Question about Panasonic PT-61DLX76 Television
Panasonic PT-61DLX76 had a buzzing sound prior to going dead. Now blinks red twice
The TV had been making a whiring noise for while prior to going dead (no sound/no picture) yesterday. I am trying to see if there is a code list for the blinking lights on the front of the TV. My light currently blinks red 2 times every 5 seconds. If I do a reset (holding power button down 10 seconds or so) and then try to restart it, the power button flashes green (like normal), the "iris" light lights up blue (like normal) but then the power light goes red and goes into the flash twice sequence. Any help would be appreciated.
  • 59 Answers
SOURCE: PT-60LC13
there are fans inside tv need to make sure they are clean and free of dust
Posted on Feb 05, 2008
Slinteriors
  • 8617 Answers
SOURCE: panasonic pt-53wx53g tries to turn on but goes right off
That is indicating that the convergence circuits have shutdown the set. You will need new Convergence ICs. They should be STK392-110 or STK392-120 either number works the 120 being the better chip. I will post a link where you can get the new ICs and they provide step by step instructions with pics so you can do the repair yourself. You will find your IC numbers under the section titled Convergence ICs just click on that and you will find your STK numbers.
http://servicemanuals.vstore.ca/
Posted on Mar 30, 2008
SOURCE: Panasonic Rear Projection TV PT-47WXC43
I have a Panasonic PT-47WXC43 47 in Rear Projection. It went off, on picture, no sound.
Posted on Oct 11, 2008
djchillsnyc
  • 152 Answers
SOURCE: The tv wont turn on
hello 2 blinks on this tv means you have this issue below
PT-44LCX65
2 blinks 5 secs you have your lamp cover open
check for this
hope this helps
Posted on Dec 14, 2008
PCCCTech
SOURCE: Panasonic PT-56LCZ70 no picture or sound
My name is Jonathan and I am an employee at the Panasonic Customer Call Center. Based on the symptoms you've described, I'd recommend contacting the Panasonic Customer Call Center at 1-800-211-7262 for assistance. We are here to help customers that have purchased (or are considering purchasing) our products and would like to assist you with resolving the symptoms described here. Our hours of operation are:
Mon - Fri, 9 AM - 9 PM EST
Sat - Sun, 10 AM - 7 PM EST
Posted on Jan 22, 2009
Panasonic PT-61DLX76 tv power indicator light blinking orange 2X. Manual says it is malfunction 2. What is that and can I fix it myself?
That doesn't sound like something you can fix yourself. At a hunch I would suspect power supply board faulty.
Around £40 for a repair place to look at it, or bin (ebay) it.
Sep 07, 2015 | Panasonic PT-61DLX76 Television
Panasonic pt53wx42f
This sounds like a main power board issue. After you unplug it, it will work? Are you planning on trying to service it or having it serviced?
Thanks,
Lee
Jul 13, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic PT-56LCX66 buzzing noise when i push power
I'm going to take a guess and say that the buzzing noise and burning smell was either a transformer or a blown capacitor (more likely). It's likely that your old lamp was still good and there is a problem at the circuit level.
If you or someone you know is comfortable with electronics, you may want to open it up and take a look. If there is a blown capacitor it will be obvious. Take a look at badcaps.net or Youtube for help on identifying them.
If you don't feel comfortable working on the inside of a TV it's probably time to get a new one. Repairs will not be cheap and they won't be worth it.
Jul 24, 2012 | Panasonic PT-56LCX66 56" HDTV
Hello. My Panasonic PT-50LC13 is not turn on. First flashing green light for one minute on the power button then starts to blink red and at the same time it starts blinking red LED lights every five...
Check ur tv fan,if ur cooling fan are runnig,before all these LED lights are flashing.If not that ur tv problems.All these LED lights are flashing the tv making alots of clinking noises too like it trying turn itself on?Yes,than the tv board that called the Ballast board it is dead too,must be replace also.This tv Ballast board only job are to help to ignite the tv projection lamp only and keeping it on and running.
Aug 29, 2011 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-61DLX76-K TV, no picture, red lamp indicator flashes once every five seconds. Bulb looks okay visually. Panasonic says bad ballast I need confirmation and service manual.
Hello.
Lamp should be replaced in average every 2.5 years. Bad lamp could look OK but it is not.
Replace the lamp first if it is older than 2-3 years. You have to do it in any case. If new lamp will not
work, only then you can start thinking about ballast replacement.
If you are OK with the screwdriver and you have technical skills you don't need service manual to replace ballast. You will need to remove rear cover and locate it near the lamp. It is not too hard.
Regards.
Russ.
Dec 01, 2010 | Panasonic PT-61DLX76 Television
Panasonic plasma th42ph10uk power red light blink twice
Manual says problem with SC, SS, or C boards. SC is large board at left when facing rear, SS is large board at right, and C is small long board at very top. You could check fuses on SC and SS. Also, SC and SS should make a buzzing noise(not too loud) if operating. If a fuse is blown, suspect that board is bad not just bad fuse. Search parts at encompassparts.
May 08, 2010 | Televison & Video
How to reset lamp timer on panasonic PT-61dlx76
If the above do not work, after message to reset goes away, press and hold the volume down button on TV and then the zero button on remote.
Dec 23, 2009 | Panasonic PT-61DLX76 Television
There is no picture or sound and the lamp light is red.
Most likely the lamp is burned out buy you a new one and replace it. It is consumer replacable.
Aug 06, 2009 | Panasonic PT-61DLX76 Television
Panasonic PT-56WX33/red light blinks 3 times ovr-n-ovr
It's one of two things, a bad chipset, or bad lamp. 200-250 repair. Hope this helps
Jul 07, 2009 | Panasonic PT-56WX53 53" Rear Projection...
Panasonic PT-51HX41 51 inch
If the power led blinks its an error code such as 3 blinks means convergence failure which is the most common error for your model.Let me know the error code and I will assist you with what you need to do.
May 28, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic PT-61DLX76 Television Logo
63 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
