Question about Pioneer KEH-P2030 Cassette Player
Cd won't play on keh-p2030
My CD player worked fine and one day it just stopped. Now when I press the CS button, it says No Disc--but there are discs in the holder. What could have happened and how can I fix it?
SOURCE: Pioneer KEH-P6600 diplays "error-11"
use your user guide to read the problem related to error 11 .. most probably your wire connecting your changer witht he head uint is either cut or not functionall ... hope that answers the question
Posted on Jun 25, 2007
lobsterman72
  • 91 Answers
SOURCE: CD Stuck in cd player
There should be a reset button on either the face of the player or under the faceplate if its removable (tiny black button). Otherwise to remove the cd disconnect the unit and then plug it in or remove the memory fuse or battery lead for 5 seconds.
Posted on Jul 06, 2008
  • 26 Answers
SOURCE: how do you set the clock on a pioneer KEH-P2030
1) Hold the source button until the radio shuts off.
2) Hold clock button until clock is displayed.
3) Use < and > buttons to move from hours to min.
4) Use volume up and down to adjust time.
5) Press band button when finished.
6) Press source button to turn radio on.
Posted on Jan 21, 2009
Blackberry_U
  • 223 Answers
SOURCE: CD is stuck and eject button doesn't work
Unplug the cd player and open the unit up by taking the top cover off..there will be screws holding it on on the underside. You should be able to retrieve the cd from inside. Your track is broken, you will need to replace it.
Posted on Jun 01, 2009
fingaz22
  • 1068 Answers
SOURCE: When I put a audio disc in my cd player. I get on
this is a error code for can't read disc or bad lens. what you need to do first is try a cd cleaner in it first and then if not you will need to have it repaired because the lens can't read data.
hope you get it going with the cleaner! good luck
Posted on Nov 04, 2009
Technics SL-MC60 error message: "Take out"
Hello
If a disc has been put in the slot of the disc in play, Remove the disc, whose number is displayed, and press stop button.
Because of light or noise, the changer has detected a disc in the lot of the disc being played, even though it is empty. Check whether there is a disc in the displayed slot. With front panel closed, hold down "STOP " button for atl least four seconds or more.
Feb 03, 2012 | Audio Players & Recorders
Turntable will power up, all the lights come on,reads the cd but does not play. unit has to be turned off then on to eject the disc ? (hope this helps) Any ideas?
One of the buttons has got stuck, so when you press the button you want to, its not getting the message to start / stop playing. This is also why the eject won't work. Either a new button, or replacement board would make it happen for you :)
Jun 24, 2011 | Pioneer CDJ-1000 CD Player
I have a Sony Psyc CD Walkman D-Ej010 and I will have a cd in there at it will play for a few minutes and then stop and say no-disc. What could be the problem?
There may be a couple of reasons why a NO DISC , DISC ERROR or INSERT DISC error may appear in the display of your CD player. Try doing the following steps to troubleshoot why the error is displayed:
  • For disc players with a HOLD switch, make sure to move the switch to the OFF position.
  • Verify that the disc being used is supported by the CD player. NOTE: CD players do not support VCD or DVD discs. In addition, some CD players do not support CD-R or CD-RW discs that are created by a CD burner. For information regarding disc compatibility with your player, refer to the operating instructions supplied with the product
  • Ensure a disc has been inserted into the player. Make sure that the disc is inserted correctly, with the playback side of the disc facing down on the disc tray.
  • If the disc still does not play, attempt to play a different, commercially-produced disc.
  • NOTE: If more than one of the commercially-produced discs do not play, verify whether the discs are extended-length discs. Some players are not able to play discs where the recording exceeds the standard 74 minutes. If the recording of the disc is longer than 74 minutes, it is possible that some of the specifications of that disc were compromised and therefore, the CD player will not recognize that disc.
  • If the disc is dirty with fingerprints or smudges, or if the disc is scratched or broken, the CD player may not recognize the disc.Clean the disc using a soft, dry cloth.
  • Properly reinsert the disc into the player.
  • Attempt to play the disc again.
  • Only press the PLAY button once. If the PLAY button is pressed more than once, the disc may stop playing.
  • If the disc is still not recognized, remove the disc and leave the CD player powered on for approximately one hour to resolve the possibility of moisture condensation inside the player.
  • Please use a Lens Cleaning disc and check if that helps.
If the issue persists, please click hear to locate the repair facility near your area.
Thanks for understanding. Please let me know if you require any clarifications.
Jan 29, 2010 | Sony Walkman D-EJ010PS Personal CD Player
CD player will not play burned Cd's anymore after 5 years of work
If it has been playing CD's for over 5 years (really reliable CD player.) then I'd think it's had it's life, it needs to rest now. Meaning it's dead so you either get a replacement or a get a new CD player.
This is what happened to my mum by the way. ;)
Sep 03, 2009 | JVC XLFZ2585 Disc CD Changer CD Players
Can't set the time on my pioneer DEH-10 cd player
turn off power to unit wait 5sec to shut off hold the source button down than press and hold down the function or f button till beep and scroll threw features by pressing function or f button and clock should be located there turn power back on after setting by pressing the source button and time should be set on unit
hope this helped
Mar 04, 2009 | Pioneer KEH-P2030 Cassette Player
I need to know how to get it on radio and change channels
hi there
if there is a source button press it till radio display is in screen if you press the source button it will switch from CD - tape - am/FM
to select the channels after this is done press left or right
hope i was able to help
Feb 16, 2009 | Pioneer KEH-P2030 Cassette Player
How do you set the clock on a pioneer KEH-P2030
Jan 18, 2009 | Pioneer KEH-P2030 Cassette Player
Pioneer KEH-P2030 Cassette Player Logo
20 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
