Question about HP COMPAQ DC5850 PC Desktop
5 BLINKING RED LIGHTS - HP COMPAQ DC5850 PC Desktop
Why does it have six red blinking lights?
Hi Tim
In my opinion
No... the LED's are doing their job
Error reporting
Modern TV's are computers and try to indicate where a problem exists.
Does it need a Firmware upgrade?
Red green or orange lights are on or blinking on the TV
Sep 22, 2015 | Sony KDL-50R550A 50" LED TV 1920x1080, 240...
Red/green lights both blink and tv will on turn on
Are the red and green lights blinking at the same rate or not? If the green light is blinking every 3 seconds and the red light is blinking every 1/2 second, the lamp door is not properly secured. If both lights are blinking at 1 second intervals, try replacing the lamp. If a new lamp doesn't solve the problem, the TV needs service.
I hope this helps.
Jun 23, 2011 | Toshiba 52HM95 52" HDTV Projection...
Tv wont turn on it cycles through about 5 times then it turns off blinking 2 red lights at the bottom of the monitor.
Are you sure its two red lights blinking and not the one red light blinking and you can see it through the other window to look like two red lights? If so sounds like your lamp is blown. Open the back door and unscrew the lamp (2 phillips screws) and check to see if your lamp is blown.
Nov 02, 2010 | Toshiba 50HM67 50" HDTV
Had Blinking RED blinking lights. FIXED
CHECK LAMP COVER, CLOSE IT AGAIN THE RIGHT WAY
Feb 21, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Two Red lights blinking constantly. unable to
Epson -R 230 desktop printer. Two Red lights blinking constantly on the control panel (beside main switch). unable to print.
Oct 24, 2009 | Epson STYLUS R230 InkJet Photo Printer
6 red blinking lights
You have a bad thermal fuse.
Oct 23, 2009 | Televison & Video
Philips LCD TV - Red blinking lights
I would check the capacitors on the power pack for failed or blown ones. doing this work will require soldering skills
FYI
Mar 21, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Flashing red ring on x box 360 console
3 Blinking red lights often means that your Xbox 360 has suffered from hardware failure.
4 Blinking red lights means that your Audio / Video cable is not correctly connected (it's the colorful one; Red, white, yellow; green, blue, red if Component)
If it IS just three lights, and you bought your xbox 360 under three years ago, call 1-800-4MY-XBOX
Jul 18, 2008 | Video Game Consoles & Games
HP COMPAQ DC5850  PC Desktop Logo
14 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
