Question about Onkyo TX-SR600 Receiver
Bi-amp tx-sr600 how can it be done properly
SOURCE: My Tx-sr600 shuts off when watching movies at level 65
first try unpluging it for an hour from the socket
2.if that doesnt work try toggling your eq button on the remote control trying it on then trying it off
3.if that does not work try with the cenima button on then try with it off
4. if that doesnt work try changing the cross over frequency to a lower output
5. if that doesnt work try lower the decibals going to each speaker if you follow this you should either fix the problem or increase the intravel time in it cutting off
Posted on May 07, 2008
easyq
  • 144 Answers
SOURCE: TX-SR506 Bi-Amping
If you select bi-amping the device will use a second amp for your rear speakers, this indicates that in your setup menu you probably have deleted the rears (set to None). Try to find the settings for your rear speaker in your setupmenu and see if they are selected in normal operation.
If all fails, see if you can reset teh device back to factory settings, sometimes software can get confused after using for a while. Resetting should than fix most problems.
You can also check and see if there is maybe a software update available for your device, loading and installing is explained in either the file or on manufacturers site.
Posted on Apr 17, 2009
  • 7 Answers
SOURCE: subwoofer not working on onkyo tx-sr600
Have you connected the Subwoofer out to the "Pre-out Subwoofer" on the left bottom corner jack(looking from the back)?
Have you set subwoofer out in the menu(under speaker settings or similar menu you will find all the channels that you have connected and here you should have "YES" for the subwoofer)?
HTH
Posted on Aug 12, 2009
Grubhead
  • 5126 Answers
SOURCE: Can I play my ipod through my Onkyo TX-SR600 receiver?
All you have to do is get a 3.5mm plug to two RCA plugs lead and plug the 3.5 Jack in the headphone socket of your ipod and the two RCA's into an aux imput and away you go. If you get one of the small docks, that will stop the battery running down, but you don't need one.
By the look of the picture on FixYa it looks the RCA's can go in the front socket under the volume control.
Posted on Mar 30, 2010
Testimonial: "Thanks so much. Great solution."
Grubhead
  • 5126 Answers
SOURCE: I have an Onkyo TX-SR806 receiver, that won't play
Don't know if it applies to your model but on my 607 it says Zone 2 won't work if Bi-amp is being used!
Posted on Jun 14, 2010
Onkyo sr600 memory problem
I had the same problem with my TX-SR601 receiver.
Solution: I changed the capacitor C766 (100uF/6,3V) on the "DSP and main microprocessor" or "U1" board. This capacitor is responsible to keep the settings in the memory. It is directly next to the SRAM ICs (Q705-706) (type: CY7C1019BV/CV33-15VCT).
Now the receiver works properly again.
Mar 04, 2012 | Onkyo TX-SR601 Receiver
How do I reset from the amp protect mode Onkyo receiver TX-SR600?
How do I reset my amp / receiver from protect mode ?
May 07, 2010 | Onkyo TX-SR605 Receiver
Mar 30, 2010 | Onkyo TX-SR600 Receiver
Onkyo tx-sr601 bi wire with zone 2
SMCCARTY,
The idea behind bi-wiring speakers is to get the highest quality of sound by getting the sound from two separate sources doing separate jobs. Lower frequencies are harder for an amplifier to produce than higher frequencies. So it is common to give these frequencies to two different amplifiers so each can produce the highest quality of sound. By removing the low end from the top end amplifier, it provides the top end amp more headroom thus reducing the chances of clipping. Clipping can easily be heard from the tweeters destoying not only the sound but your speakers as well. It is common practice in pro and car audio to use separate amps for subbass, low, mid and high; four amps working together to their corresponding drivers (more or less depending on the system and type of audio being produced).
In your case, getting the two different sources from basically the same amp (power supply), would not accomplish the full intent of bi-wiring; it would just make more wiring for the same end result. However still a good thought on your end. Onkyo receivers are great because of their beefy power supplies. Not very many other brands have such strong power supplies. Denon's are close but not equal.
Chris-
Feb 14, 2010 | Onkyo TX-SR601 Receiver
TX-SR600 remote sensor no longer works. The remote still works with other devices...so I suspect the sensor in the A/V receiver.
The remote sensor is part# 241341 or 241335. On the front board its marked U7501.Some times initializing the unit will restore normal operation. Althougth afterwards you will have to re prgramm all your settings and presets. While on hold down the VIDEO 1 button while pressing the power button. The display will read "CLEAR".
Dec 31, 2009 | Onkyo TX-SR803 Receiver
Subwoofer not working on onkyo tx-sr600
HTH
Jan 16, 2009 | Onkyo TX-SR600 Receiver
Low Volume regardless of input
Front L/R and Surr back L/R are the termianls used for BI-amping
Check page 27 of the manaul
http://www.onkyousa.com/download/own_manuals.cfm?cat=Receiver
you can find it here
Dec 24, 2008 | Onkyo TX-NR905 Receiver
TX-SR506 Bi-Amping
Sep 15, 2008 | Onkyo TX-SR506 Receiver
Distorted right channel
There is a problem in the pre-amp section of the receiver. This is most likely a bad transistor. FIgure on about $5-$15 for parts for this repair.
Dan
Sep 11, 2008 | Onkyo TX-SR600 Receiver
Onkyo TX-SR600 Receiver Logo
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
