Question about Mitel 5224 IP Phone
5224 doesn't ring
Don't ring
Mitel 5224 not showing any signs of life
You should have received a power supply with the phone. If it is new, and will not turn on at all, there is a good chance it is not plugged in correctly. You should have two Ethernet cables plugged into the rear of the phone. One for Data, and another for power.
Once on, it will still have to be set up by your IP Service provider.
Mar 20, 2014 | Mitel 5224 IP Phone
The rocker zoom in and out on the top has frozen and doesn't work suddenly :(
I think focusing ring got stuck or jammed. What you can try to do is spray some compressed AIR into the lens to try to free up any sand or dust that may have worked its way in. If that doesn't help, you can gently bump the camera to try to free the focusing ring.
or.......
You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Good luck and have a nice day.
Rating the solution is highly appreciated.
Jul 03, 2011 | Cameras
I want to change the voice message on my mailbox. I have a Mitel 5224 IT Phone. I hit the envelope and it says "NO MESSAGES". How do I record the message?
the envelope button only works when it is flashing. Need to dial the voicemail or if there is a key programmed on the phone that rings voicemail.
Jun 09, 2011 | Mitel 5220 IP Phone
Mitel 5224 Speakerphone not working
it is likely the phone is in headset mode. If you've got a headset button programmed, then it should be lit.... if so, press it and it should work for you.
If you don't, you might be able to use the blue superkey to either turn off headset mode or set a button.
Press the Blue superkey, Press an unused button in the two rows of buttons. Press the "Change Key" softkey (under the display). Press No until you see headset key... press Yes.
Press the superkey again to get out of the programming.
Now that you've got the key programmed for headset, press it, if it's lit, press it again. Test your speakerphone.
If this doesn't work, I believe you would have a defective phone and should report it to your system admin or telephone system vendor for repair/replace.
Sincerely,
Mark
May 31, 2011 | Mitel 5224 IP Phone
Panasonic kx dt 333 When the phone rings the red light doesn't flash to denote which line it's coming in on. Any idea how to resolve this?
Which means what? You have a solid red light on the line or you don't have the line at all. A TDA system rings by a process called ICD groups. You can have a phone in an ICD (600 by default) and tell it the number of rings to delay, not ring, or immediate ring, but that means that the line button will flash as the call is coming in. If you don't assign it to a group, it's really stupid and won't do anything but light solid red.
If you have access to installer programming, you assign the extension to the main ICD. If you don't you have to call your Panasonic installer or dealer.
Carl
May 11, 2011 | Panasonic KXDT333 Phone
My computer is slow wont to put it back to factory settings but dont have cd
download this software if you don`t have one, it`s registry cleaner and run it on your pc, every 5 days, it helps keep your system fresh, it`s free, you don`t have to pay anything , here is the link http://www.piriform.com/ccleaner/download/standard
Mar 10, 2010 | Acer Aspire 5536-5224 Notebook
Mitel 5224 keeps flashing message but is no message
This sounds like you have a call back message active on your phone, The callback is a through back to the days before we had Voice-mail, if you wanted a person to call you back you could activate their message light by pressing your message key while the called phone was ringing. To remove the light you would lift your handset and press the message key then select which party you wished to "callback", once the call was answered at the other end the light would be extinguished. Give this a try, I bet you will be surprised at the results.
Jul 16, 2008 | Mitel 5220 IP Phone
Mitel 5224 IP Phone Logo
51 people viewed this question
Top Mitel Computers & Internet Experts
Martin Murray
Are you a Mitel Computer and Internet Expert? Answer questions, earn points and help others
