Question about Car Audio & Video
Alpine water cooler YCH-720w cold water warm
The cold water tap is putting out warm water
  • 263 Answers
SOURCE: water not getting cold
see if the compressor is working or move the thermostat to a highter level
Posted on Dec 30, 2007
  • 171 Answers
SOURCE: Plumbing - no cold water from cold water tap
Hi blondi_1452,
I'm Harvey the Master Plumber.
Your question is: Why would the cold line water be luke warm?
In 30 years I've seen this maybe 10 times. It is relatively rare. But each time it was a cross connection between the hot and cold water lines. It could be this fixture is close to the hot water heater or the cross cnnection is in a faucet or it is in the way the water lines are piped. Anyway I would have to closely inspect the system while running the water in the fixtures in different combinations. Once the cross is located the easiest fix at this point is installing a check valve at the right point. You might consider utilizing thr Repair Directory to find a repairman. Make sure he has solved this type of problem before.
Feel free to contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 14, 2008
SOURCE: my water cooler tastes metalic
I have bought a sanitiser to see if this works so will hang on now to see if this fixes the problem.
Jenny
Posted on Feb 06, 2009
  • 1150 Answers
SOURCE: my mt 12 cooler doesnt blow cold just warm air
thermostat could not be set properly, compressor could not be running, unit could be low on freon. start checking some items and let me know.
Posted on Nov 28, 2010
  • 3 Answers
SOURCE: My water cooler won't cool
Check to see if fans are working i just bought a used one and one of the fans was not working and i fixed it and sems to be working
Posted on Feb 16, 2012
I have a whirlpool he washing machine, when I put the temperature on warm or hot, all I get is cold water. what can I do?
Hi Kimberly, You have to have both hot and cold water taps connected and turned on and if you have then your hot/cold water switch is faulty, I hope this helps........CHEERS..
Apr 30, 2016 | Whirlpool Washing Machines
Our bath taps which are a mixer with shower attachment stay really hot if you put the hot on first or really cold if you put the cold on first any idea how to adjust so we can have warm water when turning...
you make no sense. From the picture the water "mixer" is the center lever or is it a diverter valve for the shower and water nozzle below???
The knobs are for hot and cold water??
Jun 08, 2014 | Plumbing
97 acura 3.2 tl temp gauge doesnt read anything stays at cold doesnt move at all, whats could it be???
Your thermostat which closes when cold to let the engine warm up and opens when the water gets hot and lets it circulate through the radiator. If they stick closed your engine overheats in short order. When they stick open it takes forever and a day for the heater to warm sufficiently. This also makes the engine use more fuel. If your thermostat is indeed stuck open it is easy to tell. With the engine cold, take the radiator cap off and start the engine. If it is stuck open water will immediately circulate as seen at the radiator cap opening. If the thermostat were operating normally you would not see water moving for 5 or more minutes of idling. You should always drain the coolant, flush and refill every 2 years. Never ever grab that garden hose and put tap water in your radiator. They come from the factory with distilled water (about $1 a gallon at any grocery store) which has no minerals in it. The minerals in tap water promotes rust and scale build-up in the cooling system reducing it's efficiency. Don't use tap water unless you WANT to have problems.
Jan 03, 2012 | 1998 Acura TL
Getting hot water only into the tub. Is that a bad mixing valve? Where can I get one for a VERY old Maytag Washer?
The cold water valve could be faulty. It's quite possible that the valves haven't changed. If you don't need hot water put the HOT hose on the COLD tap and wash on 'hot' or 'warm' you'll need to rinse on hot or warm or the machine wont open the 'hot' valve which is now delivering cold water!!!! Enjoy.........Nomess
Apr 18, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Our washing machine is putting out hot water when the temprature setting is on cold ...and cold water when it is on hot. All rinses are hot. What part could be bad?
The water temperature is incorrect The temperature of the incoming water determines the temperature of the water in your washer. You get either hot, cold, or a mix of the hot and cold water that's currently available to the machine. So if the cold water that enters the machine is very cold--or if the hot water entering the machine is very hot--the warm water is affected. If you live in a Northern climate, unless you adjust the hot and cold water taps that supply water to your washer, the warm water supplied to your washer is usually hotter during the summer months and colder during the winter months.
Jan 03, 2010 | Washing Machines
My GWL10 fills really slowly. It starts fine with the hot water, then slows to a trickle when it switches to cold but it doesn't seem to affect it if I change the temperature selection. I normally leave it...
sounds like you have a restriction on the cold water water pipe kinked or a blockage turn off cold water and remove pipe from cold tap then turn tap on and see if water is coming through fast enough if it is then the restriction is in the hose or valve on washing machine if not then the restriction is in the cold water tap
Jul 14, 2009 | Fisher and Paykel GWL11 Top Load Washer
No cold water is comming out of the cold water pipe, when I press warm/cold only the warm water comes out what could be the problem?
hi sounds like u could have self pluming taps on your hot cold pipes common for them to get blockd due 2 hard water need 2 replace taps or remove and clean holes out in old taps hope im right from washerman27
Apr 27, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
HOT WATER WON'T FILL TUB
most inlet water hoses have screens in them.  You could remove the hose from the back of the washer and see if there is water flow.   If there isn't, the hot water valve assembly is defective.  These are solenoid operated valves that admit water into the tub.  They can be accessed behind the washer after you remove the back.
Mar 30, 2009 | Amana DLW330RA Top Load Washer
Car Audio & Video Logo
182 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
