PACE ATT 5031NV FACTORY RESET - Computers & Internet
Have a new Pace Gateway modem from ATT.Works ok for awhile then "Service"light turns red and have unplug,reset,plug back in.What can it be?
Contact your provider and ask them to do a
( hard )reset
Also check your cords and cables to see if they are damaged
also confirm your connections are clean and contacting
Happy repairs
Apr 12, 2014 | Computers & Internet
I need the URL to access my Att PACE DSL Gateway Model 4111N Using an ip adress won't work
I have the at&t Troubleshoot and Resolve Tool Installed on my computer that allows me to access my Pace Modem/Router.
Aug 17, 2013 | Computers & Internet
Passcode
Passkey is created by the user & not by the manufacturer,if ur phone is unable to connect via bluetooth try doing factory reset.
Resetting your phone will wipe out your data, so be sure you have it recorded elsewhere.
Mar 17, 2013 | ZTE Att Z331
Mm#6 error on samsung galaxy s3
Does it come up at all? Have you tried to factory reset it?
Feb 08, 2013 | Samsung Galaxy SIII S3 SGH-I747 White ATT...
Will a factory reset on an unlocked ATT sharp Fx cell phone lock it?
No.
Unlock usually means the phone is unlocked for different sim cards by different companies. For example, I have an ATTphone and I unlocked it for use on Tmobile network. Also, applies for taking your phone to another country to use their cellphone network providers.
Factory reset only changes the DATA of apps, user settings, phonecalls, messages, etc.
Unlock is not connected to that portion of control for factory reset.
Jan 14, 2013 | Sharp TM-150 Cellular Phone
Need to reregister att tl86009 with new base
The secret decoder key sequence, provided by AT&T tech support, to factory reset this handset is:
(right softkey "-") * 3 3 1 7 3 4 # (left softkey "-")
The handset they should beep and go into registration mode.
Oct 04, 2012 | AT&T ATT TL86009 Phone
Hi, We have lost a lot of channels on our Pace dv3 digibox during the digital switchover in our area. Most of the advice I can find online is for a Sky+ digibox, rather than ours. Ours is just a 'Pace...
normally a factory reset would work other than that have you tried just re-scanning it as that would normally pick up channels that have been lost
Apr 22, 2011 | Televison & Video
Need Viore code for ATT-U-Verse remote.
I tried every code suggested for my Viore with Uverse and nothing worked. Finally decided to reset the remote to factory settings using code 900 as described in the instructions from ATT uverse. The remote now works on my Viore tv and all I did was reset the remote to factory settings.
May 17, 2010 | Toymax Viore 42 in. Plasma TV
I have lost the pace function since I have added cadence device
Not sure if this will help as I haven't tried it but I found on the internet if they lock up you can "reset" the device by holding MODE and powering ON at the same time (Push mode first). By "reseting" I am unsure if it puts everything back to factory settings, I am inclined to think so. BUT FIRST back up everything to PC as I'm sure all info will be lost on the unit.
Mar 28, 2009 | Garmin Forerunner 305 GPS Receiver
Will re-setting bb bold to factory settings delete my downloads?
Yes sir! A "Hard Reset" will COMPLETELY reset the all interface back to factory default.
If you use the Blackberry Desktop Software you can easily, back all your data first, then initially "hard reset" the device. After you have performed the necessary steps you can restore all your data.
Hope this helps!
Mar 19, 2009 | RIM BlackBerry Bold Smartphone
Computers & Internet Logo
202 people viewed this question
David Payne
David Payne
