Release button started popping seems out of balance
When the laminator is turned on the release button starts to jump and make a loud click sound. What is going on? And How can I fix it?
  • 49 Answers
SOURCE: Loud Popping Sounds
If this is a heat pump system it is possible that your fan blade is hitting ice on your condenser coil.
Posted on Nov 18, 2007
bbtoast
  • 319 Answers
SOURCE: Maytag Range MER5875QAS Problem
You may have a serious electrical problem. Or you may need a new element.
Please provide more info as to the source/location of the smoke.
Brian
Posted on Jan 19, 2008
  • 179 Answers
SOURCE: My DLP TV made a loud popping sound then went off
first. unplug the set for 5 minutes and see if it will reboot. if it does not the you have 2 problems, the chassis is also bad. next open the lamp door cover, it is behind the speaker grill, and behind the lamp door.
take out the lamp and see if it has broken on the inside if it has it needs to be replaced. mits will send you one i believe it is about 100.00 the number is 915P020010. if the lamp looks ok then the color wheel has probably fallen apart.if this is the case the light engine need to be repaired. check out www.tv-techs.com
Posted on Dec 31, 2008
shinn8
  • 85 Answers
SOURCE: Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
Posted on May 27, 2009
teddquinlan
  • 30 Answers
SOURCE: 2005 Altima won't start, hear clicking sound coming from fuse box,key stuck in ingintion,won;t turn over,tried to jump start.
the clicking that you hear is coming from the starter relay. sounds like your ignition starter switch or ignition lock cylinder is bad.
Posted on May 30, 2012
While driving a 96 chevy astro mini van I heard a popping sound and then the engine cut off and won't start again. When you try and start it the engine shakes, why is this
Sounds like you timing has jumped. Set the balancer at the 0 mark. take the distributor cap off. The rotor button should be at #1 position or 180 degrees off that. Any other place , the timing jumped.
Mar 22, 2015 | 1996 Chevrolet Astro
How do i get my Fellowes Venus 125 Laminator 5215901 to stop bleeping and heat up ?
Unfortunately, this message was posted in the section for paper shredders. If you still need an answer you will need to repost it.
Jul 16, 2014 | Fellowes Venus 125 Laminator 5215901
Scotch Thermal Laminator not heating up.
well it sounds like you may have cut a wire or pull one somewhere. i would go ahead and take it apart carefully and check everything. may have unplugged something hopfully! let me know whwat happens!
Jan 31, 2014 | 3M TL902VP Scotch 9" Thermal Laminator...
SMOKE COMING FROM DASH, LOUD POP. CAR WONT START. IT TURNS OVER BUT WONTS START 92 DIAMANTE
if its smoking thats a shorted system..if you feel safe with fixing it do so otherwise get rid of that deathtrap..
Dec 25, 2013 | 1992 Mitsubishi Diamante
2005 Mazda 3 won't start; when I turn the ignition the dashboard lights flicker and a loud clicking sound occurs
the battery is low on power. the lights will still light for a bit longer but your engine needs more cranking amps to turn it over. The clicking sound is your starter without enough power. Have someone help you jump the car. or if you have a manual transmission, get the car moving 5mph+ somehow (push or hill) and pop the clutch out with the keys in the ignition in the "on" position. your car will start right up. if your car regularly needs jumped you probably have a bad battery. if your car looses power while driving you have a bad alternator.
May 03, 2011 | 2005 Mazda 3
I have a Kenmore Elite Dryer Model 110.66992500 that will not start. When the start button is pushed, it only makes a click. During the last use, the dryer was working fine then all of a sudden while...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 01, 2011 | Kenmore Elite HE4 Electric Dryer
2003 325i started to turn over slowly today, and now it does not
sounds like it might be a bad connection on the starter try jumping the starter and see if it turns over
Apr 15, 2010 | 2003 BMW 325
Won't turn over
The whirring sound may be coming from the starter. You can have it tested at Autozone to see whether or not the starter is operational. If it's not the starter, I would try to start the vehicle in another gear other than park or neutral. If it starts, you have a bad Neutral Safety Switch. If this part goes out, it can shut off the starting capabilities.
Sep 10, 2009 | 2001 Dodge Intrepid
2001 ducati 750ss wont start
does it start and run when you jump start it? if so, you probable need a higher cranking battery. sounds like the battery isnt powerfull enough.
May 20, 2009 | 2001 Ducati 750 SS i.e. N-C
18 people viewed this question
k24674
