011
Ryobi 18v drill keyless chuck stuck
Try holding the bit in a vice and gently tap the chuck off of the bit and see it it releases the pressure on the jaws.
Jun 20, 2012 | Ryobi 18v Cordless Drill - P206 18 Volt V
I have a skill 18v drill and the chuck jaws that hold the bit has one stuck down and two even, i have taken off the chuck but was wondering how to disassemble the chuck itself or if there is another way to...
Lube the chuck with some penetrating oil and bring the two loose jaws near the surface. Take a brass or soft hammer and pound the face. The stuck jaw should come down. They have a spring to push them down, but sometimes grits or other contamination causes them to stick.
Apr 26, 2011 | Next Generation Power Engineering Skil 18V...
Chuck is stuck open thank model973227070
Try spraying WD40 or similar into jaws of chuck and alow a couple of minutes for it to penetrate before trying to close it.
Also use cloths on the chuck while tightening to get a better grip.
Feb 27, 2011 | Craftsman 3/8" Corded Drill
Bosch keyless chuck stuck
Make sure you try it in both directions.
Apr 18, 2010 | Black & Decker 3/8" Variable Speed...
Bit tighten stuck open
If you mean the chuck jaws seem stuck open, spray around them with some penetrating oil or spray like WD-40, RP-7 or similar and let sit for a couple hours... Then you can tap around the chuck body with a light hammer or spanner etc... just lightly tap... Then if the chuck has an arbor lock to prevcent it from spinning, be sure that is engaged then try to release the chuck jaws. Sounds like they are stuck open through tight friction or rusting on the inside edges (that you dont see). Be careful not to leave them in the fully open position when stored as this is exactly what can happen!
Mar 31, 2010 | Makita 6304LR 1/2" Chuck Electric Drills
Keyless chuck is stuck open
That can happen if the jaws inside the chuck, usually 3 triangular pieces get jammed together. With chuck facing down tap chuck several times to loosen jaws. If that doesn't work spray a small amount of WD-40 into chuck and try again
Feb 23, 2010 | Garden
How do I attach the drill bit to the chuck on a ss 120 drill
Well I couldn't find a pix of your drill so I will guess that it is a typical drill. You seem to be asking a very basic question so I will start will all the basic info I can think of.
First you have to know where the power trigger is to make it go.
2nd you have to know where the forward and reverse switch is.
Now with the switch in the forward position squeeze the trigger to make it go. Then gently grab the chuck with your hand while it is going and the center Jaws should close up and come out of the chuck.
Now with the switch in the reverse position squeeze the trigger to make it go. Then gently grab the chuck with your hand while it is going and the cetner Jaws should open up and go into the chuck to a maximum point
Open the jaws enough to put the drill in the jaws then put the switch in the forward position. Put the drill in the chuck, sqeeze the trigger to make it go, and hold the chuck so the jaws close on the drill. All while keeping the drill from falling out of the chuck.
When it closes on the drill and the drill is in straight then hold the chuck as tight as you can while squeezing the trigger to make the jaws close very tightly on the drill. If you have very tender hands you might want to use gloves.
To get the drill out put the switch in reverse, hold the chuck very tightly, and squeeze the trigger to open the jaws off of the drill.
Nov 28, 2009 | Black & Decker Drills
Keyless chuck grip is stripped inside and the chuck is stuck in a tightened position. Can I get a replacement chuck grip and how do I get the chuck assembly off the drill, if that's necessary ?
second question first. No you cant just buy the grip, you have to buy a replacement chuck, shop around for best price, second you have to get the jaws opened up to remove, couple different ways, but first go to Dewaltservicenet.com and type in your model number for a parts explosion. Next if the grip is damaged can you put a pair of pliers on it and turn the collar to loosen it? the jaws have to be retracted to remove the chuck screw (LH threads), what you need to do now is put the drill in the drill only position and the tool in low range. Find a bent handle allen wrench and lock in the jaws, put the chuck on a bench or block of wood and wrench at about a 30 degree angle to strike it counter clockwise, you might have to hit a couple time but this will work. Let me know if I can help further.
Sep 07, 2009 | Dewalt Drills
My dc927 chuck is jammed fully open and won't move. How can I lossen it. Regards George
Something I would try:
George, look down the center of the chuck jaws with a bright light. It's going to be difficult to see, but there is an Allen head screw down in there.
Taking the screw out, will afford you the opportunity to remove the chuck from the drill. The drill should have a slightly tapered shaft, and the chuck has a tapered hole to match. It might be stuck on tight. Tap on the back side of the chuck, with a wooden block, and hammer.
(Yes, this may require a helper)
Tap on one side, then the other to try to remove the chuck evenly.
With the chuck off it may release pressure on the jaws. It may not.
In this case the chuck will have to be opened up, (Which will release pressure on the jaws), and the jaws reset.
Aug 22, 2009 | Dewalt 18 Volt Compact Drill Kit
Chuck will not release bit
the Chuck should be 2 Part.
Use 2 pair of stillsons Or pipe wrenches, Tight On the 2 Chuck Parts, Crack in opposite Directions.
Alternative, Use Wrench On Chuck Jaw, Short sharp Blow With Hammer.
Mike @ compurepair.
Feb 28, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Delta 1310049 Chuck Logo
42 people viewed this question
Top Delta Drills Experts
Bill Boyd
pete musca
pete musca
Level 1 Expert
Are you a Delta Drill Expert? Answer questions, earn points and help others
