Question about Panasonic SD-YD250 Bread Maker
Will not come out of rest
Programed for multi gain bread and bake, hit start and waited for it to start. several hours
How can I get the machine to start the bread making process from the beginning. It is currently stuck on knead.
Do you have your owners manual and have you baked bread in your machine before? Just want to be sure that you know the stages that the machine goes through. The first mixing and kneading stage in a tr444 will take up to 15 minutes before it stops on its own. It will then let the dough rest for about 1/2 hour before the 2nd knead begins. It takes almost 4 hours for your machine to go through all the stages before your baked bread is finished.
Jan 15, 2015 | Breadman TR444 Bread Maker
In the middle of baking cycle kneading starts for a little while and damages the loaf. How to fix this programm error?
Most bread machines do a little "punch down" before the final bake stage. The bake stage doesn't really begin until after the final 4-10 seconds of "punch down". Then the bake stage really begins and lasts about one hour.
Apr 01, 2013 | Black & Decker B2300 Bread Machine
Breadman ultra tr700 did not bake the bread
The whole process takes 3-4 hours to complete. Did you give it that much time? Next time note how many hours are on the readout just before you push "START" and let the machine countdown to 0:00 on the clock before you assume something is wrong. If you did that last time and the bread wasn't baked then your machine is broken.
Feb 10, 2013 | Breadman Kitchen Appliances - Others
Breadmaker stopped and bread not baked
It usually isn't worth it to try to repair a bread machine and yours does sound like the eletronics have gone bad. I have several good machines for sale at very reasonable prices. contact me at breadmachineshelp.com if you are interested in replacing your k6725
Sep 30, 2012 | Regal Ware K6745S Kitchen Pro Bread Maker
How do I turn off the delay timer? When I set it up, the timer automatically sets it on a 3 hour delay. I have moved the up & down arrows but it won't set at 00:00 unless I unplug it. Then I set...
No offense intended but you need to step away and read the instruction manual step-by-step. One point I can make: The three hours you're seeing in the display when you first plug the unit in are simply telling you how long the default white bread mode is going to take to complete. It's merely a counter that counts down so at any time you glance over at the machine you'll know how much longer it's going to be before the bread is finished. The digital display has NOTHING to do with the delay timer until you start pressing delay timer arrows.
Hope this helps!
Jun 20, 2011 | Breadman TR777C Bread Maker
I just baked one loaf, and was readying the 2nd loaf, entered settings, hit start and got this: "E:01" What do I do?
That is a temperature warning that is an automatic feature on bread machines. What the machine is telling you is that the oven chamber is still too hot from baking the last loaf. It does that to prevent you from starting another loaf and having that loaf fail due to the high heat killing the yeast. If you want to bake more than one loaf unplug the machine after baking the first one, raise the lid, and leave it open for no less than 20 minutes. It should work fine by then. If not let it cool off another 10 minutes. It will be cool enough by ½ an hour to start another one.
Mar 26, 2011 | Breadman TR555 Deluxe Rapid Cool Touch...
I just bought your breadmaker B2200 and i am looking for recipes for a basic white and whole wheat bread.The booklet does not have basic recipes. I am looking forward to baking bread for a long time to...
Basic White
1 1/3 cups lukewarm water
2 tablespoons powdered milk
1 1/2 teaspoons salt
1 tablespoon sugar
2 tablespoons butter or margarine
3 3/4 cups white flour
1 teaspoon yeast
1. Measure ingredients in the order listed into Baking Pan.
2. Insert Baking Pan securely into unit; close lid.
3. Select BASIC setting and 2.0 lb. loaf setting. Choose LIGHT or DARK crust setting.
4. Push Start button. There will be a 15-minute preheat delay before mixing begins.
5. The Complete Signal will sound when bread is done.
6. Using pot holders, remove Baking Pan from the unit and carefully turn bread out of Baking Pan. (Mixing paddle may remain in bread. Remove paddle when load if cool.)
7. Allow to cool before slicing.
Time 3:50 hours
100% Whole Wheat
1 1/2 cups lukewarm water
2 tablespoons powered milk
2 tablespoons honey
2 tablespoons molasses
3 3/4 cups whole wheat flour
1 3/4 teaspoons yeast
2. Insert Baking Pan security into unit; close lid.
3. Select GRAIN setting and 1.5lb. loaf setting.
4. Push Start button. There will be a 25-minute preheat delay before mixing begins.
Time: 4.10 hours
Feb 19, 2011 | Black & Decker Bread Machine
Break starts to fall at start of baking
the bread machine needs the dough then rests and the needs agian just before the baking progam
Dec 24, 2010 | Oster 5838 ExpressBake Bread Maker
My White Westinghouse Automatic Bread Machine sits for over 1/2 hour before it starts to combine the ingredients by turning. Then it turns for over 1/2 an hour and does not seem to stop to let the bread...
Hi fellow bread maker! Can you tell me which program you are using. Basic, whole wheat, sweet bread etc.?? Based on what you describe I think you may be choosing the whole wheat cycle because the stages you describe are almost exactly what my Toastmster does if I choose the whole wheat cycle. Hope this helps....
Oct 17, 2010 | Westinghouse Kitchen Appliances - Others
Panasonic SD-YD250 Bread Maker Logo
83 people viewed this question
Top Panasonic Kitchen Appliances - Others Experts
Irene Tulloch
Oloyede Monsuru
Are you a Panasonic Kitchen Appliances - Other Expert? Answer questions, earn points and help others
